Old 12-28-2008, 11:52 PM   #1
wh0aitznic0
wh0aitznic0's Avatar
wh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enough
Advice on trimming studs ?
I have a pair of 20mm and 25mm bolt in spacers for the front and rear (respectively). To use them with the wheels I have, I would need to trim the studs down a few threads either by grinding or cutting them so they would not smack the back of the wheel. Do you guys have any advice on what tool i should use and what is a better way of trimming them (grinding or cutting) ? I was thinking just taking it to the shop a block from my house and having them straight up cut a few threads off but I would rather do it myself.
SPLparts.com * PoweredByMax.net
Originally Posted by hailandkill View Post
wh0aitznic0 -- has or had a shocker sticker on his car at one point, is asian with a gooey white center
<3
Nothing says, 'I'm broke and still trying', like aftermarket steelies.
wh0aitznic0 is offline   Reply With Quote
Old 12-29-2008, 12:09 PM   #2
!Zar!
!Zar!'s Avatar
Thread a open end lug nut onto the thread before you cut it.
Then spray some wd40 or put some oil onto the thread to help cut through.
Depending on how much you need to take off, grind or cut off the excess.
Make sure to keep lubricated.
After you finish cutting, smoothing out the cut you just made, unscrew the lug nut so it can recut the threads.
After that, just toss it on and torque everything down.
Old 12-29-2008, 12:45 PM   #3
projectRDM
projectRDM's Avatar
Exactly as he said. A bandsaw will make the smoothest, cleanest cut without damaging the threads, a sawzall is next in line. A grinder will cut fine but usually chews up the stud a little making it harder to rethread.
FORMERLY R240NA
