Old 12-17-2008, 02:54 PM   #1
95se
95se's Avatar
95se is an unknown quantity at this point
Clanking noise during braking
I have a '95 se and there are 2 clanks coming from the front evertime I brake, once during initial braking and again before coming to complete stop. I have Z32 30mm brakes up front. This noise has been there since about the time I had the pads replaced about 3 yrs ago. I've been told everything is tight in the front suspension and no one can figure it out. I replaced the FLCA's and front TC rods last year with SPL V2's but the noise never went away. I have taken it to a new mechanic since who says the only thing he could think of it being is the pads slipping a little within the calipers because they are moving on the pins or the pins are moving a little within the caliper but the calipers were tight. So basically he said I could try replacing the hardware kit when I get new pads or go back to stock brakes. Anyone have this issue. All other bushings in suspension were checked and looked ok.
thanks,
C
z32 front brakes, spl tc rods
95se is offline   Reply With Quote
Old 12-17-2008, 02:55 PM   #2
Teddy
Teddy's Avatar
Trader Rating: (44)
Feedback Score: 44 reviews
Check to see if the bolt/nut holding on your lower control arm is loose.
www.realize-jp.net
Old 12-17-2008, 02:59 PM   #3
95se
95se's Avatar
Like I said everything is tight in the front suspension. It's been checked multiple times.
Old 12-17-2008, 03:22 PM   #4
Teddy
Teddy's Avatar
Trader Rating: (44)
haha sorry I didn't read everything.
www.realize-jp.net
Old 12-17-2008, 03:58 PM   #5
chibo
chibo's Avatar
chibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfection
Send a message via AIM to chibo
Coilovers?
1989 S13 | 1996 S14 | 2001 E46 | 2009 ZX6R
chibo is offline   Reply With Quote
Old 12-17-2008, 07:54 PM   #6
95se
95se's Avatar
Originally Posted by chibo View Post
Coilovers?
Again I said suspension is stock with exception of the SPL TC V2 TC rods and the front brakes are 30mm Z32 with ABS stock 240 brake package.
Old 12-17-2008, 08:11 PM   #7
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
engine mounts? since u already replaced all your front suspension. thats the only thing i have left in my mind with play for wear and tear.
