Old 03-25-2003, 12:50 AM   #1
s13rookie
s13rookie's Avatar
s13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant futures13rookie has a brilliant future
Send a message via AIM to s13rookie
flat spots on brand new tires
i have 4 new tires on my s14. by new i mean less than 500 miles. the other night i was coming home from work, dog in the road, locked up all 4's. damn i miss abs. i now have flat spots on my tires that turned a butter smooth ride into a constant thumping,. im just wondering if i was to do a few burnouts in my driveway, and than rotate tires, and do another burnout. would that help to even out the flat spots? or would it just wear down the already flat spots worse. i just need these tires to last me like a month till i get my plans under way. thanks, matt
Ive spent most of my money on cars and women...the rest i wasted
s13rookie is offline   Reply With Quote
Old 03-25-2003, 03:21 AM   #2
adey
adey's Avatar
adey is an unknown quantity at this point
Remember that if you're on an open diff, you may only "shave" one of the two rear tires... if they're directional, you may have to spray some water (or do something similar?) to get the other wheel (the one you couldn't manage to spin) to 'shave'. If you have non-directional tires, you can swap 'em around as you please... just make sure they all get 'shaved'.
If you have an LSD (or even VLSD) you won't have to rotate the tires as much.
Instagram: @SX180HKG
adey is offline   Reply With Quote
Old 03-25-2003, 10:32 AM   #3
hookedup240
hookedup240's Avatar
hookedup240 is an unknown quantity at this point
Send a message via AIM to hookedup240
What kind of tires, they must be really ****ty if they are messed up only after 500 miles.
hookedup240 is offline   Reply With Quote
Old 03-25-2003, 03:59 PM   #4
sykikchimp
WOW addicted
sykikchimp's Avatar
thats a silly statement.. how good a tire is, does not determine whether or not it will flat spot if you lock up the tires.. many VERY expensive tires will be more prone to flat spotting because of softer compounds.
Old 03-25-2003, 04:30 PM   #5
hookedup240
O Ok sorry i guess i didn't understand what he meant then. Thanks
Old 03-25-2003, 06:03 PM   #6
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
you need better brake control man....
but, do the front tires first if you're gonna do it the burnout way. the rears might not be anywhere near as bad as the fronts. less weight over them during the ordeal.
AceInHole is offline   Reply With Quote
Old 03-25-2003, 11:15 PM   #7
piratepete420
piratepete420 is an unknown quantity at this point
Just wondering, how long did you lock em up for? Also, what kind of tires?
piratepete420 is offline   Reply With Quote
Old 03-26-2003, 08:02 PM   #8
s13rookie
s13rookie's Avatar
dunlop something on stock alloys are the tires. i need better brake control yes, but understand, my last 2 cars (eclipse,civic) have all had abs, i took it for granted. still getting used to the car
thanks, matt
Old 03-26-2003, 08:56 PM   #9
deviousKA
deviousKA's Avatar
deviousKA is making a name for him/her selfdeviousKA is making a name for him/her self
Send a message via AIM to deviousKA
unless you wear your tires way down your flat spots wont go away. they will thump there and wear wrong for a long time, burnout wont help much and you have no lsd. you will have one thumping tire that is worn out and probably a ticket as well. anyone willing to argue consider this, a tire that is unbalanced will not become round because it did not start out round. a flat spotted tire is unbalanced or out of round
deviousKA is offline   Reply With Quote
Old 03-26-2003, 10:42 PM   #10
adey
adey's Avatar
"Dunlop something" doesn't help too much. I take it they're all season tires, then? relatively cheap? ... kind of strange that a hard compound tire like that would flatspot so easily.
That said, devious- point taken, but wouldn't you agree that burning each tire out would make it slightly more bearable, not to mention is a cheaper alternative to 4 new tires. ($$$!!!)
Old 03-26-2003, 11:27 PM   #11
s13rookie
s13rookie's Avatar
sorry, dunlop something is all i can remember. i didnt feel like grabbing a flashlight and running outside in the rain to find the exact model number.
what i was trying to say is basically this " i have flat spots on all 4 tires, i want to remove flat sopts so tires will last a month. will doing a few burnouts, than rotating tires. remove the flat spots, or help make flat spots worse?"
Old 03-26-2003, 11:34 PM   #12
s13rookie
s13rookie's Avatar
i think i have my answer but figure this: assume i took .020'' of the tread, compared to the rest of the tread. i was just assuming it would be like turning something on a laithe, only the highest points are affected( highest points being the majority of the tire not affected by the flat spot. would doing a burnout resemble the laithe effect? or would other forces such as suspension, make a difference?
Old 03-27-2003, 01:21 AM   #13
knightrider
knightrider's Avatar
knightrider is an unknown quantity at this point
basically, you cant get rid of the flat spots, you would be better off just buying new tires, even though they are only for a month, you screwed up, all be it not on purpose, and u ruined brand new tires, they are pretty much shot, there is no half assed way around it, just curious, how fast were u going, and how large are the flat spots?
Drift_ Into A Mountain
Jim Wolf Technology
Stock CA18DET-SR T25-greddy FMIC-JWT SR Lightened FLywheel-300zxTTclutch-SR20DET JWT tuned Ecu
knightrider is offline   Reply With Quote
Old 03-27-2003, 08:11 AM   #14
sykikchimp
WOW addicted
sykikchimp's Avatar
My bet is that they are pretty big flat spots.. I have locked down my brakes several times, and have never got a flat sport large enough for me to get a thumping while driving.
Old 03-27-2003, 08:55 AM   #15
piratepete420
What about shaving the tires like they shave race tires?
Old 03-27-2003, 08:58 AM   #16
Dousan_PG
Dousan_PG's Avatar
i have a LSD
ill shave your tires at the track for you
Aaron
Pink GodziRa
Old 03-27-2003, 09:00 AM   #17
Dousan_PG
Dousan_PG's Avatar
mm i think we need to shave some more off, sir.
Aaron
Pink GodziRa
Old 03-27-2003, 10:04 AM   #18
knightrider
normally they shave racing slicks, i would think the gaps in the tread would creat a problem
Jim Wolf Technology
Old 03-27-2003, 10:57 AM   #19
95Blue240sx
95Blue240sx's Avatar
95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection
i did the same thing, but only the fronts locked up. took a bing chunk of tire out. i went back and lied to the place i bought them from but they would not replace it for free. go back to where you got the tires, tell them what happened and they will probably pro-rate them. they wanted to charge me $60 after i just paid $80 for a warranty on all 4's. and they didnt want to cover it cause it wasnt a "road hazard" i said screw you, and left. im not paying for new tires after paying for new tires, then a $80 warranty. !@#K that. deal with it. i did.
Please leave me feedback
95Blue240sx is offline   Reply With Quote
Old 03-27-2003, 12:23 PM   #20
andrave
andrave's Avatar
andrave is an unknown quantity at this point
Send a message via AIM to andrave
damn I've locked up my bfg touring t/a's for long periods of time, and the ****ty ass coopers or whatever was on there before I used to just have fun with, and I've never had a flatspot big enough to cause any problems at all.
andrave is offline   Reply With Quote
Old 03-27-2003, 11:30 PM   #21
RedlineRacer
RedlineRacer is an unknown quantity at this point
Send a message via ICQ to RedlineRacer Send a message via AIM to RedlineRacer
How fast were you going when you locked up your brakes?
RedlineRacer is offline   Reply With Quote
