![]() Join Date: Oct 2008
Header is glowing red hot!!!!!
Does any1 know why my friends stock header on his ka single cam glows red hot after driving it? My advice to him is to junk it already, i mean sad but god damn there's something wrong with it every other week. Well anyways if you guys have any suggestions on why this would be happening help me help out a friend.
![]() Join Date: Jul 2007
Trader Rating: (106)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 106 reviews
That's normal. Headers get really hot when you drive the car HARD. Now if they glow everytime you drive it you may be running lean, which is not good.
richen it up. move the dist and see if you get a better idle.
but headers do turn red after a "hard" run.
fS! vlsd ! slim fans ! hid kits ! lug nuts ! http://www.zilvia.net/f/search.php?d...earchuser=bo2o ^^^click^^^ |
Well this is a daily driven car not really a car that gets run hard, it can be a short trip and the headers will get red hot.... so he might be leaning out the motor right? And if the injectors are bad wouldn't it cause it to sputter?
well its an s13 fastback.... this care has had issues since the moment he bought it. He had the cat and exhaust checked out and theres no type of blockage or anything like that.
#15 |
![]() Join Date: Oct 2006
^^mr knowitall again... greeeaaaat.
a rich condition CAN cause excessive heat. the distributor could have moved - retarded timing makes that shit glow like that. or the cat clogged/piping kinked off. i actually seen a muffler innerwall material melt down in front of the stream and cause it. injector issue, etc. I would start at the timing. My SR glows red in the dark the mani and turbine sometimes do... I was tuning a gtir swapped sentra last week and that car had the o2 glowing bc the fellas crank pully rotated and the timing marks were off and he didnt know any better. came over and that shit was RED - i was like so yeah... we're gonna need a ruler, a screwdriver and a plug wrench - i set that bitch to TDC according to my screwdriver, measured the 20 marks distance to the stock tdc mark - marked from the pin over, and set that sucker to "Steve's 20 deg" ![]() hooked up my knockometer, lm1, and ostriches, and did er up. shit runs its balls off now.
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope |
#18 |
You know what he's out of town right now but he should be back by tomorrow or no later than saturday, i should take pics and post im yet to even see it he just told me about it.
#19 |
AFC #1
![]() Join Date: Oct 2003
Header/Manifold glowing is usually fuel burning in the manifold.
Check the Timing first. Usually the case is the ignition timing has retarded to the point were combustion is not completed and hot burning fuel is sprayed into the manifold. Then it finishes burning in the manifold cooking it. Rich/Lean condition will cook other components before the manifold starts to get hot enough to glow after shut down. But he has said there is other problems. 1) Check the Base Timing. 2) Inspect the spark plugs. Read them for color and deposits.
#20 | |
![]() Join Date: Nov 2006
Yeah, I used to have a bad tune and it ran rich and my manifold was glowing red.
Do what he said^^^
#21 |
how does he know its actually glowing red? was the car on a dyno? was the car jacked up, set on stands and revved out? lol
a header doesnt glow red "after" a hard run. it glows red during a hard run. |
#22 | |
#25 | |
AFC #1
It's also one of the 2 big reasons why some people can run the cheapest manifold on ebay and never crack it and another can run the most expensive one or a stock manifold and crack it in a month.
#26 |
![]() Join Date: Jan 2005
Trader Rating: (29)
Ok do the simple shit first. Like others have said: spark plugs and timing.
Then if that does not work you might try getting your injectors rebuild. I had mine done for about $100.00 for all four. Make sure if you do that they use OEM seals! All the after market seal kits that I have found for the Nissan SOHC injectors are a hair too small and they leak. I found that when I did mine the car rans so much better. Better mileage, ran way smoother, and almost passed smog. All four were leaking is what the tech said. |
#27 |
It was still glowing when he popped the hood after he got home, not sure but i would think he left the car running and popped the hood cus he noticed something was up.
