Old 08-26-2008, 10:07 PM   #1
woohaa
woohaa has a little shameless behavior in the past
Driveshaft Problem
I am wondering if an 1 piece STEEL driveshaft is worth the upgrade? I am doing an auto to 5 speed swap. Is there really a BIG difference? I read thru some threads all I know is that the engine revs faster and faster throttle response, but is it A LOT faster? This will be installed in a KA.
woohaa is offline   Reply With Quote
Old 08-26-2008, 10:15 PM   #2
Mikey88
Mikey88's Avatar
Mikey88 is on a distinguished road
if you have the money go for it
Mikey88 is offline   Reply With Quote
Old 08-26-2008, 10:18 PM   #3
djtrickz
djtrickz is an unknown quantity at this point
Send a message via AIM to djtrickz
YES! I would definitely get one. The biggest difference is the weight, but you also have to think of the extra play in the joints and the fact that there is a damper in the middle that can wear out over the years. Plus since youre already under there, might as well change it once instead of twice if you have the money.
fixafixa
djtrickz is offline   Reply With Quote
Old 08-26-2008, 10:32 PM   #4
Mikey88
Mikey88's Avatar
tell you the truth tho i ended up buying a 1pc aluminum during my sr20/auto-manual swap...so i shouldnt speak hahaha, but like trickz said it can be a good investment for the future
Old 08-26-2008, 10:34 PM   #5
g6civcx
g6civcx's Avatar
I run nothing but Driveshaft Shop 1-piece steel propeller shafts on all my street driven vehicles. It is worth it to me.
What do you value? Tell me what you value and I'll tell you if it's worth the cost to get the benefits.
Different compared to what? Stock? Aluminium? Carbon fibre?
I assume you're comparing to stock.
For a perfect new stock propeller shaft, the difference is significant. Less lag. Less vibration.
For a worn out propeller shaft, which you will probably get if you buy used, there is no comparison. The steel 1piece is much better.
is it A LOT faster?
The response is faster because energy isn't wasted twisting the 2piece shaft.
What do you think is a lot?
Someone should install a shaft sensor on the output shaft of the gearbox and one on the input of the diff. Then datalog and compare the lag between the two sensors for a 1piece vs. a 2piece.
Old 08-26-2008, 10:44 PM   #6
woohaa
Yes, I am comparing to stock. Stock vs. Steel. What mean by faster is faster response. Does it have to be Driveshaft shop driveshaft in order to be a quality shaft? How about other shafts like R&D Factory which I look through.
Old 08-26-2008, 11:03 PM   #7
g6civcx
g6civcx's Avatar
Check with the vendor. Most of the "custom" driveshafts I've seen are actually rebadged DSS shafts, which is not a bad thing at all.
I *heart* DSS.
Old 08-27-2008, 12:16 AM   #8
flip3d
flip3d's Avatar
flip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond repute
Send a message via AIM to flip3d
Do ittt! Carrier bearings are a PITA.
flip3d is offline   Reply With Quote
Old 08-27-2008, 11:47 PM   #9
woohaa
g6civicx-you said there is "less lag and less vibration"
Wouldn't a 1pc. driveshaft create more vibration, because you no longer can absorb vibration. Would a 1pc. driveshaft be bad for a DD? Is it bearable? I just want to know what I am getting into.
Old 08-28-2008, 01:34 AM   #10
ericcastro
ericcastro's Avatar
Didnt finish reading the thread.
But when that carrier bearing wears out, Its like $100 dollars under the cost of a one piece steel shaft.
So you might as well do it if you can afford it.
Old 08-28-2008, 02:02 AM   #11
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
i have a 1 piece aluminum driveshaft from DSS. i fucking love the response. LOL
i do have vibrations because i havent replaced any motor mounts i got =)
hence i have 250k on my car original everything. hehehe
Old 08-28-2008, 05:38 AM   #12
g6civcx
g6civcx's Avatar
No. The 2 piece has more vibration because the 2 pieces can rotate around the center carrier support. The 1 piece is a straight shot from the gearbox to the diff, and moves together with the gearbox if there is drivetrain movement.
With a 2 piece, vibration is transferred to the carrier support and the chassis.
I have driven over 3+ years on my 1pc with SR and V8. There is no problem for me.
Old 08-28-2008, 08:22 AM   #13
hybrid racing
hybrid racing's Avatar
hybrid racing is a splendid one to beholdhybrid racing is a splendid one to beholdhybrid racing is a splendid one to beholdhybrid racing is a splendid one to beholdhybrid racing is a splendid one to beholdhybrid racing is a splendid one to beholdhybrid racing is a splendid one to beholdhybrid racing is a splendid one to beholdhybrid racing is a splendid one to beholdhybrid racing is a splendid one to beholdhybrid racing is a splendid one to behold
Check out the link below, we have unbeatable prices on Driveshaft Shop Driveshafts.
http://zilvia.net/f/advertiser-speci...ml#post2121657
Pm me or e-mail me at [email protected] if you have any questions.
Iggy
hybrid racing is offline   Reply With Quote
