Old 12-03-2008, 11:21 AM   #1
LA_phantom_240
LA_phantom_240's Avatar
LA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfection
S14 window issue
Hey everyone, my S14 started a new problem today. My passenger side window won't roll down. The window wasn't sluggish or anything... well no more sluggish than it should be for a 13 year old car. When I hit the button, I hear just one small click, and the next time I hit the button I don't hear anything. I can only hear it with the car off. The only thing I've messed with is my door speaker, and I'm worried I may have damaged something with the screw going too far or something. Is there anything behind the speaker I need to worry about?
Thanks guys.
Originally Posted by SoSideways View Post
Come on, this isn't Gran Turismo.
Originally Posted by DOOK
your balls are either ballin, or they aren't... no second hand nut sweat can change that.
3/28/09 Buy this stuff!
http://zilvia.net/f/sale-items/24807...-stuff-fs.html
LA_phantom_240 is offline
Old 12-03-2008, 11:46 AM   #2
idlafie
idlafie's Avatar
What year is your S14?? 95-96 or 97-98?? If I recall correctly the 95-96 have issues with the window amplifiers, (see your factory service manual for further), going bad. That could be the cause of your problem.
Also check the motor on your window to see if it's not burn out, (doesn't happen often but it does happen). You'll have to run 12 volts directly to the motor to test it.
The only concern you should have with a too long of a screw is if it's so long that it touches the window while it's in the down position. But if that were the case you would have scratched or broken the window by now. Nissan usually runs the wires for the power window & door locks on a loom that is fastened to the door frame away from the speakers.
Anyhow, hope this helps...
ID
idlafie is offline
Old 12-03-2008, 11:54 AM   #3
projectRDM
projectRDM's Avatar
Only 95s had external amplifiers, and only for the driver side. If the passenger side is dead it's 99% of the time the motor. The speaker mounting location is nowhere near the motor or regulator, if you did run a long screw into something it would have to be really long, like stupid looking.
Pull the motor (or just unplug it from the harness) and hook it straight to a 12V drill battery. You'll get your answer.
FORMERLY R240NA
projectRDM is offline
Old 12-03-2008, 12:18 PM   #4
OBEEWON
OBEEWON's Avatar
Hey, external amps on 95's you say? My windows were going in and out intermittently. Now its stopped all together? Can the amp be repaired? Where can a new one be sourced? Am I going to get any taller? Thanks.
OBEEWON is offline
Old 12-03-2008, 12:40 PM   #5
chituntang
chituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nice
Those amps went out in a long time. Happened to me before. It worked intermittently for about half a year before it complete stop working.
chituntang is offline
Old 12-03-2008, 12:48 PM   #6
S14TEENZ
S14TEENZ's Avatar
S14TEENZ is an unknown quantity at this point
i have some amps i would sell if interested lmk???
but u better find out what actually wrong with it first...
S14TEENZ is offline
Old 12-03-2008, 12:49 PM   #7
jmac636
jmac636's Avatar
jmac636 is an unknown quantity at this point
projectrdm hit the nail on the head. Find the fsm for your car on 240edge.com then check your fuse, your wiring connections, check the switch and then test your motor by applying 12 volts. Or you could first just check your motor to save some time.
S14 Turbo LS1/t56 http://www.playloudclothing.com/
jmac636 is offline
Old 12-03-2008, 02:44 PM   #8
projectRDM
projectRDM's Avatar
Correct. The external amplifier was only used on 1995 models and only drives the driver side motor. Anyone who tells you an amp replacement will fix a passenger side window on a 95 or either window a 96-98 model is lying. Kick them in the teeth. A new amp is about $60 at the dealer.
The same amp also is used on 89-94 models as well as first generation G20s and Q45s.
FORMERLY R240NA
Old 12-03-2008, 05:15 PM   #9
LA_phantom_240
I think it's just my switch going out due to a cold solder joint. Pulled the switch on the passenger's side, cursed at it, cleaned the terminals and plugged it back in and low and behold it works again. I dunno, it was probably something stupid, but it works so I'm happy.
Old 12-04-2008, 01:19 AM   #10
kid270r
kid270r is an unknown quantity at this point
you might want to check your fuseable link inside your fuse box in your engine bay. i believe its a green 25 amp fuse. it can also cause the windows and sunroof to stop working.
kid270r is offline
Old 12-04-2008, 05:36 AM   #11
OBEEWON
OBEEWON's Avatar
DoubleelbouD
OBEEWON is offline
Old 12-04-2008, 05:37 AM   #12
OBEEWON
OBEEWON's Avatar
Gonna go check as soon as I can. I can hear it clicking when i flip the switch. Does that sound like the amp isnt working?
OBEEWON is offline
Old 12-04-2008, 06:36 AM   #13
LA_phantom_240
That or the motor.
Old 12-04-2008, 07:23 AM   #14
DaPCWiz
DaPCWiz's Avatar
DaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond repute
Send a message via AIM to DaPCWiz Send a message via MSN to DaPCWiz Send a message via Yahoo to DaPCWiz
lol. Reminds me of an issue my buddy had. We even took apart the door and everything to check for the problem and couldn't find any issues with anything. Then he realized that he had just hit the window lock button by accident. so yeah check your window lock, LOL.
http://blog.dapcwiz.com
DaPCWiz is offline
Old 12-04-2008, 07:29 AM   #15
blueshark123
blueshark123's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
haha yea that happens ....
blueshark123 is offline
Old 12-04-2008, 09:00 AM   #16
projectRDM
projectRDM's Avatar
That would have absolutely nothing to do with only one window not working. Try to stay on point if you're going to bother to offer help.
If both windows are erratic the amplifier would not be the culprit, as I stated it only drives the driver side window. The passenger would not see any effects from a bad amp and would work fine even if the amp was burned up. If it's only the driver side then it's likely it is the amp, but as always test the motor itself before making a decision. I've sold a lot of amps to people who came back calling me a thief because the amp was 'bad', when all along it was the motor that didn't work. Replacing a good part with another good part won't fix the bad part, no matter how bad you want it to do so.
FORMERLY R240NA
Old 12-04-2008, 09:02 AM   #17
EDacIouSX
EDacIouSX's Avatar
Trader Rating: (53)
EDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfection
Feedback Score: 53 reviews
i was going to say if its not plugged in all the way it won't work. i believe it works on a closed circuit, meaning both passenger and driver has to be plugged in in order to work. at least on my car i know both sides had to be plugged in for windows to roll down...
EDacIouSX is offline
Old 12-04-2008, 09:07 AM   #18
projectRDM
projectRDM's Avatar
Correct. I've even seen switches that work in one car, but not another. Over 10 years ago I diagnosed a problem where the passenger side window didn't work in a friend's car, we swapped switches and fixed it. His switch worked in my car but not his, whereas mine worked in both cars. Random weird shit that you can't explain.
FORMERLY R240NA
Old 12-04-2008, 10:12 AM   #19
OBEEWON
OBEEWON's Avatar
Yeah, its only the drivers on my 95, it was the passenger on my 96 and it makes a crazy noise, but the 96 got stolen so that solves that problem.
OBEEWON is offline
Old 12-04-2008, 10:20 AM   #20
rotation3x
rotation3x's Avatar
rotation3x has made poor choicesrotation3x has made poor choicesrotation3x has made poor choicesrotation3x has made poor choicesrotation3x has made poor choicesrotation3x has made poor choices
Send a message via AIM to rotation3x
I took the window amp apart on mine and soldered a piece of wire in place where it burned out on the board, works just fine.
rotation3x is offline
Old 12-04-2008, 12:57 PM   #21
kid270r
[quote=projectRDM;2487799]That would have absolutely nothing to do with only one window not working. Try to stay on point if you're going to bother to offer help.
im mearly tellin the guy it could be an option to check out. dont be tellin me to be on point. not like you know whats wrong with the situation either. just cause im not talking about the window amp, im not on point? oh please, and just for your information, the fusible carries an FL 25A 9p/window) fuse! so it can most deffinatley cause the a window and the sunroof to not work. i ran into that problem three months ago. if you dont like my suggestions, then keep shut and think "what a dumbass"... rather than posting wanna be wise comments trying to keep us on "point". good day
kid270r is offline
Old 12-04-2008, 02:56 PM   #22
projectRDM
projectRDM's Avatar
Fuck off troll. The fuse in question power BOTH windows as well as the sunroof. If all three quit working, you'd be right. Nowhere in this thread has anyone stated that, the whole scenario has been one window only being defective. Your suggestions are pointless.
Why not suggest changing his oil too, that may fix the window problem.
Learn how to quote a post too if you're going to call someone out. Right now you just look like the idiot you are.
FORMERLY R240NA
Old 12-04-2008, 04:16 PM   #23
kid270r
troll?? ha ha thats the best your over the hill ass can come up with? stop comming off like a prick with people and mabe youd get some respect. i never stated my method was correct. just somthing for him to keep in mind. so fuck off... and your stating how i replied to your quote? sorry, didnt know there was a certain way to start an internet battle..lol.. dude grow up and go your way and ill go mine.. the only one looking like an idiot is you...instead of bitchin.. this guy should be getting his help.
kid270r is offline
Old 12-04-2008, 05:44 PM   #24
LA_phantom_240
Kid, quit acting like a kid. I personally respect ProjectRDM because he's been very helpful to me in the past, and knows his shit better than 90% of the members here hands down.
As for this thread, I'm not going to let it turn into more of a shitfest than it has already become. Problem solved, and all useful information posted, I see no more need for this thread to be opened. Thanks guys, I'm sure that this thread will be off assistance to fellow current and future zilvians.
/thread
power window, power windows, s14
