Old 12-01-2008, 02:22 PM   #1
MrChow
MrChow's Avatar
MrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant future
Send a message via AIM to MrChow
Heater isn't work. Brings from outside
I've searched and I know this has been posted.
I have a 95' S14. I read something about a cable that turns on the heater. I search and looked in the FSM and couldn't find anything about it.
Can anyone help me on this?? I have no idea what to look for.
Also I heard from a friend that I should flush my radiator since it's over 2 1/2 years old. Or could there be anything else that would cause this problem??
Originally Posted by TheSquidd View Post
Are you the guys that buy your KSports and just turn the dampening knob to 32?
"It's stiff and hurts my livers! I'M A HANDLING GOD!"
WTT: 2 way for 1.5 way LSD
MrChow is offline   Reply With Quote
Old 12-01-2008, 02:46 PM   #2
projectRDM
projectRDM's Avatar
On 1995 models only there's a cable coming off the mode door motor that actuates a valve on the firewall heater hose. Have someone operate the unit inside while you watch the cable, see if the valve is working. Could be kinked, broken, or the motor has jammed somehow.
FORMERLY R240NA
Old 12-01-2008, 02:53 PM   #3
dori_sil8t
dori_sil8t's Avatar
dori_sil8t is making a name for him/her selfdori_sil8t is making a name for him/her self
so... the blower motor isnt working? blower motor or resistor.
or it doesnt blow hot air? thermostat is stuck open.
unionautoclub.com
dori_sil8t is offline   Reply With Quote
Old 12-01-2008, 03:08 PM   #4
Sil-Eighty SE-K
Sil-Eighty SE-K's Avatar
Sil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfection
Send a message via AIM to Sil-Eighty SE-K
not quite..... if its blowing but not hot could also be the blend door or cable/actuator for the blend door. If it has a water control valve instead of a blend door it could be that or something related to that system (control, wiring etc)
Originally Posted by JTunedMotorsports View Post
get off the thread...no one cares...
Sil-Eighty SE-K is offline   Reply With Quote
Old 12-01-2008, 03:10 PM   #5
Sil-Eighty SE-K
well if it has a control valve like that just bypass it and if thats the problem youll have heat..... dont expect good a/c tho if you do lol
Old 12-01-2008, 03:32 PM   #6
dori_sil8t
dori_sil8t's Avatar
im just trying to get more info....
unionautoclub.com
Old 12-01-2008, 03:46 PM   #7
projectRDM
projectRDM's Avatar
Not always. No heat can mean a dead blend door motor, jammed linkage, faulty control unit, or other mechanical issues. Could also just have a clog in a line or the hoses on backwards at the firewall.
FORMERLY R240NA
Old 12-01-2008, 05:23 PM   #8
MrChow
MrChow's Avatar
It blow air out. Just not warm or hot air. It's cool air.
Also my car warms pretty quick. Like after 5 min of driving it's warmed up.
Um... Not to sound dumb. Your talking about the mode that changes cold to hot air. Also is there anyway you can me show me where the cable is?? I'm soo lost about this.
Anyone else chime in with a pic would be great. It's winter and foggy as hell I need my defrosters and heat!!
Old 12-01-2008, 05:28 PM   #9
LA_phantom_240
LA_phantom_240's Avatar
Location: Louisiana. LA is for Louisiana. L.A. is Los Angeles.
LA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfection
Look at your heater hoses on the firewall. There's going to be a white valve with a cable like a throttle cable running to it. That controls the hot water flow to your heater core.
I have a similar problem as the OP. My heat doesn't work... at all. It kinda worked last year, but this year its dead. My blower doesn't always work, so I just opened the sunroof a bit to get circulation when it worked. I think my valve is stuck. Reason being that I can't turn it by hand, I can't open or close it. Am I supposed to be able to open or close it manually?
Originally Posted by SoSideways View Post
Come on, this isn't Gran Turismo.
Originally Posted by DOOK
your balls are either ballin, or they aren't... no second hand nut sweat can change that.
3/28/09 Buy this stuff!
http://zilvia.net/f/sale-items/24807...-stuff-fs.html
LA_phantom_240 is offline   Reply With Quote
Old 12-01-2008, 05:40 PM   #10
HS13KLS
HS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant future
thermostat maybe?
i heard a guy tell me that once..
HS13KLS is offline   Reply With Quote
Old 12-01-2008, 05:43 PM   #11
LA_phantom_240
Originally Posted by HS13KLS View Post
thermostat maybe?
If the car warms up to operating temp, but doesn't overheat, I doubt its the thermostat.
Old 12-01-2008, 06:33 PM   #12
MrChow
MrChow's Avatar
Thanks! I'll give it looks see tonight.
Old 12-02-2008, 09:25 PM   #13
MrChow
MrChow's Avatar
Okay I found it. It looks like it's work. It moved up and down. What's next??
