#1 | ||||||||||||
![]() Join Date: Apr 2004
Fuel economy discussion goes here
Due to protest in the other thread, all posts were copied here for discussion if you so choose.
#2 | ||||||
Originally Posted by CrazyTrance
Mine gets like 17 or so i think. idk my speed sensor hasnt been working properly. David Steele Doesn't mean you were driving for best economy. Quote:
![]() Join Date: May 2006
I thought the BSFC convo was interesting - naturally, when an engine is under conditions that produce peak torque (which for almost all internal combustion piston engines is up in the revs quite a bit), you'll need less fuel to produce the same amount of energy - the problem is that keeping the engine at that 'condition' means losing a bunch of that energy to moving all the reciprocating mass, the friction involved, and to a lesser extent the rotating mass of the driveline.
That's why you get better mileage below your peak torque... mileage is something that is complicated enough that it needs to be tested in the application - go out and drive as "grandma" as possible for a set number of miles, then normal, then "track day" status, and report back.
![]() Join Date: Jun 2007
so basically... what your saying is...
Grow a mullet, date your sister, and drive an f-body to get good gas mileage, right? lol I kid. There are plenty of ways to increase your mpg. Better intake, better spark plugs, new o2 sensors, tune it to run a little lean... a little. And I'd do that on an NA car before I'd to it on a turbo car.
BRAND NEW GReddy PRofec E-01 EBC for sale, Cheap! |
#8 | |
I am growing a mullet though... I'd rather get .5 fewer mpg than running too lean. |
longer gears would be great
i read someone did a 3.2 rear end? is that true, they took the ringland out of a pathfinder front diff or something or a xterra i get 15-17mpg street/highway i got 22mpg once on highway, some street SR20DET S14 NVCS// GT2871R .64 550cc, 255walboro, 50fuel pressure nismo fpr stock s14 VLSD 4.08 stock sr20 s14 tranny
if it aint broken, fix it(95 240/96 sr20) Last edited by bkfill; 09-22-2008 at 10:19 AM.. |
#10 | |
No Nissan R200 ever came with a 3.2. |
#11 | ||
![]() Join Date: Mar 2002
3.2 doesn't exist (for Nissan R200, anyway). I'll be using a 3.692 in my S13 as soon as I can figure out how to change a bearing over without a press. ![]()
#13 | |
It does exist, but not as an OEM option. Offroad Nissan guys get custom ratios made for their R200 diffs, but I don't hang out with that crowd enough to know.
If not let me know and I'll set up the info. $40+shipping. It was cheaper than trying to find a press. |
#14 |
#16 | |
Lower RPM-less fuel burned. So yeah I suppose if you look at it that way... sure it'd help. In a superficial kind of way.
#17 | |
If you're talking about low speed dyno tailpipe testing, then it depends if your engine makes more emissions at lower RPM or not. If yes, then lower ratio will not help. Some state requires certain gears to be used for testing, and if you go too low in gearing your engine will bog. If you're talking about cruising, then maybe yes maybe no. Lower cruising speeds may produce more emissions in ppm, but you're spewing out less nominal count so it may be better. It really depends. Nobody knows. |
#18 |
![]() Join Date: Jul 2007
I should be getting great MPG with a 4.63 ring and pinion than :sarcasm:
with the stock ring and pinion ( 3.08? ) I already am at like 3k going 60-65 ( in 5th ) I need a 6th gear to save gas
#19 | ||
higher number = more engine revs to turn the wheel one time. Stock final drive ratio is 4.08:1 number if gears isn't relevant to engine revs - it's the drive ratios of those gears. 4th gear is almost always 1:1.
#20 |
![]() Join Date: Jan 2008
Location: Amerika24 alabama: Where if your not first..... your last
My LT1 f body just got 15 MPG today and i paid $5.29 a gallon for that tank of gas
![]() And i dont date my sister but a mullet would be nice
#21 |
Tons of torque and long gears plus lower ring and pinion ratio will get you good gas mileage. I usually shift around peak torque on my KA and it gets me pretty good mileage. On the SR I seem to waste more due to the lack of torque and it's boost dependent.
#22 | ||
3:1 Press the button 3 times, and the button lights up for one second. Press the button 180 times and you've got light for a minute. 4:1 Press the button 4 times, and the button lights up for one second. Press the button 240 times and you've got light for a minute. You can see there's a difference of sixty button pushes between the ratios. Consider that as a difference in how much an engine has to work. Let's change the button presses to revs/min (rpm) and increase by a factor of 10. 1800rpm for a minute will get you a mile, or 2400 rpm for a minute will get you a mile. Seeing the difference here? 4.36 or 4.6 gearing makes the engine work harder throughout the range of speeds. Off-the-cuff example (not accurate by any means - just an example). 60mph 4.08:1 (stock) = 3500rpm 4.36:1 (some Silvias) = 3850rpm 4.6x:1 (something) = 4200 rpm 3.69:1 (S15 SpecR) = 3200rpm That's messing only with final drive ratio, not tire/wheel sizing or transmission gearing. As you can see, the engine has to spin more, work harder and burn more gas to do the same amount of work.
