Old 08-26-2008, 07:16 AM   #1
s13hatchback
s13hatchback's Avatar
s13hatchback is an unknown quantity at this point
SR SR bucking problem but no codes!
I just swapped my redtop into another chassis and now the car starts bucking bad when i ease into the throttle, but it doesnt happen at wife open throttle.Mods are...
redtop
z32 maf(new)
greddy fmic
fujita intake (PoS)
Walbro pump
I put the boost back down to stock until i figure this out. The MAF is new as are the plugs and O2 sensor. The ECU is showing 55 no problems. I checked for boost leaks and intakes leaks and nothing. Anyone have similar issues or have had in the past i would greatly appreciate the help. Also the plugs are fine(beige color) and there was no fuel smell when i took them out.
s13hatchback is offline   Reply With Quote
Old 08-26-2008, 07:25 AM   #2
Firestorm
Firestorm's Avatar
Firestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond repute
Send a message via ICQ to Firestorm
is your ECU mapped for the Z32 MAFS?
Firestorm is offline   Reply With Quote
Old 08-26-2008, 08:29 AM   #3
s13hatchback
its a stock #62 ecu
Old 08-26-2008, 08:39 AM   #4
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
the #62 ecu is designed for a redtop SR MAF, not a z32 MAF. if your are using a Z32 MAF in an ecu that it was not dseigned for, you need some type of air/fuel controller like the ap;exi AFC, or a reflash of your ECU..
or get yourself the right MAF, or a SOHC KA24E maf.
clark is offline   Reply With Quote
Old 08-26-2008, 08:48 AM   #5
s13hatchback
my bad thought i put that in there... i have an safc2
Old 08-26-2008, 08:56 AM   #6
clark
clark's Avatar
so did you configure the safc2 to compensate for the z32 maf?
the settings are all over this forum.
Old 08-26-2008, 09:08 AM   #7
s13hatchback
yes i did 2 in 6 out hot wire
4cyl with arrow to the northeast
Old 08-26-2008, 09:21 AM   #8
HS13KLS
HS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant future
i thought it was 2 in 10 out hot wire..
i may be wrong..but thats what i thought.
check that out and see what happens
HS13KLS is offline   Reply With Quote
Old 08-26-2008, 09:46 AM   #9
0wn3r
0wn3r's Avatar
0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of
you recirculated or no?
97 240sx se
0wn3r is offline   Reply With Quote
Old 08-26-2008, 10:17 AM   #10
s13hatchback
no not recirc. it an hks ssqv
Old 08-26-2008, 10:23 AM   #11
burnsauto
burnsauto's Avatar
double check that maf/wiring..granted it may be new, but defects to happen. double check all the wiring you did..make sure nothing is loose, it really sounds like the maf is cutting out/not getting a signal.
Old 08-26-2008, 10:35 AM   #12
Black240Ct
Black240Ct will become famous soon enoughBlack240Ct will become famous soon enoughBlack240Ct will become famous soon enough
Send a message via AIM to Black240Ct
check the voltages, im not sure if they are displayed on your safc, but get in there with a volt meter
Black240Ct is offline   Reply With Quote
Old 08-26-2008, 12:38 PM   #13
s13hatchback
I believe it is displayed when you go to sensor check on the safc, though i dont know which one it is. If anyone does plz let me know...
if it is sensor 1. it is at 1.1V at idle
2 is at .25 at idle
Old 08-26-2008, 01:50 PM   #14
s13hatchback
like i said the car idles fine but when i give it slight throttle it starts cutting out and bucking. then when i get to about 3500 rpms it runs fin again under a decent amount of throttle
Old 08-26-2008, 03:36 PM   #15
s13hatchback
I just spent a few hours checking everything and the maf reads 1.25V when at idle and the boost gauge sits at zero even when the car is at idle. when i give it gas it starts to read vacuum until i hit boost and it reads the boost just fine.
Anyone have any other ideas?
Old 08-27-2008, 08:54 AM   #16
0wn3r
0wn3r's Avatar
wth? vacuum leak maybe? Mine sits at 19-21inHG at idle
97 240sx se
Old 08-27-2008, 09:47 AM   #17
BiG MiKE86
BiG MiKE86's Avatar
BiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really nice
Send a message via AIM to BiG MiKE86
sounds like u has a major vac. leak - ^^^ 0wn3r's numbers are what u should be reading - Goodluck
BiG MiKE86 is offline   Reply With Quote
Old 08-27-2008, 10:44 AM   #18
DDSR240
DDSR240's Avatar
DDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond reputeDDSR240 has a reputation beyond repute
damn I'm sorry bro I had that same problem and it turned out to be the fuel pump sock I know it sounds strange but try it. g/l
DDSR240 is offline   Reply With Quote
Old 08-27-2008, 11:06 AM   #19
GSXRJJordan
GSXRJJordan's Avatar
Haha how can no one mention GROUNDS. Check your grounds, from the MAF to the body, from the ignition harness (coilpacks) to the head, to the body, and from the ECU to the body. That's much more likely to be the problem than SAFC settings, because your car idles correctly.
