![]() ok so i have a 91 240sx, at first all i would have to do is kick the clutch a few times in order for it to start, but one day it wouldnt start at all, when i turn the key there isnt a sound.. ok so i replace the starter, the battery, and the spark plugs.. i try to start it again, and nothing.. the same thing, its as if trying to start it without pushing down the clutch pedal..
so i get down and push the button under the clutch pedal with my finger and it starts right up.. so i think "ok theres the problem"and it started up fine for the rest of the day. the next day, thinking my car is all fixed i go to start it the same way(with my finger on the button).. only now sometimes when i push the button and turn the key either, nothing happens at all, or it cranks but wont turn over.. my question is.. could the car NOT TURNING OVER, yet STILL CRANKS have something to do with that button?? or do you think i might be facing yet another problem?? please help! ![]() |
#2 | |
#5 | |
battery is more likely though |
yeah i havent had the chance to jump start it, since theres no other car to use around here, but what i did is disconnect the plug from behind the buttin, cut it off and connected the brown and black wire together.. but still no luck, no cranking or anything... maybe i do just need a jump start.. thanx for the advice bro.. keep it coming, its helping..
#7 | |
![]() Join Date: Aug 2008
#8 | |
![]() Join Date: Sep 2005
First... fix your clutch pedal so it hits the interlock switch. Make sure you have spark and fuel. that means (check the condition of those items responsible for fuel and spark). Then verify the timing. If there is a problem with the ignition system, the ecu may have stored a code. If this is for a KA? the only thing's that caused my KA not start, was a starter relay problem and dead alternator.
#11 | |
Maybe it's so much fail in the thread with you in it, read the rest of the post saa! I did read... where he bypassed the relay but it still not cranking AKA something wrong. What he needs to do is get a fresh battery and start over eliminating everything posted by you! WHY are you trolling this thread anyway? LAME
c'mon, both of you guys' advice is important to me, no need to argue.. well i didnt get a chance to work on it today bc of the rain.. hopefully it doesnt rain tomorrow so i can mess with it..
#14 |
![]() Join Date: Jun 2008
I would think that you have 2 different issues if
1. Engaging the clutch switch does nothing when trying to start. 2. Engine "sometimes" cranks but won't fire when engaging the clutch switch. If your engine cranks, but doesn't fire, that's most likely a spark issue (aside from fuel, which I assume you have ruled out). You check the plug wires? Distributor? Alternator? I don't see them listed on your OP. Since the clutch switch simply completes a circuit, I would check the wiring on that. Make sure the ground is good, etc. Since you bypassed it, I would make sure spark isn't your issue. I recently finished rebuilding a motor that cranked but wouldn't fire. We went through 3 distributors before it finally fired. Granted these were used parts, so they were hit and miss. Check spark yo.
#16 | |
#17 |
thanx for the advice guys.. looks like no rain today, and its my day off. so its of to work on this dumb car, ill retry a kick start, and ill try a jump start.. the battery i hae is brand new, like a week old, but ur right it prolly drained.. ill see what i can do.. ill keep u guys posted! zilvia is cool, lots of helpful people.
#18 | |
most diplomatic post in the history of the net. truth is that the net is full of rude , ignorant know it alls who answer regardless of whether they know anything. myself excluded. |
Tags |
s13 starting problem |
