Old 12-09-2008, 09:09 PM   #1
Kougeki
Kougeki's Avatar
Kougeki has a reputation beyond reputeKougeki has a reputation beyond reputeKougeki has a reputation beyond reputeKougeki has a reputation beyond reputeKougeki has a reputation beyond reputeKougeki has a reputation beyond reputeKougeki has a reputation beyond reputeKougeki has a reputation beyond reputeKougeki has a reputation beyond reputeKougeki has a reputation beyond reputeKougeki has a reputation beyond repute
Send a message via AIM to Kougeki Send a message via MSN to Kougeki Send a message via Yahoo to Kougeki
Removing Cluster?
I typed in cluster, gauges and dash.
No threads came up that SHOWED how
to take off the cluster.
I have an idea, but i need to be sure.
I'm planning on putting in LEDs.
Any help?
Gamertag:XxChumbawumbaxX
Kougeki is offline   Reply With Quote
Old 12-09-2008, 10:14 PM   #2
projectRDM
projectRDM's Avatar
S13? S14? Z32? Pinto? ElCamino?
Remove the shroud, remove the cluster. Dropping the column helps. So does an FSM, which you clearly need to download.
FORMERLY R240NA
Old 12-10-2008, 09:25 PM   #3
Kougeki
Kougeki's Avatar
My bad.
It's a 91 240SX.
Old 12-10-2008, 09:29 PM   #4
Devil Man
Devil Man is an unknown quantity at this point
wow man
Technical Articles: s13 Dash Removal
under 5 secs
Devil Man is offline   Reply With Quote
Old 12-10-2008, 09:32 PM   #5
0displacement
0displacement's Avatar
0displacement has a spectacular aura about0displacement has a spectacular aura about0displacement has a spectacular aura about0displacement has a spectacular aura about0displacement has a spectacular aura about0displacement has a spectacular aura about
that hardly shows how to pull the cluster, or at least it shows how to pull EVERYTHING including the cluster.
just drop the steering wheel column and undo a couple screws on the bezel and un clip the cluster and pull it out above the steering wheel. takes like 5 mins
0displacement is offline   Reply With Quote
Old 12-10-2008, 09:33 PM   #6
DreamN
DreamN's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
90 240SX Instrument Cluster Removal: Nissan Online Mechanic: Nissan Forums / Infiniti Forums - NICOclub
don't limit yourself to searching on just one forum.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 12-10-2008, 09:34 PM   #7
DreamN
DreamN's Avatar
Trader Rating: (54)
If you still don't understand it just PM me and I'll help you out.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 12-10-2008, 09:45 PM   #8
nismo racer
nismo racer's Avatar
nismo racer is making a name for him/her selfnismo racer is making a name for him/her self
takes like 15mins to change out the bulbs in the cluster.
PEGASUS
nismo racer is offline   Reply With Quote
Old 12-10-2008, 09:49 PM   #9
Kougeki
Kougeki's Avatar
It probably does take 15 minutes AFTER it's removed.
I saw the Nico one already, but i know i saw one on Zilvia that showed exactly how
to take out the cluster only.
I'll still look around, and thanks.
Old 12-10-2008, 09:52 PM   #10
Kougeki
Kougeki's Avatar
Ok, the things i have a question on is,
do i need to take off the buttons?
Do i have to remove the steering wheel?
Old 12-10-2008, 09:52 PM   #11
DreamN
DreamN's Avatar
Trader Rating: (54)
Dude, it seriously takes about 15 min. Hell, I've swapped out LEDs for two people on the same night at a car meet with little to no light and it took me about 20-30 min. for each of them. It was just a bitch to get those 12 mm steering column bolts back in place when you can't see where they're going.
If you look around at the parts you need to remove you should be able to figure it out by yourself.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 12-10-2008, 09:53 PM   #12
DreamN
DreamN's Avatar
Trader Rating: (54)
No you don't have to take off the buttons. If you want a little more space to work with it does help.
Steering wheel definitely does not need to be removed.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 12-10-2008, 09:55 PM   #13
Kougeki
Kougeki's Avatar
Aight, sweet.
Thanks man.
Old 04-02-2009, 04:17 AM   #14
silentcovenant
silentcovenant's Avatar
silentcovenant is an unknown quantity at this point
Sorry to revive a dead thread guys but I could not find information on how many bulbs I'd need to completely replace the entire dash. My dash is suuuper dim and I wanted to change the bulbs to LEDs. Which bulbs do I need to get and how many?
Thanks,
--Marc
silentcovenant is offline   Reply With Quote
Old 04-03-2009, 10:16 AM   #15
lil_killer
lil_killer is an unknown quantity at this point
i change mine some day ago and i buy all my led on ebay.
1 pack of 10 t5 like these: 10 x Blue LED Dashboard Speedo Wedge Light Bulb T5 286 - (eBay.ca item 320355790890 end time 01-May-09 01:30:07 EDT)
2 pack of 4 t10 like these:4pcs Bright Blue LED Wedge Light Bulbs Dome 194 168 T10 - (eBay.ca item 360141647872 end time 23-Apr-09 01:51:28 EDT)
really cheap and great result.
lil_killer is offline   Reply With Quote
Old 04-03-2009, 02:32 PM   #16
silentcovenant
Originally Posted by lil_killer View Post
What would be the equivalent bulbs on SuperbrightLEDs? Hehe, I prefer to order from one source. If cannot find, I'll order em'
Did you use all the bulbs?
Old 04-03-2009, 02:55 PM   #17
94_240sx
94_240sx is on a distinguished road
Hmm... I checked other write ups and no one is doing it right. Here's how to for the cluster removal. I'm adding it just in case someone search this thread.
- Remove scuff plate
- Remove kick panel(where fuses are). 2 screws and 1 plastic clip are there. You need to remove this because one bolt underneath it is holding the lower knee panel.
- Remove 2 screws on hood latch opener
- Unhook the hood latch opener
- Remove all the bolts on knee panel and unhook it from two holes.
- Disconnect floor light plug
- Remove key ring cover
- remove upper and lower steering column covers
- Remove 2 14mm bolts, so you can drop the steering column
- Remove 2 crews on top of cluster trim. You need a short screw driver for this.
- Undo the clips under the cluster trim vents.
- Grab both side of cluster trim, pull down and pull it toward you
- Disconnect plugs behind the cluster trim
- Remove 3 screws that are holding the cluster
- Remove the cluster
I think that's about it. I've done it many times, so I can do it with my eyes closed.
94_240sx is offline   Reply With Quote
