plz school me in offset
Umm yeah, i just did a search on it, and i found alot of stuff talking about offset, but nothing really telling me what it all means. I was just wondering if anyone could tell me the basics of wheel offset, if it matters i have a 91 240sx. I was looking into getting volk le37t's in 17x8.5 maybe 18's for brake clearance.
But officer the sign said 85 |
hope this helps
http://www.tirerack.com/wheels/tech/offset.htm |
#5 | |
![]() Join Date: May 2002
ITS ABOUT THE DRIVER NOT THE WHEELS!!!!!!! a good driver can drift fast and keep traction with ANY wheels depends on the car's setup, the tire choices and how it matches the wheels your question is SO vague its ridiculous. there are many answers all of which are applicable. |
http://autos.groups.yahoo.com/group/240sx/
Found this topic on this yahoo group..... Those offsets you listed seem a little high. If you plan on doing Z-brakes or coilovers there¡Çs no way they¡Çll fit without a spacer. This was taken from a post on Freshalloy by Alex Chang, it¡Çs just to use as a reference but it lists some good stuff. Wheels/hubs -Clearance of wheels for Z32 brake upgrade is entirely dependent on wheel spoke AND wheel design, NOT on offset of wheel. -Wheel width/offset needed for clearance of coilovers is as follows (disregarding brake clearance): ** 6" +54 or lower ** 6.5" +45 or lower ** 7" +40 or lower ** 7.5" +34 or lower ** 8" +30 or lower ** 8.5" +24 or lower ** 9" +20 or lower ** Please note that this does not take into account variations in offset calculation by manufacturer, or tire sidewall bulge. This list also does not take into account differences in design of coilovers (esp. lower brackets on coilover kits which can cause changes in wheel clearance issues). This list also only applies to the FRONT WHEELS and is intended as a GUIDE for reference. -The LARGEST wheels that will fit the front of a S13/14 with stock fenders is 9" wide. The rear can take up to 10.5" wide with a very specific offset AND must dial in negative camber. To fit large wheels one must use negative camber to ensure proper fender clearance. Also check the freshalloy forums, http://forums.freshalloy.com/ubbthre...eads.php?Cat=, look in the 240 basic and advanced forums, wheels/offset/tires are discussed several times daily. So if you can¡Çt find what you¡Çre looking for you aren¡Çt looking hard enough. One more thing, the main thing when picking wheels and tires is deciding what you want out of them. Are you going to run coilovers, get Z brakes? What size do you want, what width? What are you going to be doing with the car, is it for track, autocross, drift, show? Those all play into it. Then you¡Çll have to pick a suitable offset and tire size depending on what you decided. Just do it right the first time and you¡Çll be happy, don¡Çt go with a high offset wheel because it¡Çs cheap and looks alright and then be disappointed when you can¡Çt get coilovers/z brakes on there without replacing the studs or a bolt on spacer. And think about how the wheel is actually going to look in the wheel well, sure it may fill the gap with suspension mods, but it¡Çs not going to look good if it¡Çs sunken in. Most people want the wheel to be flush and that also involves some thinking. Tim -----Original Message----- From: robinlow [mailto:robinlow@y...] Sent: Thursday, April 10, 2003 10:36 AM To: [email protected] Subject: [240sx] Re: Tires & Rims I would suggest that 17" probably gives good performance for its price. These are sizes I tired and they fit my S14. 225/40/18 +40 front 255/35/18 +42 rear 225/45/17 +32 front 255/40/17 +38 rear 225/50/16 +35 front 255/45/16 +40 rear I damaged my 18" SSR competition rims in 99 and still have yet replaced them. I would suggest getting a good set of rims and tires and not go for cheap ones as a light rims like Volk Racing, SSR, OZ Racing really make a big difference in performance in the car. Unless you are just going for a car show, then you need chrome 19" 255 tires in front and 285 in the rear with flared out fenders and a wide body kit!! But you car probably will not accelerate well!! haha Robin |
#7 | |
#8 | |
#10 | |
drifting is ALL ABOUT traction there's a reason Taniguchi uses Semi-slicks for drifting. hmm. last time i check, semi slicks arent what most people think of when they buy tires specifically for drifting drifting is about traction and controlling it. people who use crap tires when drifting get crappy response. good tires grip well and you control and break traction when needed. you may not keep the traction CONSTANT during drifting but you always are constantly breaking controlling and using the tires traction to keep you on course, in control and your angles and speed TRACTION is the MOST important part of drifting, especially when it comes to high speeds go look at japan drifters, they are using Azenis (sport and st115s), FM901s, Neovas, etc. STICKY tires. stuff most wouldnt consider at all except for grip. 2. your questoin is SO vague is ridiculous. what width? what do you need to clear? do you want flush? how much camber do you use? do you want to be flush w/ the camber or at 0 camber? what tire size do you want with the wheels? stretched, straight, max tire size for wheel, or slightly buldged? your question as i said has TONS of replies. so STFU before you TRY and school me on drifting and such. |
#11 | |
and to answer some of your variables. i wrote up top that i was looking into volk le37t's 17x8.5 or 18s, and umm yeah i want them flush, and i have eibach sportlines with kyb's, i was looking at 0 to very slight negative camber in the back, and im not sure about the front yet
#14 | |
i dont know all the terms and such, but the way your car's balance is from a LOOOOW offset (wider stance) and a high offset im sure someone like AKA and sykikchimp can explain further (among other members) but offset affects handling quite a lot even from me going from a -3 offset on a 7" to a +40 on a 7" is a huge handling difference (even with same tires and same tire size) |
#15 | |
run like a -1. to a -1.25 in back and maybe a -1.5 in front gives better response and you can corner a bit harder. at least that's been my expirience, car is more stable remember camber DOES NOT kill tires (as long as the camber is not crazy like -4) toe DOES. if you are doing grip, then 18s SUCK stick w/ a 16 or 17s MAX depending on your power (KA or SR?) and skill 18s are for bling. |
#16 | |
#17 |
sr with too much crap on it, i havent put it on the dyno but injen cai, apexi n1, z32 mafs, blitz downpipe, greddy intake manifold, greddy pulley set, fidanza flywheel,apexisafc, apexi avcr at 1.1 bar boost, t28 turbo
#18 | |
Retired General
#19 |
cool
but one thing width DOES NOT affect brake choices. wheel design does offset does not affect brake choices for the most part too, depends heavily on spoke design (though offset does play a VERY large roll, spoke design is still #1 priority to focus on first) now unless your going with something like AP racing. the wheel size (15, 16 17) doesnt matter, z32tt fit under most 15s and up. u still never siad how flush youwant it too. offset affects that so much. and drifting you dont lose traction, you control it. its not getting lost or going away, its getting controlled. its car control. |
#20 | |
everyone's preference is different. that worked for me back in the day. after more tinkering i know what i want trial and error. |
#21 |
![]() Join Date: Jan 2003
i don't have a FSM, but i'm pretty sure 240sx doesn't come stock with 0 degree camber front or rear, it compromises handling. Good if you want to lay down the traction drag racing, but for turning 0 camber is not good at all. Unless you have adjustable rear upper arms you can't change rear camber, and your camber will be stuck. (you get slightly more negative camber when lowered).
with your susepsnion, i wouldn't worry about camber at the rear. volk 17x8.5 will clear z brakes fine. as for offset, depends on what style you like it. what kind of flushness? anything from +30 to +20 would look flush on the rear of a s14 (with 8.5") as for front, i don't remember... lol, I suggest 17x9 +22 all around... it seems to be the best offset offered for TE37, 17x8.5 +30 will work too, but the rears might look slightly sunken (not a problem if you're not overly concerned with flushness).
Paul Black and Red ![]() |
#22 | |
#23 | |
![]() Join Date: Mar 2002
i think this is an interesting subject that we never really talked about... i made some quick drawing ![]() lets say the car for the 3 figures are the same (its a blue 240sx) 1) lets say the wheel base length is constant for all three for easier understanding lets make the length = L the width = L/3 these are for the first picture ratio = L / (L/3) = 3 <-- lets say this is the stock ratio 2) width = L/4 (sunken wheels/high offset) lets calculate the ratio between the length and the width ratio = L / (L/4) = 4 <-- higher than the stock ratio this setup will create a longer wheelbase-like environment to the car... since the stance is narrower from my common knowledge (im could be wrong), longer wheelbase will create a more stable ride, yet a bit sluggish and not that responsive (handling wise) 3) width = L/2 (wheels stick out a bit / low offset) wider stance ratio = L / (L/2) = 2 <-- lower than the stock ratio this setup will create a shorter wheelbase-like environment to the car.. wider stance with same wheelbase length. shorter wheelbase will create a more responsive handlings.. yet its not as stable as number 2.. but you eliminate some of the sluggishness feeling to the handling of the car im might be wrong because i observe this issue based on my engineering knowledge.. but then again.. im not doing so well in college.. im sorry if this is hard to understand feel free to fix my wrong perspective (if im wrong) or maybe elaborate more (if im somewhat correct)
![]() ==>>TGL GARAGE<<==.. RIP! S13 coupe KA-T @ 0.5 Bar = SOLD! A31 Cefiro + SR = Current |
#24 |
i know what you mean by that flush look
mine is -4 degrees camber in the rear and -3.5 in front SUPER flush hehehe pruto's response is great my advice, if you want SUPER flush you buy a wheel that you know will stick out some (like a 17x9 +15-like nitekids has). then you 'fix' that with camber and roll your fenders to make it PERFECTLY flush that's the best bet since you have s13, go 17x9 all around ![]() 17x9 +22 to +15 (lowest you should go) all around or so w/ about -3 degrees camber is super flush (MUST ROLL FENDERS-NO WAY AROUND IT) |
#25 | |
#27 | |
yeah i forgot about that too DEFINATELY need 5 lug for some SERIOUS 17/18s that are SUPER flush!! im 5 lug thinking one day model 5s SP1 TE37 probably bronze model 5s always like that. and after i get my car painted, i'll go that route. ![]() |
#30 |
Some other things to consider with wheel offset in regards to handling...
1. Scrub radius. This describes the difference in position between the imaginary point where the steering axis intersects the road surface, and the center of the tire's contact patch. Lower offset wheels increase the scrub radius. Stock scrub radius is about zero. A little positive scrub radius is a good thing in a RWD car. In FWD cars they try to get zero or negative for stability under acceleration. In RWD cars this isn't a problem. Adding just a bit (say, going from +40 to +30 offset) increases feedback to the driver regarding front wheel traction. Excessive scrub radius leads to bumpsteer, however. Just what is excessive is up to you. 2. Wheel rate. This is the effective spring rate at the wheel, which is different from the rate of the spring itself because of the lever effect of the suspension. Moving the wheel further out makes the lever longer and reduces the wheel rate... it actually decreases the effective stiffness of the suspension! |
