Old 05-15-2008, 01:09 PM   #31
twistedsymphony
twistedsymphony's Avatar
twistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of light
I know this an older topic but it's a good tech topic so my question is best asked here..
... what's the reason for using the USDM bases instead of the JDM bases? The driver's side base on my car is broken, so I was considering doing this mod to fix my base and add some cool new features to my car.
I would think that you'd want to use the USDM housings to keep the mirrors in a LHD configuration but everyone here keeps saying they're using JDM housings with USDM bases which seems odd to me.
twistedsymphony is offline   Reply With Quote
Old 05-15-2008, 01:19 PM   #32
alkemyst
alkemyst's Avatar
alkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nice
Send a message via AIM to alkemyst
you transfer the guts basically to the new mirrors. The housings and bases you use from your current ones AFAIK.
Now my Kensai, I curse you to be a Ronin and with the my remaining spirit I, beseech Chimata-No-Kami, to have you wander through time and distance lands, seeking a new master.
alkemyst is offline   Reply With Quote
Old 05-15-2008, 01:25 PM   #33
upSLIDEdown
upSLIDEdown's Avatar
Location: VA.. And for those that keep PMing me asking what kit I have, it's Origin Stream.
upSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfection
I think the base matters, but not the actual mirror housing. From what I understand, the bases are what the "bad angle" comes from. I need to do this. I have 2 mirrors, and a switch. I don't have stock power mirrors though, I have manual. I only really care about the folding function. I can adjust them just by pushing on them, so I don't see a need in running all those wires to actually move the mirrors too, but I guess I could. I dunno. I remember when I got them, I glanced at them and didn't see how the housing actually came off of the base. Anyone got a pic of that? It's been years since I even looked at them, so I may have just missed it.
upSLIDEdown is offline   Reply With Quote
Old 05-15-2008, 01:52 PM   #34
twistedsymphony
d'oh... I just re-read the tutorial and I caught this that I missed the first time I read it:
JDM housing and triangle mount top (nice and painted body color)
USDM housing and triangle mount bottom (crappy grey plastic)
you can use the JDM ones, but you are retarded if you do. the angle is all wrong so it makes your mirrors almost useless. i tried removeing the metal bracket inside the plastic houseing to see if they are interchangeable and if that would correct the mounting angles, but they are not. The plastic is formed to each one and the metal mounts will not interchange with the mount houseings.
The mirror houseings however, are interchangeable. since i liked my paint better, i kept my USDM housing.
so apparently you can use either and even though the JDM mounts are nicer what makes the mirrors work for LHD or RHD is in the mount itself not the housing... so if you use the JDM ones the viewing angle would be screwed up...
well that sucks... that means I'd need to buy a set of power-folding mirrors AND a new driver's side housing...
Old 05-15-2008, 02:18 PM   #35
upSLIDEdown
you mean driver's side mount?
Old 12-21-2008, 05:56 PM   #36
boostinS14
boostinS14 will become famous soon enoughboostinS14 will become famous soon enoughboostinS14 will become famous soon enoughboostinS14 will become famous soon enoughboostinS14 will become famous soon enough
heres my problem i cant find the right wires i have the kouki switch
USDM switch
JDM switch
wires from USDM chasis
need your help thanks. which wires connects to the JDM switch
boostinS14 is offline   Reply With Quote
Old 12-21-2008, 10:25 PM   #37
projectRDM
projectRDM's Avatar
Why'd you cut the plug off?
The JDM switch, if for the same model and year, is a direct plug in to the US harness. All the wire colors match up perfectly. You will then have two additional wires coming out of the switch, these are the folding in/out signals to the mirrors. In fact, even when using the earlier 94-96 switch, the pin out and wire colors are still the exact same, it just uses a different style plug with larger pins. The folding wires should be light green/black and green/black, everything else is the same.
What I would do is if your wiring doesn't match color to color on the new plug, put the US plug back on and reconnect all your OE wires, using solder and heatshrink of course, then depin the those extra wires not being used from the new plug, and pin them into the two empty spots on the old plug. Basically with the mirror switch left OE, not hacked off like yours is, there's two empty spots on the plug. Those are the folding outputs. You can also just wire the new plug straight matched pin to pin, even if the wire colors don't match, as that plug could be from another car.
FORMERLY R240NA
Old 12-22-2008, 07:30 AM   #38
98s14inaz
98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection
Originally Posted by mrmephistopheles View Post
...Mostly superfluous in the US...
I disagree. I use them daily when parking in my garage. I usually don't have a passenger so I can park all the way to the right side of the garage and I hit the switch to fold them in so I don't hit anything with the mirrors. I usually fold them anytime I park so some dumbass doesn't hit them or break one off. I get some funny looks at the carwash though.
-Retired
98s14inaz is offline   Reply With Quote
Old 12-22-2008, 07:32 AM   #39
98s14inaz
USDM switch
JDM switch
There is a write up on *cringe* NICO. You have to run 2 or 4 (I forget) extra wires from the mirrors to the JDM mirror switch. Once you do that you're golden. The hardest part is threading the wires through the rubber tube in the doors with a coat hanger.
-Retired
Old 12-22-2008, 07:41 AM   #40
94_240sx
94_240sx is on a distinguished road
Originally Posted by alkemyst View Post
Someone has posted that if you swap the bases to USDM the driver side doesn't fold in flush, but sticks out a bit (compared to the passenger side and what the JDM base does).
Anyone have pics of this with USDM bases and JDM folding motors folded in?
Ã…
Yup!! They are not even when folded. I'll try to get some pics for you guys.
94_240sx is offline   Reply With Quote
Old 12-22-2008, 08:13 AM   #41
98s14inaz
There is a reason for that. The angle of the mirrors when unfolded will suck if you use the jdm bases. You won't be able to see shit and no matter how much you adjust the mirror. At the very least, on the driver's side, use the usdm base, there is a tab you need to grind off but you'll see that when you go to reassemble.
-Retired
Old 12-22-2008, 09:34 AM   #42
Marcus
Marcus's Avatar
Trader Rating: (18)
Marcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfection
Feedback Score: 18 reviews
this one isnt. im not sure what switch he has, but the US harness has only a few of the same colors. take another look at the pictures. the jdm switch that he has has 10wires. the us harness has only 7. two of the remaining wires go to the folding mechanism. but what about the other 1?
Marcus is offline   Reply With Quote
Old 12-22-2008, 11:22 AM   #43
projectRDM
projectRDM's Avatar
I did, pics are blurry as hell on my monitor. It's probable that the extra wire is for the defrost option, some JDM cars came with both folding and defrost mirrors. That would be the only thing different but I don't know if the chassis would be prewired for it. Like I suggested though, using the OE plug and pinning the two folding wires in or just wiring straight pin to pin will work fine, the pinout for the mirror control is the same for either switch.
FORMERLY R240NA
Old 12-22-2008, 12:36 PM   #44
Om1kron
Om1kron's Avatar
oh oh oh I want to do this!!! fun fun fun more electrical stuff... *slaps forehead.
Wayne Edwards
https://om1kron.blogspot.com
Old 12-24-2008, 09:59 AM   #45
94_240sx
I swapped both driver and passenger side bases and I can see with no problem, but this happens when folded. They are not even, but that's okay with me.
- They will be even when folded if you use JDM bases, but you can't see anything because angles screwed up.
- They won't be even when folded if you use USDM bases, but you can see rear well.
You can see difference clearly in this picture.
Old 01-03-2009, 11:42 AM   #46
boostinS14
alright guys the 2 wires left on the mirrors are orange and pink the orange wire goes to the Green/black/silver wire and the pink wire goes to the green black wire on the JDM switch
Old 02-25-2009, 02:20 PM   #47
Asmar
Asmar's Avatar
Asmar is an unknown quantity at this point
I'm having problems wiring up my JDM S14 power folding mirrors. I searched various different forums to find an answer but still no answer... I have used the following write-ups:
- S13 Power Folding Mirror Install: 240SX Technical Forum: Nissan Forums / Infiniti Forums - NICOclub
- Write-Up: JDM S14 Power Folding Mirrors - Northwest Nissans
- http://zilvia.net/f/tech-talk/130592...g-mirrors.html
The second write-up on that list is my write-up which shows how to install the mirrors, not how to write them up using the switch I have. Here are pics of what I'm talking about:
Wires from the car:
1. Blue/Black
2. Black
3. Orange
4. Blue/Red
5. Yellow/Blue
6. Purple/White
7. Yellow/Black
Also not pictured are 2 extra wires coming from the mirrors, the Orange and Pink wire which are used for the folding function of the mirrors.
Wires from the JDM switch:
1. Green/Black
2. Purple/White
3. Black
4. Light Green/Black
5. Yellow/Blue
6. Yellow/Black
7. Light Green/Red
8. Light Green
9. Blue/Black
10. Blue/Red
I wired up all the colors that matched and connected the Green/Black and Light Green/Black wires to the Orange and Pink wires (used for the folding function), but still nothing happened. The mirrors won't fold or adjust. There is nothing wrong with the mirrors ad there is nothing wrong with the wiring (by that I mean all wires are connecting the way they are supposed to be connected).
I used this to match up wires on the mirrors:
I matched the wires up the way are supposed to be by looking at this JDM adapter/connecter.
Wires from the car, wires from the JDM switch:
So I don't know I'm doing right or wrong... I can't figure this out... If anyone could help me figure this out that would be really great... Thanks!
Asmar is offline   Reply With Quote
Old 02-25-2009, 05:27 PM   #48
projectRDM
projectRDM's Avatar
Dammit, I hate when people don't read.
Where's your old plug? The pinout is the same. Match pin to pin, simple. The wire colors *should* match but don't always, so don't go by that. Even easier (would have been had you not got crazy with the wire cutters) is to just depin the new plug and take the two folding wires out of it, snap them into your existing plug.
FORMERLY R240NA
Old 02-25-2009, 05:34 PM   #49
Asmar
Asmar's Avatar
I already read your post above about this and it didn't work. If I were to use my old USDM plug with the JDM switch the mirrors should adjust and not fold until I add the extra 2 wires needed to make the mirrors fold. They won't even adjust. Not having the 2 wires connected, the mirrors should still adject but they don't and there is nothing wrong with the wires or the mirrors. Could it be a fuse? If so, what fuse should I check? Also where exactly do I put the 2 extra wires from the JDM plug into the USDM plug?
Old 02-25-2009, 05:41 PM   #50
projectRDM
projectRDM's Avatar
Very easily a blown fuse. You go cut up shit, typically that happens. Check ALL the fuses, inside and out. IIRC the orange wire is the power, check it for +12V also. Make the system work correctly first, then go from there.
FORMERLY R240NA
Old 02-25-2009, 08:30 PM   #51
Asmar
Asmar's Avatar
If I wire up all the USDM wires and not the wires for the power folding function will the mirrors adjust function work?
Old 02-26-2009, 08:36 AM   #52
projectRDM
projectRDM's Avatar
If the switch and mirrors indeed work, yes. Again, the pinout is the same, the JDM switch just adds two wires. There's no other difference in the switch.
FORMERLY R240NA
Old 03-04-2009, 08:32 AM   #53
bewst pewp
bewst pewp is an unknown quantity at this point
nice jdm awesomeness
now i'm deff ordering mine
bewst pewp is offline   Reply With Quote
Old 03-04-2009, 06:11 PM   #54
tinys s14
tinys s14's Avatar
tinys s14 is making his/her stupidity well-knowntinys s14 is making his/her stupidity well-knowntinys s14 is making his/her stupidity well-knowntinys s14 is making his/her stupidity well-knowntinys s14 is making his/her stupidity well-known
could you just install the entire mirror insted of pullin out the motor?
tinys s14 is offline   Reply With Quote
Old 03-04-2009, 06:16 PM   #55
holemilk00
holemilk00's Avatar
Trader Rating: (33)
holemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the roughholemilk00 is a jewel in the rough
Feedback Score: 33 reviews
Nice write up, subscribed....
holemilk00 is offline   Reply With Quote
Old 05-10-2009, 07:38 AM   #56
ViperBiteLV
ViperBiteLV is an unknown quantity at this point
First of all - Thanks for the great instruction. Used it step by step to do my mirror conversion.
Second - I can also approve that if you use USDM base for mirrors, they will not fold evenly on both sides!!! At first I was shocked and thought that one motor might be faulty, but after reading that other's have the same problem, I started to understand why.
Has someboby thought of a way for both mirrors to fold evenly?
ViperBiteLV is offline   Reply With Quote
Old 05-10-2009, 09:24 AM   #57
alkemyst
alkemyst's Avatar
what stops the motors when turning in? If it's a physical block with a draw sensor on the motor...someone should be able to machine the 'block' so it allows it to close inward more.
Old 05-10-2009, 10:15 AM   #58
ViperBiteLV
I think it's a physical block, due to the base angle.. as i can imagine, the JDM base angles make the mirrors fold evely, but the USDM makes one fold more closer to window than JDM and on the other side it doesn't fold as close as needed (as JDM base), because the base angles are different.
Old 06-07-2009, 06:22 PM   #59
twistedsymphony
ok so I FINALLY got time to install these things, everything is wired up but I just have to feed the two folding wires into the connector.
The wiring section of this tutorial seems all screwed up to me
- the switch in the picture is for an S13 (you can tell because it's horizontal and not vertical)
- the connector doesn't look look like the mirror connector in my S14, differen't shape/different pin layout
- the wiring colors don't match up with the factory wiring in my S14
- the section that tells you what wire to connect to what only lists 7 wires and there is 10 on the connector (where are the other 3?)
The wires that come off of my JDM mirrors for the folding function are Pink and Orange... I've hooked them directly to a battery and folded them in and out to confirm this.
Here is a picture of my USDM mirror harness, still wired up, I haven't cut anything. pins 1 and 6 go to the folding function since those are the only pins on the JDM switch that are not used on my USDM connector.
1 - ?
2 - yellow/light blue
3 - yellow/black
4 - light blue/red
5 - light blue/black
6 - ?
7 - orange
8 - (not used)
9 - black
10- pink/white
all I want to know is which pin (1 or 6) is for pink and which pin is for orange.
I'm mid engine swap right now and and the electrical is all hacked up at the moment so I have no 12V available to test this..
I just need to know which pin is for orange and which is for pink.
EDIT:
I played around with the switch on a multi-meter, assuming that the orange wire (pin 7 above) is 12V and the black wire (pin 9 above) is ground then the mirrors should have the
pin 1 - orange folding wire
pin 6 - pink folding wire
thats how I'm going to wire it up, I welcome anyone who is able to correct the above, hopefully this will help someone else.
Old 07-01-2009, 11:42 AM   #60
wbarrett48473
wbarrett48473 is an unknown quantity at this point
I started to take apart my jdm mirrors and noticed some extra wires attached to the mirrors that weren't in any of the other pics.
Can someone tell me if these are in fact the power folding mirrors or something different?
Looks like defrost or something to me, but not sure if they are also power folding.
Any insight would be greatly appreciated!
Thanks
wbarrett48473 is offline   Reply With Quote
