Old 09-21-2008, 11:07 PM   #1
gippy87
gippy87 is making his/her stupidity well-knowngippy87 is making his/her stupidity well-knowngippy87 is making his/her stupidity well-knowngippy87 is making his/her stupidity well-known
Nissan liquid gasket
When i ordered my rebuild kit it came with oem nissan liquid gasket the orange kind. i used it on everythign that the FSM(sr20det) said to apply liquid gasket too. I put oil in the motor for the first time since the rebuild today and looks like the orange liquid gasket is not making for a good seal on the oil pan. Is the orange liquid gasket not oil resistant? Luckily the motor is still out of the car so replacing it with a better oil resistant liquid gasket shouldnt be to bad im just worried about everythign else i used the liquid gasket on such as the oil pump and upper oil pan
gippy87 is offline   Reply With Quote
Old 09-21-2008, 11:18 PM   #2
nissanguy13
nissanguy13's Avatar
nissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant future
Maybe I can't read, but what is the problem and what is the question?
I used the same stuff on my oil pan, valve cover, and other places and never had a problem with it.
Originally Posted by unicoladron;
dick, i had like 4 posi reps in a row and you ruined it
nissanguy13 is offline   Reply With Quote
Old 09-21-2008, 11:21 PM   #3
projectRDM
projectRDM's Avatar
Originally Posted by gippy87 View Post
When i ordered my rebuild kit it came with oem nissan liquid gasket the orange kind. i used it on everythign that the FSM(sr20det) said to apply liquid gasket too. I put oil in the motor for the first time since the rebuild today and looks like the orange liquid gasket is making for a good seal on the oil pan. Is the orange liquid gasket not oil resistant? Luckily the motor is still out of the car so replacing it with a better oil resistant liquid gasket shouldnt be to bad im just worried about everythign else i used the liquid gasket on such as the oil pump and upper oil pan
You didn't apply it right. Either the surfaces weren't cleaned, you used too much, or you didn't use enough. Learn the correct way and redo everything, it's obvious your flaw will be carried on throughout the assembly.
FORMERLY R240NA
Old 09-21-2008, 11:27 PM   #4
gippy87
Sorry meant to say its not appearing to seal allthough I could be wrong i spilled a little bit when pouring it in. I guess ill know in the morning if theres oil all over the place haha. Also the surfaces were very clean i used a new oil pan and the upper oil pan was cleaned by the machine shop. I also applied the liquid gasket as recommended by the fsm. you see in the pic it looks like there is quite a lot but like i said i followed fsm for recommended bead thickness and all that.
Old 09-24-2008, 07:35 PM   #5
0100
0100's Avatar
0100 has a reputation beyond repute0100 has a reputation beyond repute0100 has a reputation beyond repute0100 has a reputation beyond repute0100 has a reputation beyond repute0100 has a reputation beyond repute0100 has a reputation beyond repute0100 has a reputation beyond repute0100 has a reputation beyond repute0100 has a reputation beyond repute0100 has a reputation beyond repute
Is that a Greddy or Freddy?
If it's a Freddy remove and destroy with a BFH.
If it's a Greddy remove liquid gasket and use Hondabond.
TougeHero.com l SilviaV8forums.com
0100 is offline   Reply With Quote
Old 09-24-2008, 07:48 PM   #6
swayray
swayray's Avatar
swayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfection
it must be a freddy mac oil pan... i never had a problem with those orange things either so maybe you did not apply it evenly. Also, did you let it sit and try abit until it gets tacky?
http://www.thenismoshop.com
swayray is offline   Reply With Quote
Old 09-25-2008, 12:51 PM   #7
chituntang
chituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nice
Did you bolt down the oil pan correctly? When I replaced my oil pan, it took me quite some time to make sure if the nuts are bolted down tight enough (did not have a torque wrench). Or you used a freddy pan, where it does not sit flat with the upper oil pan.
chituntang is offline   Reply With Quote
Old 09-28-2008, 11:00 PM   #8
gippy87
Its a greddy oil pan i didnt take any shorcuts on this motor I assume its just the oil i spilled but its really hard to tell. the motor is installed in the car now and im just waiting on a custom downpipe and my oil drain flange to come in so i can do my first start. Im still considering taking the pan off and applying new liquid gasket although i think its fine.
Old 09-29-2008, 06:38 AM   #9
HalveBlue
HalveBlue's Avatar
HalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond repute
First of all, what makes you think the LG isn't sealing properly?
Really, the only thing you need to make sure is that you used the proper amount of gasket in the proper places, as specified by the FSM, and that you torqued the pan down correctly so that the mating surfaces ensure a proper seal.
If you followed the steps in the FSM properly you'll be fine.
HalveBlue is offline   Reply With Quote
Old 09-29-2008, 02:54 PM   #10
gippy87
The liquid gasket looked all wet like oil was seeping through but like I said it was really hard to tell cause I had spilled some earlier. I guess if no one else has had an issue with it then it's probably fine. I had to drain the oil to replace oil drain plug with a magnetic one I'll see what happens when I put oil back in tonight. And I'll use a funnel this time haha
