Old 11-18-2008, 10:59 PM   #1
jeb
jeb's Avatar
jeb is an unknown quantity at this point
s13 thumping sound when breaking
i have been constantly working out kinks on my car since i did the swap an i think i have finally just about got them all. but now when i hit the brakes it makes an thumping sound from my rear end that kinda sounds like the diff is trying lock up but i dont see why hitting the brakes would do that. when i am driving tho its fine. any ideas what this could be?
jeb is offline   Reply With Quote
Old 11-18-2008, 11:02 PM   #2
GSXRJJordan
GSXRJJordan's Avatar
speed-dependent? brake-pressure dependent? what happens in reverse?
Could be a driveshaft issue, could be a diff issue, could be a brake issue.
Most likely it has to do with your brakes/wheels - check the torque on your wheel lugs first (cause it's easy) and if you can easily get the car up make sure the nuts on the driveshaft/diff bolts are solid. What changes the sound? Braking? Speed?
Old 11-18-2008, 11:09 PM   #3
allntrlundrgrnd
allntrlundrgrnd's Avatar
warped rotors? can you feel it?
Old 11-18-2008, 11:18 PM   #4
jeb
jeb's Avatar
i only feel it when im brakeing or coming to a stop. its fine in reverse an taking off.i checked the tires an they seem fine.i will take a better look at things in the morning when i can see better but im trying to trouble shoot it early. how could i find out if its the diff?
Old 11-18-2008, 11:21 PM   #5
jeb
jeb's Avatar
also if it was warped rotors wouldnt i feel it all the time?
Old 11-19-2008, 06:59 AM   #6
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Constant thumping or just a thump or two and then goes away. If its just a thump, im thinking subframe bushing.
CLICK HERE!!!
Old 11-19-2008, 07:06 AM   #7
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
perhaps worn driveshaft u-joints?
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 11-19-2008, 08:03 AM   #8
jeb
jeb's Avatar
its constant the whole time the brake is being used
Old 11-19-2008, 08:13 AM   #9
Sileighty_85
Sileighty_85's Avatar
worn subframe bushings or loose diff mounting bolts?
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 11-19-2008, 11:01 AM   #10
GSXRJJordan
If it's only braking dependent, get your rotors turned (and replace the pads if you haven't already), break them in properly, and re-evaluate. Could definitely be warped rear rotors, although most of the time people warp the fronts, not the rears.
Old 11-19-2008, 03:02 PM   #11
looking4-240
looking4-240's Avatar
looking4-240 is an unknown quantity at this point
worn subframe bushings is possible. but it usually happens when you let off the gas period.....
looking4-240 is offline   Reply With Quote
