Old 06-22-2008, 05:53 PM   #1
2.0-TURBOcoupe
2.0-TURBOcoupe's Avatar
2.0-TURBOcoupe will become famous soon enough2.0-TURBOcoupe will become famous soon enough2.0-TURBOcoupe will become famous soon enough
SR sr20. rough idle LOUD backfire
89 base model coupe
redtop sr20
s14 t28
255 walbro
z32 maf (blo through)
stock fuel injectors
brand new plugs.
ok i was driving the car a couple of nights ago and it was kind of chilly out so i turned on the heat(which works great) but it was the first time i have ever used it. afterwards i puled up to a redlight and took of driving normally and the car let out one of the loudest backfires. now, during a shift or decel of RPM the car will backfire. i was driving back to my house and i fouled a plug. i replaced the plugs but its still idling rough and when i rev it up it will back fire very very loudly. checked fuel presure. cleaned iacv. throttle body. unplugged maf(no change in idle). im at a loss. the car has never given me any sort of problem before. if anyone has any suggestions let me know
2.0-TURBOcoupe is offline   Reply With Quote
Old 06-22-2008, 05:55 PM   #2
rightcoastimports
rightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond repute
check your timing...
95 SR Zenki | @ e_form
daily - A34 Maxima | A36 Maxima
rightcoastimports is offline   Reply With Quote
Old 06-22-2008, 08:35 PM   #3
xxsptcuztomsxx
xxsptcuztomsxx is an unknown quantity at this point
where in tn do you live? if your close you could bring the car by and i could take a look at it...
xxsptcuztomsxx is offline   Reply With Quote
Old 06-22-2008, 08:38 PM   #4
Jordan-S13-Silvia
Jordan-S13-Silvia is a jewel in the roughJordan-S13-Silvia is a jewel in the roughJordan-S13-Silvia is a jewel in the roughJordan-S13-Silvia is a jewel in the roughJordan-S13-Silvia is a jewel in the roughJordan-S13-Silvia is a jewel in the roughJordan-S13-Silvia is a jewel in the rough
i suggest you not use blow through in all the cases ive seen it never works properly.
just try putting the maf back to its traditonal spot and see how it runs then
Jordan-S13-Silvia is offline   Reply With Quote
Old 06-22-2008, 08:40 PM   #5
flip3d
flip3d's Avatar
flip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond repute
Send a message via AIM to flip3d
+1
check that shit d00d. get a cheap timing light from autozone. you'll be glad you have one.
flip3d is offline   Reply With Quote
Old 06-23-2008, 12:56 AM   #6
2.0-TURBOcoupe
i can never figure out how to time the motor properly. i have tried to set the CAS timing before with a light and i end up just having to do it by ear. when i hook up the timing light by the loop or by bridging the coil pack it looks like the pully is just rolling around. i need help bad.
Old 06-23-2008, 01:03 AM   #7
singlecamslam
singlecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymore
did you line up the CAS correctly? there should be a mark where you line it up. Make sure that is lined up properly.
Nothing says racecar like a stock car with no interior.
singlecamslam is offline   Reply With Quote
Old 06-23-2008, 01:10 AM   #8
2.0-TURBOcoupe
yes i did. i followed the timing procedure exactly like the fsm tells you too.
Old 06-23-2008, 02:40 PM   #9
2.0-TURBOcoupe
morning bump can anyone help
Old 06-23-2008, 02:50 PM   #10
rps13drift
rps13drift's Avatar
rps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfection
One of my fuel injectors i think was either leaking or stuck open and it would shoot no joke a 2 foot flame just from decelerating and letting the rpms go down every single time pretty much on command! I used to scare the shit out of people on the side of the road all the time! LOL! So check those pups out or it could even be a slight boost leak! Pretty much anything that will cause your car to run hella rich will make you backfire/pop especialy if your not running a cat!
rps13drift is offline   Reply With Quote
Old 06-23-2008, 05:53 PM   #11
sonomadrifter
sonomadrifter's Avatar
sonomadrifter is a jewel in the roughsonomadrifter is a jewel in the roughsonomadrifter is a jewel in the roughsonomadrifter is a jewel in the roughsonomadrifter is a jewel in the roughsonomadrifter is a jewel in the roughsonomadrifter is a jewel in the rough
I am having almost identical issues with my SR as well (with similar set up), there are too many things that can cause this. I've replaced the coolant temperature sensor with no noticable gains next Im looking at injectors and timing. How is your start up? What is your fuel pressure exactly? (should be 43ish?) Did you notice any fuel on your plugs?
I wish I could help more, keep us updated.
sonomadrifter is offline   Reply With Quote
Old 06-23-2008, 05:57 PM   #12
2.0-TURBOcoupe
number four plug was a little wet after i let it set overnight. number four also seems to be the blackest in color too.
Old 06-24-2008, 03:54 PM   #13
2.0-TURBOcoupe
anybody anybody
Old 06-24-2008, 11:37 PM   #14
Jordan-S13-Silvia
hmm this kinda sounds similar to how my SR is acting.
Old 06-24-2008, 11:54 PM   #15
downshift_sideways
No Limit Soldier.
downshift_sideways's Avatar
downshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfection
Send a message via AIM to downshift_sideways
It could be a lot of problems.
I'd suggest to check your coolant temp sensor...only because it happened after you turned up the heater. A bad coolant temp can foul your plugs.
I'm assuming your running rich?
allntrlundrgrnd: "you never really appreciate your parents fridge until you look into your own and its full of condiments only"
downshift_sideways is offline   Reply With Quote
Old 06-28-2008, 05:39 PM   #16
2.0-TURBOcoupe
i wouldnt really say rich. its not smoking at idle or while driving the car just in between shifts w the backfire and then it goes away and only the number 4 plug is wet or black
Old 07-02-2008, 10:21 PM   #17
sonomadrifter
Mine only sometimes smoked durring start up (in which it acted flooded) if not at all yet I could smell gas and my backfire's occurred deceleration and shifting as well.
*UPDATE*- Car is running perfectly now, I believe my number two injector was stuck or leaking but it is now fixed (fingers crossed).
Old 08-05-2008, 10:05 PM   #18
TurboNinja
TurboNinja's Avatar
TurboNinja is making his/her stupidity well-knownTurboNinja is making his/her stupidity well-knownTurboNinja is making his/her stupidity well-knownTurboNinja is making his/her stupidity well-known
So is backfiring in general normal with these vehicles if your not running a cat?
TurboNinja is offline   Reply With Quote
Old 08-05-2008, 10:22 PM   #19
WoolyS14DET
WoolyS14DET's Avatar
Trader Rating: (18)
WoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond repute
Feedback Score: 18 reviews
Send a message via Yahoo to WoolyS14DET
Sounds like a timing issue. Correct timing adjustment is as follows, Unplug and plug in the TPS 3 times and on the 4th time leave it unplugged. (this puts it into timing mode.) make you adjustment via the CAS. After adjusting then plug the TPS back in and see what happens. If the timing light goes crazy while your doing it you could have and issue where one of the cams jumped a tooth or may have a bad pulley. (the outer ring is slipping on the pulley) Try that and see what happens !
WoolyS14DET is offline   Reply With Quote
