Old 09-13-2008, 03:29 PM   #1
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
s-13 hicas rear 5-lug?
We are trying to take my buddy's hicas car back to stock and ran into a little problem. The car was converted to 5-lug by the previous owner and when I went to put 4-lug hubs back on the rear I noticed that the stock hubs that I have won't work. It looks to have a set of hicas z-32 rear uprights/spindles and the 5-lug hubs are not removable from the spindles. They are not bolted in with 4 bolts like the s-13 hubs that I have seen. The bearings are pressed into the spindles/uprights and the hubs are pressed into the bearings. Are OE s-13 hicas rear spindles like that? Or do they have removable hubs just like the non-hicas rear uprights? We're trying to figure out what we have to do to take it back to stock and I have not worked on very many hicas cars before so I don't know for sure how the rear hubs are attached stock. Anybody have experience converting the rear of a hicas s-13 to 5-lug? Your help would be much appreciated, thanks.
Old 09-13-2008, 04:08 PM   #2
MrMcgarrett
MrMcgarrett's Avatar
Trader Rating: (313)
MrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfection
Feedback Score: 313 reviews
Send a message via AIM to MrMcgarrett
Sounds like it has J30 rear spindles/hubs on it.
You need to find some s13 hicas spindles.
MrMcgarrett is offline   Reply With Quote
Old 09-13-2008, 04:47 PM   #3
racepar1
racepar1's Avatar
Ya that is what we concluded. Good luck finding the hicas spindles I guess.
Old 09-13-2008, 05:00 PM   #4
projectRDM
projectRDM's Avatar
Ya, J30s were available with HICAS for a few years.
FORMERLY R240NA
Old 09-13-2008, 06:29 PM   #5
racepar1
racepar1's Avatar
I discovered that you can press out the balljoints in the rear spindle for the hicas toe arms and press them right back into a stock s-13 rear spindle. CRISIS AVERTED! YAY! That means that my buddy that is buying the 5-lug conversion CAN use the rear 5-lug, he just needs to buy some energy bushings to press into the j-30 upright. I am tossing around the idea of him upgrading to the j-30 rear brakes as well as he now has a 30mm 300zx front set-up and the j-30 rears should bring the brake bias a bit more towards the rear. I know that z fronts with 240 rears LOVE to lock up the fronts and this might be a cheap solution for him.
Old 09-14-2008, 01:40 AM   #6
Teambadrun
Teambadrun's Avatar
Teambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to all
R33 skyline and S13 is the same, you need the hubs,spindles,brakes,,lines etc... and you can convert your s13 with hicas to 5 stud...???
Teambadrun is offline   Reply With Quote
Old 09-14-2008, 09:02 AM   #7
projectRDM
projectRDM's Avatar
Nice reading skills. The car is already 5lug, he's switching it back to 4lug.
FORMERLY R240NA
