Old 12-08-2008, 04:55 AM   #1
s13boy89
s13boy89's Avatar
s13boy89 is on a distinguished road
Send a message via AIM to s13boy89
ka overheating
i have a question on a ka i installed alright here goes. i recently purchased an s14 ka i put my s13 intake on there since all the emissions and most of the coolant lines are gone. when i put it back on i didn't have a gasket so i used silicone. i was wondering if it should be fine because the car likes to over heat on spirited driving, but if i let it cool down it will be fine again so i want to know if it is my hg or my shitty silicone job. also yes i have bled it several times, i also took off the thermostat to see if that was the problem and it wasn't. also i have no thermo and it still does it and i dont have heater anymore so i cant bleed it
I have kids running around here I dont want to use an xxr as a coffe table
s13boy89 is offline   Reply With Quote
Old 12-08-2008, 04:59 AM   #2
tre4s13
tre4s13 is an unknown quantity at this point
Send a message via AIM to tre4s13 Send a message via Yahoo to tre4s13
Bleeding it several times just doesn't seem to do the trick on KA motors. When it warms up, cut it off....open bleeder purge on manifold, refill...cool off, repeat...till you see NO bubbles come out that little bastard.
tre4s13 is offline   Reply With Quote
Old 12-08-2008, 05:01 AM   #3
s13boy89
s13boy89's Avatar
yeah i have a radiaotr cap that lets all the bubbles out when i flick the switch but water comes out as well and when i squeeze the hose they are rock hard are they supposed to be like that
Old 12-08-2008, 05:25 AM   #4
tre4s13
I do also, but don't use that it'll just push the air into your over flow tube...lol just do it how i told ya, TRUST me it works. top off, warm up, cut off, bleed, cool down. REPEAT!
Old 12-08-2008, 05:28 AM   #5
tre4s13
oh yea, and don't forget to let your car cool down for FIFTEEN minutes. i think this is important...
Old 12-08-2008, 05:29 AM   #6
tre4s13
This is what I used after I did my ka-e to de swap.
Technical Articles: OMG My RB is overheating!
and it works.
Old 12-09-2008, 12:06 AM   #7
s13boy89
s13boy89's Avatar
bled it all day and still gets hot
Old 12-09-2008, 12:20 AM   #8
stealthsr20
stealthsr20's Avatar
stealthsr20 is an unknown quantity at this point
have you pressure tested the motor?
stealthsr20 is offline   Reply With Quote
Old 12-09-2008, 12:23 AM   #9
s13boy89
s13boy89's Avatar
no i havent
Old 12-09-2008, 01:24 AM   #10
JRas
JRas's Avatar
JRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfection
Send a message via AIM to JRas
what does your oil look like? chocolate milk?
does it overheat idling? or while driving?
kinda confused where you used the silicone too...
edit: check out FSM for proper coolant bleeding procedure
JRas is offline   Reply With Quote
Old 12-09-2008, 01:32 AM   #11
1989rps13
1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute1989rps13 has a reputation beyond repute
Send a message via AIM to 1989rps13
his overheats while driving im pretty sure cause at idle it did not overheat
1989rps13 is offline   Reply With Quote
Old 12-09-2008, 02:12 AM   #12
JRas
JRas's Avatar
how long did you guys let it idle for?
FSM:
Old 12-09-2008, 10:55 AM   #13
s13boy89
s13boy89's Avatar
i have no heater, it starts to overheat while driving and no the oil has no coolant in it
Old 12-09-2008, 11:10 AM   #14
wht240sx
wht240sx's Avatar
wht240sx is an unknown quantity at this point
Did you switch over coolant sensors? I had this problem when i put my 91 ka in my 95 240. I thought is was overheating but i found out that the single pin coolant sensors have different resistance values and it will make the temp gauge read hot on and s14 cluster.
wht240sx is offline   Reply With Quote
Old 12-09-2008, 11:16 AM   #15
essforteen
essforteen's Avatar
Trader Rating: (50)
essforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant future
Feedback Score: 50 reviews
when was the last time you changed your water pump?
essforteen is offline   Reply With Quote
Old 12-09-2008, 11:28 AM   #16
s13boy89
s13boy89's Avatar
i just changed it when i put in my motor and the temp sensor its the same one from my other motor
Old 12-09-2008, 11:57 AM   #17
essforteen
essforteen's Avatar
Trader Rating: (50)
is it gurgling into the overflow tank
Old 12-09-2008, 12:20 PM   #18
s13boy89
s13boy89's Avatar
yeah it gurgling
Old 12-09-2008, 09:00 PM   #19
Dirty Habit
Dirty Habit's Avatar
Dirty Habit is close to perfectionDirty Habit is close to perfectionDirty Habit is close to perfectionDirty Habit is close to perfectionDirty Habit is close to perfectionDirty Habit is close to perfectionDirty Habit is close to perfectionDirty Habit is close to perfectionDirty Habit is close to perfectionDirty Habit is close to perfectionDirty Habit is close to perfection
I had a similar problem like this. Still havent fixed it. Interested to see whats going on with it.
1982 280zx Turbo
Dirty Habit is offline   Reply With Quote
Old 12-09-2008, 11:37 PM   #20
s13boy89
s13boy89's Avatar
so i found out my water pump was leaking and that my lower radiator hose was gushing water so i fixed that and also put a new thermo on and so far it hasnt over heated
Old 12-10-2008, 12:05 AM   #21
tramp_drift240
tramp_drift240's Avatar
tramp_drift240 is on a distinguished road
Send a message via AIM to tramp_drift240
how. in the hell. did you not notice that your lower hose was "gushing" water.
doesnt "gushing" normally seem like....a water balloon that got busted. or a raging river.
tramp_drift240 is offline   Reply With Quote
Old 12-10-2008, 12:44 AM   #22
s13boy89
s13boy89's Avatar
nah i fixed it then i went to a meet the i noticed i had a puddle
Old 12-10-2008, 01:27 AM   #23
tramp_drift240
that doesnt really explain why your hoses were as pressurized as you said.
when my hoses were like that, my HG had caused a tunned from the combustion chamber to the coolant jackets. ergo, super pumped cooling system.
Old 12-10-2008, 09:51 AM   #24
nismo racer
nismo racer's Avatar
nismo racer is making a name for him/her selfnismo racer is making a name for him/her self
Mine gurgles into overflow tank aswell but nver ever over heats.
PEGASUS
nismo racer is offline   Reply With Quote
Old 12-10-2008, 11:46 AM   #25
shytdoode
shytdoode is an unknown quantity at this point
can always be a bad radiator or water pump
shytdoode is offline   Reply With Quote
Old 12-10-2008, 12:19 PM   #26
s13boy89
s13boy89's Avatar
ehh it doesnt overheat anymore so ill leave it
