![]() Join Date: Apr 2008
94
aaaaaaaaaaaaaaaaaaaaaaa
https://www.linkedin.com/in/hassanbakar |
#7 | |
![]() Join Date: May 2005
Location: Louisiana. LA is for Louisiana. L.A. is Los Angeles.
There is some controversy over which are OBDI and which are OBDII... I think my s14, built in 3/94 is OBDII, but I'm not sure either. It reads correctly with an OBDII code scanner, which I've been told it shouldn't if its OBDI.
![]() Quote:
http://zilvia.net/f/sale-items/24807...-stuff-fs.html |
![]() Join Date: Dec 2002
It's like the biggest fucking broken record lately.
1995 - OBD plug below glovebox = OBD-I 1996-98 - OBD plug located beside hood release = OBD-II There is no other way to look at it. Build date means nothing.
Where is the OBD plug? And is there a carbon canister under the hood?
FORMERLY R240NA Learn what's really going on and protect your assets now before they're gone forever: www.paypalsucks.com Last edited by projectRDM; 09-15-2008 at 12:53 AM.. |
#12 | |
Carbon canister would mean OBDI, correct?
![]() Quote:
#14 | |
its as simple as ^^^ its amazing people don't understand this. |
#15 |
It's obdI then. Depending on the state they'll just use the sniffer.
-Retired |
#17 | |
If the car has a charcoal canister under the hood, beside the airbox, it's OBD-I.
#18 |
From an emissions enforcement and testing standpoint all 1995s are OBDI and exempt from the plugin test. It doesn't matter what the car is actually equipped with, it wasn't required for 95 model years so they wont enforce it for those model years.
From an actual functional standpoint 1995s manufactured after 9/94 use an OBDII compatible computer. the Port is still on the wrong side but you could pull the computer and put it in a 96 and pass the OBDII test... pre 9/94 ECUs are ACTUAL OBDI computers and are not emissions compatible with newer cars. I've confirmed this personally. (I own an early production 95 and was unable to get a read on an OBDII reader, I know someone running a late period 95 computer in his kouki and with no emissions testing issues) If you're not sure check your O2 sensor... OBDI cars use a single wire... OBDII cars use 3 wires, the manufacturing date should be stamped right on the chassis info plate, or you could also cross reference the ECU label to determine what car it came from. HT = 95 240sx MT (KA24DE) (mfg before 10/94) (A18-E07-G90) OBDI Emissions HU = 95 240sx AT (KA24DE) (mfg before 10/94) (?) OBDI Emissions 3C = 95 240sx MT (KA24DE) (mfg after 9/94) (A18-892-G00) OBDII Emissions 3D = 95 240sx AT (KA24DE) (mfg after 9/94) (?) OBDII Emissions
Everything you need to know about the S-Chassis ![]() -- CollectorsEdition.org -- | -- 240sxONE.com -- |
#19 | |
I'm guessing you can't use an OBDII computer in an OBDI s14, correct?
![]() Quote:
#20 | |
before then... it would probably WORK but throw codes. You would probably want to at least swap the MAF (I think it might be different, though I could be wrong) and O2 sensor as well.
#21 | |
You can also go the other way and use an OBD-I ECU in an OBD-II chassis, the 96 cars are a direct plug in, 97-98s require repinning three wires, JWT has a PDF on what's required. You'll also lose the rear O2 sensor since it's a 4wire on 97-98s unless you run an extra wire, but it's not needed anyway for engine operation.
#22 | |
What the fuck?!? My s14 is from 3/94, yet it reads correctly with an OBDII code scanner, and has a 3C ECU.
Can someone tell me what's going on? lol.
![]() Quote:
#23 |
Anything with an OBD plug, I or II, will work. The difference is the actual codes. 1995 cars used manufacturer codes only, while 1996+ they're mandated across all manufacturers. Read through the 1995 FSM, you won't have the same amount of codes, nor do the numbers all match up to 96+ codes. You can pull some codes using a OBD-II scanner on a 1995 model, but not all, and some won't match to what the actual problem is.
#24 | |
If my ECU is a 3C, which should be OBDII, will all the codes be OBDII compliant?
I'm calling my car OBDI½ lol. I was built 3/94, which should be OBDI, and yet it has a 3C OBDII ECU. I wouldn't imagine that the ECU had been swapped cause the car has a KA and OBDI harness... But then again...
![]() Quote:
#25 | |
#26 | |
Is there any way I can tell for sure?
![]() Quote:
#27 |
Unplug the VSS and drive the car long enough to trip the CEL, then pull up the code. If it's code 114, it's a 1995, OBD-I. If it's a code P0500, it's OBD-II.
#29 | ||
Oh well. It must be done.
![]() Quote:
