Old 12-19-2008, 08:12 PM   #1
nrmskate
nrmskate has a spectacular aura aboutnrmskate has a spectacular aura aboutnrmskate has a spectacular aura aboutnrmskate has a spectacular aura aboutnrmskate has a spectacular aura aboutnrmskate has a spectacular aura about
Extreme help needed now!
Sorry for the title, but, its urgent.
Okay, so I took off the top motor mount bolts to get the oil pan in/out. Now, I can't get the engine back on the mounts. any suggestions?
Ive been at this for about 5 hours and nothin...
nrmskate is offline   Reply With Quote
Old 12-19-2008, 08:28 PM   #2
Slammed Assassin
Slammed Assassin's Avatar
Trader Rating: (34)
Slammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud of
Feedback Score: 34 reviews
Send a message via AIM to Slammed Assassin
try unbolting the mounts off from the bottom of the car. and connect it to the motor. then drop the motor with he mounts on the subframe. theres abit more play so u can get it in.
Slammed Assassin is offline   Reply With Quote
Old 12-19-2008, 09:29 PM   #3
nrmskate
There's where I run into a problem, the bottom motor mount bolts won't break loose.
and ive spent an excess of 7+ hours trying to get them off with:
PB Blaster
Torch
WD-40
Tap and Die or whatever set
Strip set
Nothing works.
Im so fuckin frustrated right now.
Old 12-19-2008, 11:18 PM   #4
wrxn240
wrxn240 is on the path to ruinwrxn240 is on the path to ruin
took me a long ass time to get the mounts on. i had to stick a crow bar under one of the mounts and pry it to get both mounts to line up
wrxn240 is offline   Reply With Quote
Old 12-19-2008, 11:20 PM   #5
wrxn240
PB Blaster
Torch
WD-40
Strip set
Nothing works.
try a breaker bar
Old 12-19-2008, 11:22 PM   #6
Def
You've got to unbolt the bottom mounts unless you can REALLY pry the upper stud outwards and get it to line up with the now raised engine mount bracket.
Why can't you get the bottom nut loose? Did you round it off or something? Just put a 2 ft breaker bar on an extension and socket and crank that sucker right off. If you're trying to do it with a regular rachet, well, that's your problem right there.
Old 12-19-2008, 11:28 PM   #7
sr20boostn20
sr20boostn20's Avatar
sr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of light
Send a message via AIM to sr20boostn20
iv yet to do it with out having the mounts loose.
its tough thing to to a hoist makes it easiest, a floor jack or two helps as well
you might be able to drop the subframe and then install the motor to that that reinstall it on the subframe
sr20boostn20 is offline   Reply With Quote
Old 12-20-2008, 04:57 AM   #8
tre4s13
tre4s13 is an unknown quantity at this point
Send a message via AIM to tre4s13 Send a message via Yahoo to tre4s13
I had the same kind of problem...just jack it back up two pumps with the hoist, put it in the passenger's mount...lower it a TAD and shake the fucking shit out of the motor till it drops down (nothing will get damaged) eventually you will get frustrated and do it
tre4s13 is offline   Reply With Quote
Old 12-20-2008, 09:43 AM   #9
projectRDM
projectRDM's Avatar
Unbolt one of the engine mount brackets off the block, whichever you can get to easiest. Line the other side up, slip the nut on just a hair. Now go to the other side and put the bracket on the mount, then line it up to the block. It's much harder to do obviously then sliding the mounts on to the crossmember, but easier than trying to line the brackets up to both mounts.
FORMERLY R240NA
Old 12-20-2008, 12:58 PM   #10
nrmskate
Okay, a little update.
I have the drivers side on, with the nut on just a few notches.
Now, I just can't get the fuckin passenger side angled up enough to go into the hole.
Ive used prybars and sold steel with 200lbs and it still wont go level enough.
Any ideas?
Old 12-20-2008, 01:06 PM   #11
brett-hancock
brett-hancock's Avatar
brett-hancock is not welcome here anymorebrett-hancock is not welcome here anymorebrett-hancock is not welcome here anymorebrett-hancock is not welcome here anymorebrett-hancock is not welcome here anymorebrett-hancock is not welcome here anymorebrett-hancock is not welcome here anymorebrett-hancock is not welcome here anymorebrett-hancock is not welcome here anymorebrett-hancock is not welcome here anymorebrett-hancock is not welcome here anymore
Man if it was me, I'd take an air hammer with a chisel bit and chisel the nuts off the bottom mount bolts, or cut em with an angle grinder, an just get new mounts!!! IF THEY'RE THAT BAD!!!
brett-hancock is offline   Reply With Quote
