Old 11-26-2008, 07:18 PM   #1
TurboStrong
TurboStrong's Avatar
TurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really nice
frakean bolt
well me and my friend are doing my 5 lug and we are trying to put on the knukle on the front but we cant tighten the nut???
we tried clamps and we are using a torque wrench too but it does not thread in, anyone got this problem too?
TurboStrong is offline   Reply With Quote
Old 11-26-2008, 07:21 PM   #2
sidewayz240
sidewayz240's Avatar
sidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nice
stripped???
-Trevor
sidewayz240 is offline   Reply With Quote
Old 11-26-2008, 07:51 PM   #3
georgesal
georgesal's Avatar
georgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to behold
make sure the thread on the spindle is still good alot of time the first thread gets damaged if so use a tiny file to repair it
georgesal is offline   Reply With Quote
Old 11-26-2008, 08:14 PM   #4
TurboStrong
well one threaded in but it stopped there im using 125 psi on it to turn it but nothing??
i even jacked it from the bottom to help but nothing?
Old 11-26-2008, 11:13 PM   #5
JRas
JRas's Avatar
JRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfection
Send a message via AIM to JRas
may help if you upload some pictures
JRas is offline   Reply With Quote
Old 11-26-2008, 11:17 PM   #6
codunc
codunc's Avatar
codunc is making a name for him/her selfcodunc is making a name for him/her self
So your ball joint is spinning freely and not allowing the nut to tighten, correct?
codunc is offline   Reply With Quote
Old 11-26-2008, 11:25 PM   #7
TurboStrong
yes sir i tried clamps but no work it threaded like 65% in but thats it i tried and tried but nothing.
the autozone sales this like holder thing to hold the ball joint but its for heavy duty trucks and they said it might break it?
Old 11-26-2008, 11:39 PM   #8
Def
That's a good sign your balljoint is beyond thrashed. They only spin easily in the joint when they are way beyond the wear specification.
If it doesn't stay still with that side jacked up with the suspension putting weight(force) on it, then you're screwed. Best bet is to replace the balljoint at that point.
Old 11-27-2008, 12:02 AM   #9
TurboStrong
he boot is brand new the bolt is too. i have a hatch with a thrashed boot like its inn two pieces the grease is coming out of it and it threads in??
Old 11-27-2008, 12:08 AM   #10
slidewaysmn
slidewaysmn's Avatar
slidewaysmn is just really niceslidewaysmn is just really niceslidewaysmn is just really niceslidewaysmn is just really niceslidewaysmn is just really niceslidewaysmn is just really niceslidewaysmn is just really niceslidewaysmn is just really niceslidewaysmn is just really nice
Sounds like you are crossthreading it..and the vise grip isnt holding the ball joint good enough
'95 Zenki
'85 Cressida
slidewaysmn is offline   Reply With Quote
Old 11-27-2008, 12:20 AM   #11
TurboStrong
i used c clamps.would vice grips be better?
i tried the weight of the car cuz i jacked it from the ball joint and it went in alot but not all the way but it took like 30 min to go in.
Old 11-27-2008, 12:57 AM   #12
codunc
codunc's Avatar
sounds like you need to replace the ball joint. they're not that expensive
Old 11-27-2008, 10:26 AM   #13
Def
If your boot has been torn open the ball joint is surely toast, replace it and your car will drive better and you'll actually be able to torque the bolt.
Old 11-27-2008, 10:42 AM   #14
s13boy89
s13boy89's Avatar
s13boy89 is on a distinguished road
Send a message via AIM to s13boy89
i think he says he has a good ball joint just the castle nut wont screw in best be take it off check the threads if there good try by hand. if it still persists pull it off again and get a tap and dye set to clean the threads
I have kids running around here I dont want to use an xxr as a coffe table
s13boy89 is offline   Reply With Quote
Old 11-27-2008, 02:53 PM   #15
Def
Well, I don't think anybody is sure what he's saying since he's typing jibberish, but it's pretty common for really clapped out ball joints to rotate too freely and not allow proper torque to be put on the ball joint nut.
Old 11-27-2008, 03:05 PM   #16
TurboStrong
s13boy89 u got it thanks!!!!!!!!!!!!!!!!!!
thats what ive been trying to say.
i have a brand new boot and ball joint but that shit wont spin in.haha
Old 11-27-2008, 03:33 PM   #17
importdude
importdude's Avatar
importdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond repute
Send a message via AIM to importdude
check the threads on the balljoint and also check the castle nut sometimes its damage inside of them
importdude is offline   Reply With Quote
Old 11-27-2008, 03:39 PM   #18
TurboStrong
ill check that out.
but i've also heard that this happens to a ot of people as well???
Old 11-27-2008, 03:47 PM   #19
Def
I've never had a problem installing the castle nut on a new balljoint. I can't even think of anything you'd do to it before installing the nut that would damage the threads.
Old 11-27-2008, 03:55 PM   #20
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
I disagree. While it can be a sign of a worn balljoint, there are certainly situations where even brand new joints can spin 'in themselves', not allowing it to tighten down.
To the OP: Try jackup up 'against' the lower control a smidge to get some pressure on it, then tighten it down.
Old 11-27-2008, 04:03 PM   #21
TurboStrong
ya i tried that it tightened like 65% in but it dosent wanna go anymore?
Old 11-27-2008, 04:06 PM   #22
TurboStrong
i checked the threading and its fine.
Old 05-02-2012, 09:39 AM   #23
shamoney27
shamoney27 is an unknown quantity at this point
Send a message via AIM to shamoney27
Does anyone no where I can get that castle nut from?... AutoZone nor Strauss has it
Driftin not a hobby it my lif3
Parting out sr20
shamoney27 is offline   Reply With Quote
Old 05-02-2012, 09:51 AM   #24
badbob2121
badbob2121's Avatar
badbob2121 is an unknown quantity at this point
1. http://zilvia.net/f/chat/297481-smal...reads-353.html
2. Products | Fastenal
3.
FOLLOW ME ON INSTAGRAM = BOBBY_LS13
badbob2121 is offline   Reply With Quote
Old 05-02-2012, 09:57 AM   #25
ixfxi
Guest
Posts: n/a
hang yourself
its a wonder why this thread was even created, back in 2008
Old 05-02-2012, 10:16 AM   #26
shamoney27
I can't order something if i have no info on it...i only have the nut...i did search thethrew google and this is the closest i can find to what i need...the dealership no help
Parting out sr20
Old 05-02-2012, 12:20 PM   #27
kyle_s13
kyle_s13's Avatar
kyle_s13 is an unknown quantity at this point
I have one, 50 shipped to your door. haha
fastenal ftw.
kyle_s13 is offline   Reply With Quote
