Old 10-09-2008, 04:46 PM   #1
koolcat
koolcat is making his/her stupidity well-knownkoolcat is making his/her stupidity well-knownkoolcat is making his/her stupidity well-knownkoolcat is making his/her stupidity well-known
Send a message via AIM to koolcat
Rear main seal help...
anyone know from which usdm car is the rear main seal interchangeable for the s13 blacktop? Been searching and only see the 93 - Sentra Ser works for the redtop but that why im asking. I only see it specifically works for the redtop but not to sure if it works for the blacktop. Has anyone use it on the s13 blacktop before? Please let me know asap.
This post clearly said for redtop so iono...
http://zilvia.net/f/tech-talk/110449...nce-guide.html
thanks
koolcat is offline   Reply With Quote
Old 10-09-2008, 06:16 PM   #2
Sileighty_85
Sileighty_85's Avatar
SR Red Top = SR BlackTop
Same Bottom end
So yes the Sentra RMS will work
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 10-09-2008, 06:21 PM   #3
koolcat
Oh thanks man...but hey can i get any from 91-94 sentra ser rms right? Thanks
Old 10-09-2008, 06:22 PM   #4
Sileighty_85
as long as its the SR20DE Model
I believe a KA one works too
後輪駆動車1番
1986 SR86 - 200ish
Old 10-09-2008, 06:59 PM   #5
240sxspeed
240sxspeed's Avatar
240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold240sxspeed is a splendid one to behold
yssir yessir
HOME OF THE LOWBALLERS AND INTERNET THUGZ
240sxspeed is offline   Reply With Quote
Old 10-09-2008, 08:05 PM   #6
projectRDM
projectRDM's Avatar
SR is an SR in RWD configuration. If it fits the redtop bottom end, it has to fit the blacktop.
FORMERLY R240NA
Old 10-10-2008, 12:54 AM   #7
koolcat
thanks guys
Old 10-14-2008, 04:28 PM   #8
koolcat
Hey guys i went ahead and bought the rms from the nissan dealer near my place from a 93 nissan sentra Se r. Here is the picture of it, the Se-r is on the left and the oem sr20det is on the right, it has the same diameter but different thickness. Does it matters? Anyone that bought the rms for the Se-r for their redtop or blacktop, can you guys give me some input on this.
thanks again in advance.
Old 10-15-2008, 08:25 AM   #9
Sileighty_85
im at work so I cant see the pics but as long as the seal is the same diameter and seals it will be fine.
thickness doesnt really matter, it just might make it a little bit tricker to remove it
when you replace it again.
Just dont knock it all the to the back, postion it to where the actual seals lip sits in the middle the the end crank.
後輪駆動車1番
1986 SR86 - 200ish
Old 10-15-2008, 11:54 AM   #10
koolcat
cool thanks man so it sit it half way in...
Old 10-15-2008, 11:55 AM   #11
projectRDM
projectRDM's Avatar
Yes, as long as it's flush against the crank and fits snug in the recess, the thickness isn't a huge concern.
FORMERLY R240NA
