Old 10-12-2008, 03:55 PM   #1
moses
moses is making his/her stupidity well-knownmoses is making his/her stupidity well-knownmoses is making his/her stupidity well-knownmoses is making his/her stupidity well-known
Hey guys i need some ideas
I just took a dremel to my freddy intake manifold for about 4 hours trying to get it smooth and i need to find out a way too clean the inside. i just rinsed it in my tub with hot water and i still dont feel safe enogh to put it back.
any suggestions?
moses is offline   Reply With Quote
Old 10-12-2008, 04:26 PM   #2
Goldeneye9mm
Goldeneye9mm's Avatar
Goldeneye9mm has a spectacular aura aboutGoldeneye9mm has a spectacular aura aboutGoldeneye9mm has a spectacular aura aboutGoldeneye9mm has a spectacular aura aboutGoldeneye9mm has a spectacular aura aboutGoldeneye9mm has a spectacular aura about
Send a message via AIM to Goldeneye9mm
get ahold of someone w/ an air compressor and tape of the 3 holes closest to the throttlebody opening and blow inthe last one w/ like a circular pattern anything that doesn't come out the throttlebody hole will get stuck to the tape then wash it out again
Goldeneye9mm is offline   Reply With Quote
Old 10-12-2008, 04:36 PM   #3
johngriff
johngriff's Avatar
Shot Peen.
[email protected]
Old 10-12-2008, 04:40 PM   #4
projectRDM
projectRDM's Avatar
Hot tank. Carb cleaner. Urine.
FORMERLY R240NA
Old 10-12-2008, 06:21 PM   #5
moses
sounds like a plan thanks guys.
Old 10-13-2008, 06:39 PM   #6
moses
ok i did the pressurize thing with tape and it got a bit more out. The problem is when I go in with my little magnet there are little specs of metal that still come out. I got as much as i could but do you think these little pieces could really hurt my engine?
Old 10-13-2008, 07:12 PM   #7
projectRDM
projectRDM's Avatar
Aluminum isn't magnetic, what all shit are you picking up in there?
FORMERLY R240NA
Old 10-13-2008, 07:29 PM   #8
s13 @ fullboost
s13 @ fullboost's Avatar
s13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfection
Send a message via AIM to s13 @ fullboost
haha that is the best way to go for suree
s13 @ fullboost is offline   Reply With Quote
Old 10-13-2008, 07:43 PM   #9
bejota180sx
bejota180sx's Avatar
bejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura about
are freddy manifold made of aluminum?
if u did the pressure thing i woud recomend while in the hot water get some soap or something like that take a brush or something like the toiler cleaner brush (LOL!) and scrub the inside a bit in case some shavings are sticking to the inside...
bejota180sx is offline   Reply With Quote
Old 10-13-2008, 07:52 PM   #10
Ben G
Ben G's Avatar
Ben G is an unknown quantity at this point
Urine.
defiantly the best way to clean anything
Ben G is offline   Reply With Quote
Old 10-14-2008, 02:54 AM   #11
cotbu
cotbu's Avatar
Urine (tasteless kind), Cold Carb and compressed air.
Old 10-14-2008, 10:18 AM   #12
moses
the maifold is aluminum but i guess it was the stuff i was grinding with. not sure? hopefully i got everything. not much else i could do. guess ill find out when i get done with this turbo upgrade witch is a lot harder for me than everyone says it is.
one more off topicquestion. if my ecu is getting tuned for a z32 mafs, do i still need to program my afc neo to 4in 2out or whatever it is to read a z32 maf or do i just let it be?
Old 10-15-2008, 08:35 PM   #13
mrmephistopheles
mrmephistopheles's Avatar
You know.... I'm just not going to ask...
Originally Posted by PHLIP
Old 10-15-2008, 08:43 PM   #14
Sileighty_85
Sileighty_85's Avatar
Garden Hose with sprayer nozzle, or power washer (a bit extreme)
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
