Old 08-05-2008, 02:52 AM   #1
lilaznjeff
lilaznjeff's Avatar
lilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to behold
sr20det ecu help
i have a s15 sr20de swap
trying to covert over to cam angle sensor
i need some of your help
i know you guys might not can help me but try your best please
ok the s13 sr20det ecu 61 62 63
runs with 4 wires for the ignitor chip
with 4 pins to the ecu. for the ignitor chip. which is 1,2,8,9
the cam angle sensor runs with the 38,47,46,48,39
the s14 sr20det e5 e6 wc
im not too familiar with this harness can some body explain the cam angle set up and the DIS setup
or even a wiring diagram for me
the s15 i know for a fact that the ignitor are on each coilpack.
my question is-- are the later year s14 kouki harness simluar to the s15 harness
does the later year kouki swap comes with the ignitor chip as well
lilaznjeff is offline   Reply With Quote
Old 08-05-2008, 04:00 AM   #2
S14DB
AFC #1
S14DB's Avatar
S13/14 needs an ignitor. S13/14 use the same coils. S15 is totally different. You can get a S14 Harness, ECU, coils and ignitor to run the S15 motor. Just have to compensate for the injectors if they are not 370's.
Zenki and Kouki harness pinouts are different. Make sure you have matching harness and ecu if you go this route.
