Old 08-09-2008, 10:51 PM   #1
180Sil
180Sil will become famous soon enough180Sil will become famous soon enough180Sil will become famous soon enough180Sil will become famous soon enough
8.5:1 CR to 9:1 CR with JWT ECU, reflash?
I just had oil shooting out of the dip stick, major blow by, and oil on a couple of spark plug so time for a rebuild. But I'm running a JWT ECU with 740cc nismo and m62 maf with a 2871 .64 gtrs style. Right now I'm trying to decide between an OE rebuilt or a full rebuilt, reluctant for full due to $$$ issues. My goal is 400whp or 20psi with this setup, but reliable for track (2-3 times a year) and it's my daily driver. Maybe anything close to those goal is acceptable with an OE rebuilt.
Something like this is to be expected from these older sr20det motors under these extreme condition but I really don't have the $$$ for machining the block for oversize and pistons and rods and bearings and seals, etc.
One reason I was told my rings might have failed is because the car runs rich (10.5 a/f) at idle but is normal once boost hits (11.25 a/f). I don't know why this happens but it could be a bad O2 sensor, didn't check yet.
So the question is, do I need to send in the ecu for a flash due to increase in compression? I don't want the downtime as this is a DD. Will I be able to use afc, emanage blue to adjust the jwt ecu for the difference in compression and what will happen from the different in compression?
180Sil is offline   Reply With Quote
Old 08-09-2008, 10:55 PM   #2
1QUICK4
Stop or I'll Shoost
1QUICK4's Avatar
1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection
Send a message via AIM to 1QUICK4 Send a message via MSN to 1QUICK4
If you would have gotten an Enthalpy Ecu you wouldn't have any down time.
But the only nice thing about JWT is you can just call them up and ask.
-383 RWHP & 407 RWTQ-
Review Thread= http://www.zilvia.net/f/showthread.php?t=201106
1QUICK4 is offline   Reply With Quote
Old 08-09-2008, 11:06 PM   #3
180Sil
unfortunately my situation is with a JWT and they're not open tomorrow so I figure someone on the forums might know something while I do some research and gain more information to better help me make the right decision.
Old 08-10-2008, 04:31 PM   #4
l20bdime
l20bdime is a glorious beacon of lightl20bdime is a glorious beacon of lightl20bdime is a glorious beacon of lightl20bdime is a glorious beacon of lightl20bdime is a glorious beacon of lightl20bdime is a glorious beacon of lightl20bdime is a glorious beacon of lightl20bdime is a glorious beacon of lightl20bdime is a glorious beacon of lightl20bdime is a glorious beacon of lightl20bdime is a glorious beacon of light
If you tell JWT what your compresssion is they can optimize the tune. Do it. I have lower compression in my KA-T and they tuned it to compensate for the sluggishness related to lower compression. mainly timing.
l20bdime is offline   Reply With Quote
Old 08-10-2008, 05:27 PM   #5
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Hate to say it but do it right, do it once. Pretty sure the blow by is coming from the piston rings going bad. You cant exactly just expect to slap some new rings and everything will be dandy. You will probably need to rehone (not bore out) the block to make sure the new rings will seal properly. Then since SRs are notorious for having crappy rod bearings, you might as well replace them with some new ones, specially since youre gonna have to pull the rod caps off to get the new rings in.
If your really in a bind, you honestly, might be better off looking for another bottom end/block. Its usually still the cheaper alternative to all that work. Get another engine and just swap everything over.
CLICK HERE!!!
