![]() on a s14 manual swap. what can i use from a manual s13. like for say. the tranny.. MC for the tranny.. clutch pedal? and such.. anyway i have a 95 s14 zenki. thanks for the help.
s13 parts that will work on an s14. clutch pedal (but you will need to break the spacers off of the firewall of the s13) the s14 doesnt have spacers on the firewall, they are on the pedal. mater and slave cylinder are the same. s13 hardlines will work, transmition, clutch and flywheel are the same. BUT drive shaft WILL NOT WORK. you will need an s14 drive shaft. abs if your car is abs or non if your car is non abs. also the speed sending unit is different. you can pick up the sending unit, gear and retaining clip for about 125.00 from nissan if you tell them that you work at a shop in your area. hope that this helps good luck.
