Old 09-14-2008, 02:54 PM   #1
trad1987
trad1987 is an unknown quantity at this point
Send a message via AIM to trad1987
rb25det cluster not working, Easy fix?
hey guys, i may be trading my car for a RB25 powered s13. One of the issues that is keeping me on the fence is that the gauge cluster does not work, except for turn signals. He has the skyline cluster, but i would much perfer to keep the s13 one for mph. Is this a difficult fix? anyone have any insight here? Thanks
trad1987 is offline   Reply With Quote
Old 09-14-2008, 02:55 PM   #2
TurboStrong
TurboStrong's Avatar
TurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really nice
wat car do u have to trade?
TurboStrong is offline   Reply With Quote
Old 09-14-2008, 03:03 PM   #3
trad1987
my FD that is not running at the moment
Old 09-14-2008, 03:05 PM   #4
96Turbo
96Turbo's Avatar
96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute
define "gauge cluster does not work"
cuz if it doesn't work at all then he wired something wrong....probably not too hard of a fix. But if the gauges are just innaccurate then that's to be expected.
speedo signal from RB is KMH, vs MPH. So it should be off by close to a factor of 2. (mine reads almost exactly half of what it should). I think LS automotive makes a speedo that will work
as for tach....6 cyl output vs 4 cyl tach causes it to read 1.5x higher. CarlH on nico will modify ur DOHC tach to work perfectly with the RB signal for like $50. That's what i'm gonna do when i have more money.
hope that helps
96Turbo is offline   Reply With Quote
Old 09-14-2008, 03:11 PM   #5
trad1987
nevermind, i found out.
Old 09-14-2008, 03:13 PM   #6
96Turbo
96Turbo's Avatar
how much is their tach fix? I bet its more than $50......talk to carlh...trust me
and oh yea!!!! Get the VSS (speed sensor for the tranny) from a Z32
fits into the RB tranny and gives an output signal in mph. boom!
but this is all assuming that the stock cluster is wired correctly. It does work right? just not accurately?
Old 09-14-2008, 05:22 PM   #7
trad1987
Its 100, plus 50 charge fee. The speedo fix is the 180mph one. So you said the 300zx speed sensor on the rb25 will work for the 240sx cluster?
Old 11-27-2008, 08:27 PM   #8
Neejay
Neejay's Avatar
Neejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfection
Z32 TT or NA?
Neejay is offline   Reply With Quote
Old 12-13-2008, 06:38 PM   #9
96Turbo
96Turbo's Avatar
this was brought up in a nother thread recently and S14DB informed me that the Z32 sensor with NOT fix your speedo reading
he said the 2 sensors are identical and the cluster must be modified
Old 12-16-2008, 01:30 AM   #10
khoadogg
khoadogg's Avatar
khoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of lightkhoadogg is a glorious beacon of light
Send a message via AIM to khoadogg
is that true? anyone try using the z32 sensor yet?
AIM SoarinStrong[B]STRONG 6iX[B]
RB single turbo ///Work AMKREAD 180sx
khoadogg is offline   Reply With Quote
Old 12-16-2008, 08:40 AM   #11
Zerolift Autolab
Zerolift Autolab's Avatar
Zerolift Autolab has a brilliant futureZerolift Autolab has a brilliant futureZerolift Autolab has a brilliant futureZerolift Autolab has a brilliant futureZerolift Autolab has a brilliant futureZerolift Autolab has a brilliant futureZerolift Autolab has a brilliant futureZerolift Autolab has a brilliant futureZerolift Autolab has a brilliant futureZerolift Autolab has a brilliant futureZerolift Autolab has a brilliant future
Send a message via AIM to Zerolift Autolab
I have used the NA Z32 Speed Sensor in a Car and it worked no problem.
Also have used the Dakota Digital converter and that worked without a problem aswell.
Zerolift Autolab is offline   Reply With Quote
Old 12-16-2008, 08:46 AM   #12
Neejay
Neejay's Avatar
EDIT: misread, NA z32. Thanks!
Old 12-16-2008, 08:53 AM   #13
96Turbo
96Turbo's Avatar
Originally Posted by Neejay View Post
What year and model? (NA or TT)
he said NA, and any Z32 should be the save (VG30DE)
that's interesting to hear it worded perfectly for you, since i've heard different things from different people. I guess the only way is to get one and find out!
thanks for the info though. When using the Dakota Digital, did you notice any lag time in the tach? I've heard it has a slight delay in converting the signal
Old 12-16-2008, 08:56 AM   #14
Neejay
Neejay's Avatar
oops, I got so excited, I misread. lol Thanks.
Zerolift Autolab: Thanks!
As far as the tach: I don't think I'll find anything cheaper than the $45 of shipping it to Carl H and having him calibrate it.
Old 12-16-2008, 09:57 AM   #15
projectRDM
projectRDM's Avatar
The VSS doesn't give signal in MPH or KM/H. The signal is the same for all units, if you look at a JDM gauge vs. a US you'll see the points match up, the only difference would be an auto unit vs. a manual. There is no such thing as a 'JDM' or 'KM/H' speed sensor.
FORMERLY R240NA
Old 12-16-2008, 11:23 AM   #16
96Turbo
96Turbo's Avatar
yea....that's what S14DB told me.....
so you're saying my USDM cluster is reading KPH on the MPH scale? I still don't understand it completely....because the way you're making it sound it should show MPH on my cluster, and KPH on a JDM cluster without having to calibrate anything
So how do you explain people using Z32 VSS and having it work for MPH?
Old 12-16-2008, 11:58 AM   #17
OBEEWON
OBEEWON's Avatar
Good Q..........
Old 12-16-2008, 12:06 PM   #18
96Turbo
96Turbo's Avatar
so let me get this straight. basically my 2 options are:
1. get speedo recalibrated
2. Find speedo gauge face from (canada, uk, jp, anything with KPH as a primary scale, and MPH as the secondary) and switch with my MPH face
right?
Old 12-16-2008, 12:21 PM   #19
Neejay
Neejay's Avatar
right?
Those were my original plans...until I saw a thread of hope with dealing with the Z32 sensor.
Old 12-16-2008, 12:44 PM   #20
projectRDM
projectRDM's Avatar
Yes. The VSS is the exact same unit (at least for the Schassis) in all markets. Swapping a JDM cluster into your car does not require any calibration, not does using a sensor from a clip sourced outside the US.
As far the RB25/Z32 debate, I'm almost 100% positive it's the same too. It makes no sense that Nissan would build different sensors for different markets, and guys running JDM clusters in Z32s don't have to calibrate or swap anything to make them read correctly.
FORMERLY R240NA
Old 12-17-2008, 08:44 AM   #21
Neejay
Neejay's Avatar
So you're saying the z32 sensor should be accurate on a 180sx cluster? I've seen where people get a 180sx cluster and adjust the potentiometer (or whatever it's called) and claim that it works. I'm confused.
I don't understand why places like LS auto charge $110 for the "calibration" of the speedometer and the tachometer.
