Old 09-11-2008, 10:19 AM   #1
Brolewigi
Brolewigi's Avatar
Brolewigi is an unknown quantity at this point
taking off exhaust manifold
I am putting on the a new downpipe, studs for the downpipe to the turbo, new turbo lines on my SR and I thought it would be easier to take off the exhaust manifold and work on all of that outside of the car.
I have all of the bolts off except for the two that are underneath the exhaust manifold in the center.
Any suggestions for getting them off. It was getting too late last night and I didn't want to start those two so late last night.
Thanks
Brolewigi is offline   Reply With Quote
Old 09-11-2008, 10:20 AM   #2
bigOdom1
bigOdom1's Avatar
bigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfection
im confused do you need help, sounds like you got it covered use the correct socket and you should be ok
bigOdom1 is offline   Reply With Quote
Old 09-11-2008, 10:21 AM   #3
SHIFT_*grind*
SHIFT_*grind*'s Avatar
SHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfection
14mm combination wrench......and that's it. Seriously. If it's really stuck on there you can spray some WD40 on the nut, maybe slip something over the end of the wrench for extra leverage or tap it with a hammer, but it's not hard to get to.
My seller review thread
SHIFT_*grind* is offline   Reply With Quote
Old 09-11-2008, 12:54 PM   #4
jspaeth
jspaeth's Avatar
Thanks
So you are having trouble with the 2 exhaust mani stud in the center on the bottom row?
IIRC, I used a closed-end wrench on those, making tiny (like 1/32nd of a turn at a time) turns
Daily driven
Old 09-11-2008, 01:01 PM   #5
shmiddy
shmiddy's Avatar
use a wrench. do it from under the manifold
i fully de-volved
Old 09-11-2008, 01:17 PM   #6
SHIFT_*grind*
I just did my manifold 2 weeks ago, you can even get to those nuts pretty easily from the top.
Old 09-11-2008, 01:21 PM   #7
jspaeth
jspaeth's Avatar
Yep closed end wrench from the top in between the runners bingo
Daily driven
Old 09-11-2008, 05:13 PM   #8
Brolewigi
Brolewigi's Avatar
Yeah, I've been trying it from the bottom and the dip stick keeps getting in the way. I have a stubby wrench and I can't put enough torque on it to loosten it. I can not get the wrench in from the top, it won't go on there correctly. The nut isn't clocked quite right. I'll keep trying. Thanks!
Old 09-11-2008, 08:06 PM   #9
SHIFT_*grind*
Keep trying; I don't see how it couldn't be clocked the right way, when I took those 2 nuts off a couple weeks ago there was plenty of angle to turn the closed wrench end around. Not the open end.
Old 09-11-2008, 08:16 PM   #10
Brolewigi
Brolewigi's Avatar
Thanks Grind, the closed end wrench worked like a charm. It just took a little bit to get it on the bastard...
Thanks a lot guys!
Old 09-12-2008, 08:59 AM   #11
s15specR
s15specR's Avatar
Trader Rating: (18)
s15specR is making a name for him/her selfs15specR is making a name for him/her self
Feedback Score: 18 reviews
From the top with a combi wrench, 14mm
s15specR is offline   Reply With Quote
Old 09-12-2008, 09:21 AM   #12
aa87
aa87's Avatar
aa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant future
Send a message via AIM to aa87
I always used a bunch of swivel heads and extensions. Got every bolt off using the magic combos. Stock manifolds are too easy.
Hookers and blow.
aa87 is offline   Reply With Quote
Old 09-12-2008, 11:08 AM   #13
azndoc
azndoc's Avatar
Trader Rating: (47)
Feedback Score: 47 reviews
Shit I can't remember when I took off my stock manifold.
But I've taken off my aftermarket ones like 6 fucking times now.
Flex head wrench is what I use. Then I got the lock flex head ones and that's even better.
