Old 12-19-2008, 03:30 PM   #1
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
Drilling broken stud gone wrong...
Snapped exhaust stud, exhaust leak so I drilled. I found out I drilled at a slight angle while drilling a snapped exaust mani stud. The stud was a few mm behind the surface of the head.
The hole is way off center, and heading towards aluminum.
Would a new head be the only way to salvage this opperation?
Bigsyke is offline   Reply With Quote
Old 12-19-2008, 03:41 PM   #2
slider2828
slider2828's Avatar
no... I think you are ok.... just use easy outs after that....
Srew Extractor | Bolt | Stud Extractor | Bolt Removal
Get some PB blaster and soak that shit every hour today and leave it over night and try again. Maybe you can even use vice grips after the PB...
Turn and Burn!
Old 12-19-2008, 03:43 PM   #3
orion::S14
orion::S14's Avatar
Ouch...
Maybe a little larger bit, and try to re-aim the hole.
Dunno, man...you're headed into dangerous waters...BUT, if you screw it p, you'll still need a new head.
SO your choices are -
Stop now, and live with the leak.
OR, try again, and get that sucker out. Then re-tap larger, OR use a new stud...whatever is appropriate.
- Brian
www.KA24DEvelopment.com
Old 12-19-2008, 03:44 PM   #4
Bigsyke
Bigsyke's Avatar
im already using one and a left handed reversed drill bit, no dice, just further enlarges the hole...
Old 12-19-2008, 03:52 PM   #5
greenman100
Trader Rating: (18)
greenman100 is an unknown quantity at this point
Feedback Score: 18 reviews
take it to a machine shop, and have them bore it and helicoil it. should be about 50 bucks
greenman100 is offline   Reply With Quote
Old 12-19-2008, 04:06 PM   #6
Bigsyke
Bigsyke's Avatar
Id have to remove the head, its my DD. cant do that till next summer.
Two questions;
Will having a snapped stud eventually warp the header flange? (aftermarket)
and is there a gasket thats thicker than average to help seal the leak (snapped stud is the closest to the radiator - 1pc flange on header)
Old 12-19-2008, 05:06 PM   #7
slider2828
slider2828's Avatar
o woops wrong one....
Use this one....
http://www.sears.com/shc/s/p_10153_1...0070921x00003c
MUCH BETTER.... you can find em at sears I think
Turn and Burn!
Old 12-19-2008, 05:11 PM   #8
slider2828
slider2828's Avatar
Nope replace the stud bro.... easy.....
Yes S15 7 layer metal exhaust gasket from Phase2
Turn and Burn!
Old 12-19-2008, 05:14 PM   #9
sillyvia13
sillyvia13's Avatar
sillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfection
I got same deal on my ka24de, its 1st stud in front by rad, leaks BAD! lol..
Oil seals are junk in cyl 1 too so oil seeps out...
all good tho other than the tick from a tight exh leak.. sounds like metal on metal but just air...
*cough *cough j b weld... lmao.
sillyvia13 is offline   Reply With Quote
Old 12-19-2008, 07:05 PM   #10
reinvent
reinvent is an unknown quantity at this point
you also misspelled "operation".
reinvent is offline   Reply With Quote
Old 12-19-2008, 07:35 PM   #11
s13drob
s13drob's Avatar
Trader Rating: (29)
s13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymore
Feedback Score: 29 reviews
as long as the easy-out can get grip in the hole drilled, it should come out. it doesnt need to be deep anyways. good luck
s13drob is offline   Reply With Quote
Old 12-19-2008, 07:54 PM   #12
S13sam
S13sam's Avatar
S13sam is an unknown quantity at this point
Send a message via AIM to S13sam
good luck bro... i had the same prob and thought i could fix it myself and i fucked my head up so now good bye to rb and hello to ls1. if you have a friend that knows how to do it try and see if they can help you get it out.
S13sam is offline   Reply With Quote
Old 12-23-2008, 09:56 PM   #13
Bigsyke
Bigsyke's Avatar
anybody know how long it takes to warp a stainless header with just 1 snapped stud?
Old 01-21-2009, 11:59 AM   #14
alkemyst
alkemyst's Avatar
alkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nice
Send a message via AIM to alkemyst
I will end up leaking in about a month or so (depending on driving). I only drive about 5-10miles a day.
I just went through this. I redrilled for an M12x50x1.25 stud. You have to be careful as it's easy to drill too far and hit the water jacket. Then you will have to seal it with RTV and make sure the threads are tight.
The header shouldn't permanently warp though.
Now my Kensai, I curse you to be a Ronin and with the my remaining spirit I, beseech Chimata-No-Kami, to have you wander through time and distance lands, seeking a new master.
alkemyst is offline   Reply With Quote
Old 01-21-2009, 07:43 PM   #15
essforteen
essforteen's Avatar
Trader Rating: (50)
essforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant future
Feedback Score: 50 reviews
Im in the same boat too
I got that exact problem but i just read on another thread that i can weld a nut on it
but my problem is that it sheered off a little in the head so welding might not work
so now im just living with the exhaust leak as my eyes tear up in traffic LOL..
essforteen is offline   Reply With Quote
Old 01-22-2009, 03:34 PM   #16
chuonthis
chuonthis is a jewel in the roughchuonthis is a jewel in the roughchuonthis is a jewel in the roughchuonthis is a jewel in the roughchuonthis is a jewel in the roughchuonthis is a jewel in the roughchuonthis is a jewel in the roughchuonthis is a jewel in the rough
BigSyke, same stud broke for me a while ago. I posted about it here: http://zilvia.net/f/tech-talk/208466...ml#post2258372
What size drill bit did you use? If you used something big like a M10 or M8, then maybe try to use the M6 in the set that I ended up getting from Sears (link in other thread). As long as you haven't drilled until the end of the stud, you might have a chance of getting it out still. The bit will probably break like I described but you should be able to get it out once it's "stuck" and breaks.
chuonthis is offline   Reply With Quote
