Old 09-14-2008, 09:16 PM   #1
fatlizzard
fatlizzard's Avatar
fatlizzard is on the path to ruinfatlizzard is on the path to ruin
OBDI or OBDII ?
Is my "95" 240sx with a manafacture date of 3/94 an OBDI or OBDII ?
fatlizzard is offline   Reply With Quote
Old 09-14-2008, 09:18 PM   #2
hassanbakar123
hassanbakar123 is an unknown quantity at this point
aaaaaaaaaaaaaaaaaaaaaaa
hassanbakar123 is offline   Reply With Quote
Old 09-14-2008, 09:20 PM   #3
burnsauto
burnsauto's Avatar
check the obd port under the dash on the drivers side. that will tell you for sure. Odds are its OBDI
Old 09-14-2008, 09:20 PM   #4
Ben G
Ben G's Avatar
Ben G is an unknown quantity at this point
i know my 96 is obdII
Ben G is offline   Reply With Quote
Old 09-14-2008, 09:34 PM   #5
fatlizzard
fatlizzard's Avatar
The obd port on mine is on the passenger side below and just to the left of the glove box !!
Old 09-14-2008, 09:40 PM   #6
Ithical
Ithical is making a name for him/her selfIthical is making a name for him/her self
95 i believe is obdI, II started from 96.. Not sure but it's what i've heard from others.
Ithical is offline   Reply With Quote
Old 09-14-2008, 09:50 PM   #7
LA_phantom_240
LA_phantom_240's Avatar
Location: Louisiana. LA is for Louisiana. L.A. is Los Angeles.
LA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfection
There is some controversy over which are OBDI and which are OBDII... I think my s14, built in 3/94 is OBDII, but I'm not sure either. It reads correctly with an OBDII code scanner, which I've been told it shouldn't if its OBDI.
Originally Posted by SoSideways View Post
Come on, this isn't Gran Turismo.
Originally Posted by DOOK
your balls are either ballin, or they aren't... no second hand nut sweat can change that.
3/28/09 Buy this stuff!
http://zilvia.net/f/sale-items/24807...-stuff-fs.html
LA_phantom_240 is offline   Reply With Quote
Old 09-14-2008, 10:29 PM   #8
projectRDM
projectRDM's Avatar
It's like the biggest fucking broken record lately.
1995 - OBD plug below glovebox = OBD-I
1996-98 - OBD plug located beside hood release = OBD-II
There is no other way to look at it. Build date means nothing.
FORMERLY R240NA
Old 09-14-2008, 10:40 PM   #9
zipman72
zipman72 is an unknown quantity at this point
My '95 is OBDII.
I Give Up.
zipman72 is offline   Reply With Quote
Old 09-14-2008, 10:41 PM   #10
projectRDM
projectRDM's Avatar
Originally Posted by zipman72 View Post
My '95 is OBDII.
Where is the OBD plug? And is there a carbon canister under the hood?
FORMERLY R240NA
Old 09-14-2008, 10:51 PM   #11
TurboStrong
TurboStrong's Avatar
TurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really nice
obiiiiiiiiiiiiiiiiii 1
TurboStrong is offline   Reply With Quote
Old 09-15-2008, 05:49 AM   #12
LA_phantom_240
Carbon canister would mean OBDI, correct?
Old 09-15-2008, 06:59 AM   #13
burnsauto
burnsauto's Avatar
yessir, canisters are obdI
Old 09-15-2008, 07:03 AM   #14
nzmoman
nzmoman's Avatar
nzmoman is an unknown quantity at this point
its as simple as ^^^ its amazing people don't understand this.
nzmoman is offline   Reply With Quote
Old 09-15-2008, 08:43 AM   #15
98s14inaz
98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection
It's obdI then. Depending on the state they'll just use the sniffer.
-Retired
98s14inaz is offline   Reply With Quote
Old 09-15-2008, 09:12 AM   #16
g6civcx
g6civcx's Avatar
Are you saying that OBD-II cars do not use evaporative charcoal canisters?
Old 09-15-2008, 09:28 AM   #17
projectRDM
projectRDM's Avatar
They use the EVAP canister, located in the rear of the car. It's a completely different type of system, it purges and filters based on solenoid control as well as engine vacuum, and flow is dictated by fuel temperature, ambient temperature, and other factors. The basic charcoal canisters purge all the time based on vacuum only.
If the car has a charcoal canister under the hood, beside the airbox, it's OBD-I.
FORMERLY R240NA
Old 09-15-2008, 09:35 AM   #18
twistedsymphony
twistedsymphony's Avatar
twistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of light
From an emissions enforcement and testing standpoint all 1995s are OBDI and exempt from the plugin test. It doesn't matter what the car is actually equipped with, it wasn't required for 95 model years so they wont enforce it for those model years.
From an actual functional standpoint 1995s manufactured after 9/94 use an OBDII compatible computer. the Port is still on the wrong side but you could pull the computer and put it in a 96 and pass the OBDII test... pre 9/94 ECUs are ACTUAL OBDI computers and are not emissions compatible with newer cars. I've confirmed this personally. (I own an early production 95 and was unable to get a read on an OBDII reader, I know someone running a late period 95 computer in his kouki and with no emissions testing issues)
If you're not sure check your O2 sensor... OBDI cars use a single wire... OBDII cars use 3 wires, the manufacturing date should be stamped right on the chassis info plate, or you could also cross reference the ECU label to determine what car it came from.
HT = 95 240sx MT (KA24DE) (mfg before 10/94) (A18-E07-G90) OBDI Emissions
HU = 95 240sx AT (KA24DE) (mfg before 10/94) (?) OBDI Emissions
3C = 95 240sx MT (KA24DE) (mfg after 9/94) (A18-892-G00) OBDII Emissions
3D = 95 240sx AT (KA24DE) (mfg after 9/94) (?) OBDII Emissions
twistedsymphony is offline   Reply With Quote
Old 09-15-2008, 11:36 AM   #19
LA_phantom_240
I'm guessing you can't use an OBDII computer in an OBDI s14, correct?
Old 09-15-2008, 12:06 PM   #20
twistedsymphony
I'd say there is a good chance it would work in a 9/94 MFG date or newer.
before then... it would probably WORK but throw codes.
You would probably want to at least swap the MAF (I think it might be different, though I could be wrong) and O2 sensor as well.
Old 09-15-2008, 12:26 PM   #21
projectRDM
projectRDM's Avatar
Incorrect. The MAF is the exact same. As far as the O2, the 3wire is just a heated sensor for quicker readings, you can use an OBD-II ECU with the 1wire sensor, you'll just get a code during warmup. The only other difference is the TPS and CTS, they have different plugs but read the same.
You can also go the other way and use an OBD-I ECU in an OBD-II chassis, the 96 cars are a direct plug in, 97-98s require repinning three wires, JWT has a PDF on what's required. You'll also lose the rear O2 sensor since it's a 4wire on 97-98s unless you run an extra wire, but it's not needed anyway for engine operation.
FORMERLY R240NA
Old 09-16-2008, 06:39 PM   #22
LA_phantom_240
What the fuck?!? My s14 is from 3/94, yet it reads correctly with an OBDII code scanner, and has a 3C ECU.
Can someone tell me what's going on? lol.
Old 09-17-2008, 01:46 PM   #23
projectRDM
projectRDM's Avatar
Anything with an OBD plug, I or II, will work. The difference is the actual codes. 1995 cars used manufacturer codes only, while 1996+ they're mandated across all manufacturers. Read through the 1995 FSM, you won't have the same amount of codes, nor do the numbers all match up to 96+ codes. You can pull some codes using a OBD-II scanner on a 1995 model, but not all, and some won't match to what the actual problem is.
FORMERLY R240NA
Old 09-17-2008, 05:01 PM   #24
LA_phantom_240
If my ECU is a 3C, which should be OBDII, will all the codes be OBDII compliant?
I'm calling my car OBDI½ lol. I was built 3/94, which should be OBDI, and yet it has a 3C OBDII ECU. I wouldn't imagine that the ECU had been swapped cause the car has a KA and OBDI harness... But then again...
Old 09-17-2008, 08:50 PM   #25
projectRDM
projectRDM's Avatar
I don't trust those numbers. If you have a 3C ECU all that tells me is your ECU has a big 3C on it. It's still a 1995 model.
FORMERLY R240NA
Old 09-17-2008, 09:04 PM   #26
LA_phantom_240
Is there any way I can tell for sure?
Old 09-17-2008, 11:03 PM   #27
projectRDM
projectRDM's Avatar
Unplug the VSS and drive the car long enough to trip the CEL, then pull up the code. If it's code 114, it's a 1995, OBD-I. If it's a code P0500, it's OBD-II.
FORMERLY R240NA
Old 09-17-2008, 11:15 PM   #28
Mikey88
Mikey88's Avatar
Mikey88 is on a distinguished road
damn all this noise just to figure out obd 1 and 2 haha
Mikey88 is offline   Reply With Quote
Old 09-18-2008, 06:27 AM   #29
LA_phantom_240
Cool... but losing my speedometer temporarily just to find out is suckage lol.
Oh well. It must be done.
Old 09-19-2008, 12:10 PM   #30
Steveohoes
Steveohoes's Avatar
Steveohoes is not welcome here anymoreSteveohoes is not welcome here anymoreSteveohoes is not welcome here anymoreSteveohoes is not welcome here anymoreSteveohoes is not welcome here anymoreSteveohoes is not welcome here anymoreSteveohoes is not welcome here anymoreSteveohoes is not welcome here anymoreSteveohoes is not welcome here anymoreSteveohoes is not welcome here anymoreSteveohoes is not welcome here anymore
I got a ecu out of a automatic s14, 1996.
The ecu says CB, is that ob1 or 2?
Steveohoes is offline   Reply With Quote
