Old 11-18-2008, 01:12 AM   #1
sicwitit11
sicwitit11's Avatar
sicwitit11 is an unknown quantity at this point
Help! My coilovers rubbing rim!
i have 18x8.5 xxr 962s in the front of my 91 s13. my front left rim is rubbing the spring on my new godspeed coilover setup.. i am already using the biggest possible spacer before i run out of thread on the wheel studs.(not sure what size spacer) im not sure what to do next? will a alighment fix anything? it does pull to the right. im kinda new at zilvia. any help would be appreciated.
thanks
sicwitit11 is offline   Reply With Quote
Old 11-18-2008, 01:16 AM   #2
sicwitit11
sicwitit11's Avatar
o ya my tire size is 225 40 18
Old 11-18-2008, 01:19 AM   #3
karl wasabi
karl wasabi's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
Is the rim or tire rubbing? If it's the rim, get better offset wheels. haha. Or a bigger spacer (bolt on). Changing camber won't do anything for the front.
karl wasabi is offline   Reply With Quote
Old 11-18-2008, 01:25 AM   #4
sicwitit11
sicwitit11's Avatar
its actually rubbing the rim itself but its not constant only if i make hard turns or i hit bumps in the road. im confused doesnt everybody run 18s with coilovers?
Old 11-18-2008, 01:28 AM   #5
codunc
codunc's Avatar
codunc is making a name for him/her selfcodunc is making a name for him/her self
it should never change.. either it hits or it doesn't. are you sure you're not rubbing somewhere else?
codunc is offline   Reply With Quote
Old 11-18-2008, 01:30 AM   #6
Addicted2Kouki
Addicted2Kouki's Avatar
Addicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfection
you have 18x8.5 sportmaxes [xxr's] probably with a 35mm offset.
IT WILL RUB.
get spacers.
or buy rims that actually fit.
Originally Posted by coreansurfer View Post
zenki's are for poors and lames
with the exception of norm who is big ballin
FS:CUSCO,GREDDY,KA-Tparts
Addicted2Kouki is offline   Reply With Quote
Old 11-18-2008, 01:32 AM   #7
sicwitit11
sicwitit11's Avatar
that makes sense... but it sounds like metal to metal and thats the only place... and i was having fitmint issues when i did the install. im going to get a alignment 2marrow and see if that does anything. it pulls hard to the right.
Old 11-18-2008, 01:33 AM   #8
sicwitit11
sicwitit11's Avatar
i am running the largest spacer i could fit. any bigger i cant put the lugnuts on.
Old 11-18-2008, 01:35 AM   #9
s13boy89
s13boy89's Avatar
s13boy89 is on a distinguished road
Send a message via AIM to s13boy89
akignment wont do anything for that get a 15 mil spacer
I have kids running around here I dont want to use an xxr as a coffe table
s13boy89 is offline   Reply With Quote
Old 11-18-2008, 01:35 AM   #10
all show no go
all show no go's Avatar
all show no go has a brilliant futureall show no go has a brilliant futureall show no go has a brilliant futureall show no go has a brilliant futureall show no go has a brilliant futureall show no go has a brilliant futureall show no go has a brilliant futureall show no go has a brilliant futureall show no go has a brilliant futureall show no go has a brilliant futureall show no go has a brilliant future
Get these kind of spacers.
all show no go is offline   Reply With Quote
Old 11-18-2008, 01:35 AM   #11
codunc
codunc's Avatar
you do know there are bolt on spacers right?
Old 11-18-2008, 01:36 AM   #12
sicwitit11
sicwitit11's Avatar
um i heard of them... how do those work?
Old 11-18-2008, 01:39 AM   #13
codunc
codunc's Avatar
Pretty simple man. courtesy of powered by max
Old 11-18-2008, 01:41 AM   #14
sicwitit11
sicwitit11's Avatar
oo ic.. thanks i will look into those. they make them for the 5 lug conversion 2 right?
Old 11-18-2008, 01:42 AM   #15
sicwitit11
sicwitit11's Avatar
haha nevermind just saw the 1st pic...
thanks guys
Old 11-18-2008, 02:35 AM   #16
karl wasabi
Trader Rating: (41)
haha. I've heard of those. But then you would need to get 5 lug wheels. hehe. And then in that case, you should get better sized wheels so you don't need spacers. lolz.
Get a bolt on 15mm or larger spacer. It should clear the coilover. Are you sure you aren't rubbing your fenders?
Old 11-18-2008, 11:10 AM   #17
sicwitit11
sicwitit11's Avatar
haha. they are 5 lug wheels if i knew this would be a issue i would of bought different rims way bback then. i rolled the fenders so it doesn hit there. but left tire does hit the inside fender wall in the front when i turn hard right
Old 11-20-2008, 08:16 PM   #18
uberdrifterx
uberdrifterx is an unknown quantity at this point
hey i hade the same problem i have 17x9 sportmaxs on mine and it was rubbing the coilovers to i got a 10mm spacers from (orilly auto parts) and the bolts that hold the coil overs on the hub the top one on my ksports was slotted so i moved it out and it fixed it check that when u get the alingment done :>
uberdrifterx is offline   Reply With Quote
Old 11-21-2008, 09:58 AM   #19
Grimsta
Grimsta's Avatar
Grimsta is an unknown quantity at this point
35mm offset Sportmax wheels interfere with coilovers. If running Sportmax either get a lower offset or a big spacer. I've had to deal with this before alot
Grimsta is offline   Reply With Quote
Old 11-21-2008, 07:17 PM   #20
240!
240! has much to be proud of240! has much to be proud of240! has much to be proud of240! has much to be proud of240! has much to be proud of240! has much to be proud of240! has much to be proud of240! has much to be proud of240! has much to be proud of240! has much to be proud of240! has much to be proud of
extended studs and bigger spacers should fix the problem...
240! is offline   Reply With Quote
Old 11-22-2008, 05:06 AM   #21
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Hahaha...this thread is full of fail...thanks for the laugh in iraq...
CLICK HERE!!!
Old 03-24-2009, 01:55 AM   #22
gotspins13
gotspins13's Avatar
gotspins13 is an unknown quantity at this point
Send a message via Yahoo to gotspins13
haha just what i was thinking and also
come home soon btw
perfectly said! FJ20ET 16 valve - the holy grail of Nissan engines
gotspins13 is offline   Reply With Quote
Old 03-24-2009, 01:57 AM   #23
SoCal-s130
Why would you bump this thread to say that. You're an idiot.
Old 03-24-2009, 10:32 AM   #24
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Look at his reg date, maybe he hasn't signed on since he registered so EVERY thread is new to him.
18s, coilovers, rub, spacers, sportmax
