Old 03-30-2003, 07:06 AM   #1
crioten
"buddy jesus"
crioten's Avatar
crioten is making a name for him/her selfcrioten is making a name for him/her self
Send a message via AIM to crioten
tranny q's (parts)
anyone know the part numbers for the clutch line from master to slave cylinder and the box on the frame rail, speed sensor from a 5 spd, and sleeve on the end of the transmission for the driveshaft?
also please check my parts list, make sure i got everything that i need for the tranny swap on my 91 hb
stuff i have:
97 5-spd
flywheel
driveshaft
clutch kit
stuff i still need or on its way:
clutch master cylinder
clutch slave cylinder
speed sensor
brake pedal
clutch pedal w/ bracket
let me know if im missing something...and if you have one of these for sale let me know...
also is there anything about a tranny swap in the fsm?
thanks
glen
IMG exceeds forum limit of 150kb
Originally Posted by Var
I'd rather take the bus with a bus-full of AIDS infected naked rape convicts than drive a VW.
crioten is offline   Reply With Quote
Old 03-30-2003, 06:18 PM   #2
bennieboy
bennieboy is an unknown quantity at this point
Send a message via AIM to bennieboy
Do not forget the MT (engine to trans bolts, flywheel bolts, pressure plate bolts)... they are longer. Also get bolts for your starter. Do not forget transmission crossmember.
My original speed sensor was too big and the MT would not line up because they were different plugs so you may need to solder on the old connectors
If you need anything I will try my best to help you out. This was the best and only mod I have done to my car. It is like I got a new car! I did my swap in my front drive way. I did mine in 3 days
first and best mod EVER changing from auto to 5 speed! it is like a new car.
bennieboy is offline   Reply With Quote
Old 03-30-2003, 08:41 PM   #3
crioten
"buddy jesus"
crioten's Avatar
anyone know if these parts and if the tranny swap would be in the fsm?
Old 04-01-2003, 05:49 AM   #4
crioten
"buddy jesus"
crioten's Avatar
someones gotta know the parts #'s and the fsm question...
Old 04-01-2003, 08:57 PM   #5
the head
the head's Avatar
go here and look them up prices will also be included
http://www.parts.com/index.cfm?actio...eFront&sfid=49
also there is not really an need to get the brake pedal. It is a PITA to get out just take a grinder or cutting wheel to the AT brake pedal and shorten it up
