Old 12-02-2008, 01:50 PM   #1
SLYDNBY
SLYDNBY's Avatar
SLYDNBY is an unknown quantity at this point
s14 Ka-t and tuning?
so im thinking about boosting my ka motor rather than doin a swap what is a down fall of some of these turbo kits i find on ebay? i am somone who believes u get what u pay for but for example look at this kit for $860 eBay Motors: Turbo kit 89 90 91 92 93 94 240SX S13 KA24DE Top Mount (item 380086525539 end time Dec-04-08 11:27:40 PST)
what could be wrong with that exept of course any tuning equip. so i would like some info from people that have tried these kits i have many fabricators around me that will help with any of that shit if something needs relocated or removed but i just would lik some imput thank you and also any one that has ka-t what do u use or would suggest to use for tuning thank u
SLYDNBY is offline   Reply With Quote
Old 12-02-2008, 02:11 PM   #2
Icy13
Icy13's Avatar
Icy13 will become famous soon enoughIcy13 will become famous soon enoughIcy13 will become famous soon enoughIcy13 will become famous soon enough
www.ka-t.org
wealth of good info, however quick reply: the piping is generally not bad for anything that will not be pushed to the limits (basically, if you aren't looking for much more than 300, maybe 350, you should be good). However, the turbos are generally accepted to be crap. Buy a name brand turbo (Garrett, Turbonetics, HKS). A used t25 from a sr20 or various other applications would be 300-500 and should be much better than some badly machined POS (not that that one necc is, but it may be and therefore it is better to err on the side of a name brand that has some gurantee that its products will be trustworthy).
To all the ebay defenders, yes, it is completely possible to build a car that runs on ebay turbos for "over a year, man" and everyone has a friend who has done it. However, everyone also loves seeing the damage pictures of ebay moving parts.
So: get yourself the kit for the piping if you want, acknowledge that the turbo will essentially be a throw away (no one is going to buy it) and get yourself a name brand BOV and wastegate to protect your namebrand turbo (worth every penny).
Oh, and get your ass over to the link above (ka-t.org)
Icy13 is offline   Reply With Quote
Old 12-02-2008, 02:22 PM   #3
jmac636
jmac636's Avatar
jmac636 is an unknown quantity at this point
Wow, that kit is POS! Your probably going to get flamed for asking something that has been covered a million times. I'm no flammer I just don't want you to buy something that is no doubt not worth the money. Just piece your kit together from the forums. Their are alot of good used parts on here and other forums.(ka-t.org,240sxforums.com,and fresh alloy.) I just finished my garrett bottom mount t25 setup on 6lbs of boost and I am totally happy with my Ka-t. It starts boosting around 2500 rpms and pulls pretty damn hard. And for tuning at least get a pretuned ecu they work just fine and will save your engine. I am running a Jwt ecu that was bought used locally for $300 off Houston240sx.com. Good luck!
S14 Turbo LS1/t56 http://www.playloudclothing.com/
jmac636 is offline   Reply With Quote
Old 12-02-2008, 02:24 PM   #4
s13.5guy
s13.5guy's Avatar
s13.5guy is an unknown quantity at this point
Hello!
I do not recommend Ebay turbo kits for a KA. As I am a proud owner of a fully rebuild KA going turbo in less then 200 miles, let me share some advice.
What power are you looking for in your KA? What purpose? Daily/drift? Is your engine a DE? When you turbo a KA, you have to be careful how you do it. Too many peole slap on a turbo and call it good. But then their engine blows are something and they get upset and say KA-Ts are not good. I beg to differ.
If you are going to turbo your KA, I HIGHLY recommend a full rebuild with performance parts. Here is where I got mine. Automoto Sports Copyright&copy AMS 2006
Then I recommend some Brian Crower cams. 264 should be fine. That way you dont need to change out springs and such.
550 injectors
255 walbro pump
Front Mount and piping
You cant boost a tired engine and expect it to work really well, hence the rebuild kit. Once this is obtained, then decide on what turbo you want. For a good power range and to make good use of the rebuilt engine, I recommend a GT3071R. Some people say go t4, but to each their own. My reasoning with the 3071r is that you will have PLENTY of power and not harm your engine. The turbo is your choice, but i am merely offering suggestions.
Then I recommend a ROM tuned ecu, tuned for you exact set up.
You can visit KA-T.org for some GREAT info as well buddy.
Time is fleeting and I must go, however, if you have any questions, or if you want more info, please feel free to PM me
Here is my s13.5 thread to where you can see my engine and what has been done to it.
http://zilvia.net/f/chat/223459-my-r...-5-thread.html
I am both Kami Dori and s13.5guy in this thread. Account changed cause I shouldnt have been posting under a buddies shops name.
Adam
s13.5guy is offline   Reply With Quote
Old 12-02-2008, 02:26 PM   #5
NemeGuero
No more nissan.
NemeGuero's Avatar
I'm gonna check out this Calum ECU.
Old 12-02-2008, 02:32 PM   #6
jmac636
jmac636's Avatar
Actually, Sr t25 can be bought for $100 to $200 all day long used. I picked mine up for 150 and it is in great cond. It has normal shaft play. No smoke at all. Take your time searching but first figure out your goals.
Old 12-02-2008, 02:33 PM   #7
EDT007
EDT007's Avatar
EDT007 is an unknown quantity at this point
I'm currently running KA-T. Tuning is all dependent on what your HP/boost level is. If you plan on running let's say maybe 6psi on a T3/T4OE (what I'm currenly running) you can get away with running a FMU. I've heard that you can go as high as 8psi on that turbo without needing any sort of fuel management past the FMU. As for the injectors they would def. need to be upgraded. At the very least you should use some SR20 stocks. The stock fuel pump should be good up to about ~ 8psi. As mentioned you should def. check out ka-t.org. There's a lot of good information and plenty of ppl that are willing to help. When it comes to turn up the boost..OBD1 conversion harness and NisTune FTW!!!
EDT007 is offline   Reply With Quote
Old 12-02-2008, 03:08 PM   #8
NemeGuero
No more nissan.
NemeGuero's Avatar
NEVER use an FMU.
Old 12-02-2008, 03:21 PM   #9
vvtisupra
vvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond repute
Send a message via AIM to vvtisupra
aem ems hands down.
35 psi on a 11:1 compression KA-T with a GT3071 turbo
you can't beat it
If you are in so cal I know the perfect person and place to dyno. Price is alittle steep but you'd be guaranteed happy.
http://www.fuckdrama.com/
vvtisupra is offline   Reply With Quote
Old 12-02-2008, 04:42 PM   #10
NemeGuero
No more nissan.
NemeGuero's Avatar
Mmmm... I love places like that.
hahahah
Old 12-02-2008, 05:04 PM   #11
unlegendary
unlegendary is a well-known jackass
there is a sticky on this...search button is also your friend.
Full Time Student for Life
unlegendary is offline   Reply With Quote
Old 12-02-2008, 08:36 PM   #12
SLYDNBY
SLYDNBY's Avatar
yeah im not going for a high horse motor on this i just want anywhere between 300 to 400 in my town if ur not 800 hp plus u aint shit i just want it so i can have fun with it and enjoy it myself plus there is nothing like wakin up in the morning getting in ur car on a nice ass summer day and just hearing the turbo scream all the way down the road god i fuckin hate winter anyways yup thats my goal and i appreciate everyones help on here
