Old 09-01-2008, 01:52 AM   #1
SlideKing92
SlideKing92's Avatar
SlideKing92 is an unknown quantity at this point
240sx Manual Transmission problem
I have a 1992 nissan 240sx with a stock transmission and a stock shifter. I was getting on the freeway today only to discover that it would not shift into fifth gear. All other gears are fine and car drives fine, it just wont shift into fifth. wondering if anyone else has had this problem and was wondering if anyone could help me solve it.
Thanks
SlideKing92 is offline   Reply With Quote
Old 09-01-2008, 02:05 AM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
I wouldnt drive it, tranny's probably gonna blow soon...last thing you need is get stuck somewhere and pay off your ass in towing fee.
CLICK HERE!!!
Old 09-01-2008, 03:08 AM   #3
xpertsnowcarver
xpertsnowcarver's Avatar
Trader Rating: (44)
xpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud ofxpertsnowcarver has much to be proud of
Feedback Score: 44 reviews
id recommend getting your tranny checked after 100k mi to get the syncros replaced. gotta make sure ur changing ur fluid at least every 30k mi. your 5th gear has it's own dedicated 'slide rail' iirc. not sure if thats what that part is called. but if you hardly have tranny fluid and the car is in motion, i believe it won't let you shift into 5th. anyway, get your tranny checked. would only cost about 80 bones for a check-up. if you do need some things replaced, usually the shop will make the 80 go into the part and labor charges.
My YouTube Channel
xpertsnowcarver is offline   Reply With Quote
Old 09-01-2008, 01:31 PM   #4
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
Heh, I have seen this before. If your trans goes into all the other gears fine but won't do fith? Its toast. Do not drive it as like Ray said it will only get worse and take out the other gears. I would say the only driving I would do with it now if I were you is to your garage or the shop.
Remove and replace. Unless you really want a fresh rebuilt trans its probably worth it just to find a decent used one. They are less expensive than doing a whole rebuild.
New Video
Buy my mounts!
Old 09-01-2008, 02:39 PM   #5
nismown3d
nismown3d is an unknown quantity at this point
^i can vouch for that, same thing happened to me.
just go to the junkyard and grab another tranny, they should only be like $100 if that.
nismown3d is offline   Reply With Quote
Old 09-11-2008, 11:32 PM   #6
SlideKing92
Fixed its self some how, slightly scary, everything seems fine. I shall see how it goes
Old 09-11-2008, 11:34 PM   #7
SlideWell
SlideWell's Avatar
SlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfection
sounds like synchro issues. 5th is your gas saver, so keep an eye on it. id definitely have it checked out tho.
SlideWell is offline   Reply With Quote
