Old 10-04-2008, 06:49 PM   #1
KasperSlide
KasperSlide has made poor choicesKasperSlide has made poor choicesKasperSlide has made poor choicesKasperSlide has made poor choicesKasperSlide has made poor choicesKasperSlide has made poor choices
s13>s14 maual trans swap
ok so i swap a manual s13 trans into a 95' auto s14. and as most know the speedo reads double the mph. so to rectify the problem i bought a s14 manual VSS. but it still is reading double the mph. soooooo..... anyone of you crazy kidz know what i can do.
p.s. ive already searched and have pm'ed ppl that have had the same prob with no response nor were there post's answered.
KasperSlide is offline   Reply With Quote
Old 10-04-2008, 07:07 PM   #2
Ben G
Ben G's Avatar
Ben G is an unknown quantity at this point
did you get a manual speed sensor?
Ben G is offline   Reply With Quote
Old 10-04-2008, 07:40 PM   #3
KasperSlide
yep 86 bucks from the part store grrr...... anyone else
Old 10-05-2008, 11:15 AM   #4
KasperSlide
well damn guys i guess if i figure it out ill post for ne one that maybe have this problem in the future
Old 10-05-2008, 11:51 AM   #5
issac
issac's Avatar
issac is just really niceissac is just really niceissac is just really niceissac is just really niceissac is just really niceissac is just really niceissac is just really niceissac is just really nice
I just completed the same swap about 2mos ago. The only thing That I can think of is the pinion gear on the vss. Did your vss come with this already? From what I know Is that the s14 vss into the s13 tranny needs minor modification to work. Is the speed sensor metal or plastic? How do you know for certain that you have an s14 vss?
issac is offline   Reply With Quote
Old 10-05-2008, 06:11 PM   #6
KasperSlide
its a metal sensor with a red plastic wheel. i had to put the old gear on the new vss. but ive been told that the gear only varied for wheels size. im not gunna b/s and say its the right vss cuz you never know what u get from the parts store but i bought a 95' manual vss......would it be possible that i need to buy a 95' auto vss.
im also runing the auto trans ecu
Old 10-05-2008, 06:22 PM   #7
DreamN
DreamN's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
^ I think you got an s13 one. I believe the s14 has a plastic housing.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 10-05-2008, 07:18 PM   #8
projectRDM
projectRDM's Avatar
Bingo. You should have searched.
Aluminum housing with long wire lead = S13
Black plastic housing with direct plug in = S14
There's no way to confuse them unless you're blind and have no fingers.
FORMERLY R240NA
Old 10-05-2008, 07:20 PM   #9
projectRDM
projectRDM's Avatar
This is incorrect. The sensors swap right in, either one, because the tail housing is the exact same from 89-98, on KA, SR, and CA.
FORMERLY R240NA
Old 10-06-2008, 05:46 AM   #10
KasperSlide
yea so i got a aluminum one with a plug. ok well ill be going to the part store. thanks ill let you guys know what happens
Old 10-06-2008, 06:38 PM   #11
issac
issac's Avatar
I bought one from napa auto parts and it was the s13 one. Apparently their info is wrong their computer says that the 1995 m/t vss is the same as s13 (same part number). Be careful and don't get fooled again. I am trying to order the correct one right now. Good luck!
Old 10-06-2008, 10:30 PM   #12
projectRDM
projectRDM's Avatar
FYI, I've scoured several online parts sites and called a few places just out of curiosity, no one makes an aftermarket replacement S14 VSS. They all show to carry one up to 1995 but list the S13 unit. After 1995 there's no application.
Dealer or salvage yard only part.
FORMERLY R240NA
Old 10-09-2008, 10:13 AM   #13
KasperSlide
wow RDM i think thats one of the first times you didnt freak out on me and try to make me butt hurt. ill head to nissan
Old 10-09-2008, 12:58 PM   #14
projectRDM
projectRDM's Avatar
Shall I go off on you then anyway?
Remember the new VSS at the dealer won't have the gear, it's a separate part.
FORMERLY R240NA
Old 10-09-2008, 01:09 PM   #15
WangonwWarrior
Location: Amerika24 alabama: Where if your not first..... your last
WangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant future
And you know the dealer will charge out the ass, i think its around $140 but i cant remember.
WangonwWarrior is offline   Reply With Quote
Old 10-09-2008, 01:13 PM   #16
aoiken3
aoiken3's Avatar
aoiken3 is an unknown quantity at this point
the way i made mine read the right speed was by changing my differential gearing and running really tall tires. this method is pretty getto but it works and gets u better gas mileage.
aoiken3 is offline   Reply With Quote
Old 10-09-2008, 01:20 PM   #17
bigOdom1
bigOdom1's Avatar
bigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfection
hahaha russ you are too much
bigOdom1 is offline   Reply With Quote
Old 10-11-2008, 12:45 PM   #18
issac
issac's Avatar
Kasper. I just received mine last night and finally its the right one.Here's the part #'s
speed sensor 25010-71T00
pinion gear 32743-71T20
ring-lock 32744-71T00
If you need pics I can post them later.
Old 10-17-2008, 09:41 PM   #19
MudRacer
MudRacer's Avatar
MudRacer is an unknown quantity at this point
Anyone has a pic of the S14 Manual VSS? Ive been searching all over.
MudRacer is offline   Reply With Quote
Old 10-17-2008, 10:03 PM   #20
DreamN
DreamN's Avatar
Trader Rating: (54)
Had one lying around so here are some quick shots.
- Jimmy
Wanted:
TBD
For Sale:
TBD
