Old 12-09-2008, 08:41 PM   #1
LongGrain
LongGrain's Avatar
V-mount intercooler setups.
i am thinking about doing one on my car before the engine goes back in after the rebuild. but i'm not sure where to start. i seared and only found info on front mounts.
my current/previous setup is just a basic big front mount with custom piping, and a koyo aluminum radiator with dual fans.
what all is needed to do this?
where would i find an intercooler for this application?
can i still use my koyo?
any information is greatly appreciated.
LongGrain is offline   Reply With Quote
Old 12-09-2008, 08:48 PM   #2
khilgers
khilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond repute
get ahold of Ryan on ClubFR. He can help you out.
khilgers is offline   Reply With Quote
Old 12-09-2008, 08:53 PM   #3
pwr-adr
pwr-adr is a jewel in the roughpwr-adr is a jewel in the roughpwr-adr is a jewel in the roughpwr-adr is a jewel in the roughpwr-adr is a jewel in the roughpwr-adr is a jewel in the roughpwr-adr is a jewel in the roughpwr-adr is a jewel in the rough
I have seen multiple ways on how to do a v-mount setup. I see it as it comes down to the fabricator honestly. You can still use your koyo, obviously though you will need to make your own radiator hoses. I would consider getting an intercooler that is designed (end tank inlet and outlet wise as well as a tube and fine construction if possible) for a v-mount.
One big advantage to running v-mount is the fact you have less IC piping so why not get the intercoolers that are intended for v-mounts? It saves even more piping if you get the correct IC. Also use puller fans and locate them on the side of the rad that is facing the ground. I have seen a few people run their fans on top of the radiator if you will but I see this as only subtracting the amount of surface area your radiator has plus it disrupts the flow by creating a whirl pool effect.
Some modification may need to be done to the radiator support depending on how you design the bracketry for the IC and rad.
I do not have any pics on how I've done them or how we did a few other cars in town but I can tell you that it is well worth the time and effort. None of us have ever experienced any heating issues and the spool up time is cut down significantly. Throttle response FTW!
pwr-adr is offline   Reply With Quote
Old 12-09-2008, 08:56 PM   #4
LongGrain
LongGrain's Avatar
kevin, i definitely plan on talking to clemens about it. i'm just looking for more info on it to see if it is even in my price range. i was originally going to just replace my leaky intercooler piping with a nicer kit, but a V mount has been on my mind lately.
Old 12-09-2008, 09:04 PM   #5
stealthsr20
stealthsr20's Avatar
stealthsr20 is an unknown quantity at this point
If you do a v-mount, PLEASE do a full write up on it
stealthsr20 is offline   Reply With Quote
Old 12-09-2008, 09:05 PM   #6
smelly240
smelly240's Avatar
biggest problem i had running the vmount (beside the IC that cracked) was working on th ecar.
u gotta pull the IC to do anything.in front of th emotor. Also - i ran a inline coolant can filler thingerator. jegs sells em - makes coolant stuff cake.
and dont do a write up - make everyone fab their own up. that seperates men from boys.
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope
Old 12-09-2008, 09:06 PM   #7
jimmytango00
jimmytango00's Avatar
jimmytango00 is close to perfectionjimmytango00 is close to perfectionjimmytango00 is close to perfectionjimmytango00 is close to perfectionjimmytango00 is close to perfectionjimmytango00 is close to perfectionjimmytango00 is close to perfectionjimmytango00 is close to perfectionjimmytango00 is close to perfectionjimmytango00 is close to perfectionjimmytango00 is close to perfection
Send a message via AIM to jimmytango00
you can still use your koyo, i did.. here is a few pics of my set up...i would say hit up luisgonz but his banned.
jimmytango00 is offline   Reply With Quote
Old 12-09-2008, 09:11 PM   #8
LongGrain
LongGrain's Avatar
how much fabrication was involved? i know i will need a new intercooler, piping, and new radiator hoses, but mounting everything up is very foreign to me.
having custom piping made is no big deal, i just dont know about anything else.
Old 12-09-2008, 10:22 PM   #9
Devil Man
Devil Man is an unknown quantity at this point
i spy srt4 IC.... booooo haha.. go way of recycling some parts though
Devil Man is offline   Reply With Quote
Old 12-09-2008, 10:42 PM   #10
zaquanh
zaquanh has a spectacular aura aboutzaquanh has a spectacular aura aboutzaquanh has a spectacular aura aboutzaquanh has a spectacular aura aboutzaquanh has a spectacular aura aboutzaquanh has a spectacular aura about
honestly i dont think its that much fabing up to do , i would get a piping , cut end tanks and have them on the face of the fmic so less bends and closer ,
get a water air seperator , that way its alot easier to work with coolant , get coolant hoses , and make sumthin to divert the air into the V , and make a bracket for the setup to sit on
if you have welding skills , not to hard
zaquanh is offline   Reply With Quote
Old 12-09-2008, 10:42 PM   #11
Om1kron
Om1kron's Avatar
McRussellPants has a really nice v-mount set up, but don't expect to get any reasonable questions answered by him. He speaks "Texas"
http://zilvia.net/f/chat/184241-lol-car-4.html
Wayne Edwards
https://om1kron.blogspot.com
Old 12-09-2008, 10:47 PM   #12
McRussellPants
My V-mount will skull fuck you.
that is all.
McRussellPants is offline   Reply With Quote
Old 12-09-2008, 10:56 PM   #13
Om1kron
Om1kron's Avatar
that is all.
see I had told you!!!
Wayne Edwards
Old 12-09-2008, 11:22 PM   #14
sillyvia13
sillyvia13's Avatar
sillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfection
that is all.
lol... Nice car, glad I hit this thread,
V mount ftw
sillyvia13 is offline   Reply With Quote
Old 12-10-2008, 12:21 AM   #15
LongGrain
LongGrain's Avatar
bump for more info. pictures of cool cars are neat but how do i achieve this?
Old 12-10-2008, 08:28 AM   #16
Andrew @ 240sxMotoring
Andrew @ 240sxMotoring's Avatar
Andrew @ 240sxMotoring is just really niceAndrew @ 240sxMotoring is just really niceAndrew @ 240sxMotoring is just really niceAndrew @ 240sxMotoring is just really niceAndrew @ 240sxMotoring is just really niceAndrew @ 240sxMotoring is just really niceAndrew @ 240sxMotoring is just really niceAndrew @ 240sxMotoring is just really niceAndrew @ 240sxMotoring is just really nice
Send a message via AIM to Andrew @ 240sxMotoring
Had one on the 'ol formula d car.
Andrew @ 240sx Motoring Milford, CT @ 203-783-1422 (ext. 112)
Read what people have to say about 240sxMotoring!
Andrew @ 240sxMotoring is offline   Reply With Quote
Old 12-10-2008, 08:40 AM   #17
landins13
landins13's Avatar
landins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choices
bump looking for fab pics
NO HANDS IN PANTS!!
landins13 is offline   Reply With Quote
Old 12-10-2008, 12:18 PM   #18
Teambadrun
Teambadrun's Avatar
Teambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to all
Id stick with a FMIC if you want reliability in cooling.... But yeah here's my old Vmount kit... was around 2,000USD all up from a company who was making proper kits using Garrett core's and proper radiator cores... you can't see much but yeah lol.
Teambadrun is offline   Reply With Quote
Old 12-10-2008, 01:15 PM   #19
Om1kron
Om1kron's Avatar
yup that looks like a 7 mount lol... not a v mount.
Wayne Edwards
Old 12-10-2008, 11:10 PM   #20
jimmytango00
sorry buddy, no srt4 intercooler here,
its an Apexi GT intercooler for a GTR
Old 12-11-2008, 12:10 AM   #21
jakerps13
jakerps13 is an unknown quantity at this point
Send a message via AIM to jakerps13
Honestly bro, I wouldn't overcomplicate your setup. Somewhat knowing you drive you car on the street and track, I'd personally just recommend a stacked style intercooler/rad.
Shoot me a pm if you're interested, I'm looking for some winter projects.
Lower than a pornstar's morals.
jakerps13 is offline   Reply With Quote
Old 12-11-2008, 08:56 AM   #22
Zerolift Autolab
Zerolift Autolab's Avatar
Zerolift Autolab has a brilliant futureZerolift Autolab has a brilliant futureZerolift Autolab has a brilliant futureZerolift Autolab has a brilliant futureZerolift Autolab has a brilliant futureZerolift Autolab has a brilliant futureZerolift Autolab has a brilliant futureZerolift Autolab has a brilliant futureZerolift Autolab has a brilliant futureZerolift Autolab has a brilliant futureZerolift Autolab has a brilliant future
Send a message via AIM to Zerolift Autolab
Zerolift Autolab is offline   Reply With Quote
Old 12-11-2008, 09:09 AM   #23
Om1kron
Om1kron's Avatar
looks good by why not run a shroud on the back of the radiator still. is it because the fan is set to pull instead of push? I dunno these things, explain.
Wayne Edwards
