Old 01-02-2009, 11:53 AM   #1
drftmark
drftmark's Avatar
drftmark has a spectacular aura aboutdrftmark has a spectacular aura aboutdrftmark has a spectacular aura aboutdrftmark has a spectacular aura aboutdrftmark has a spectacular aura aboutdrftmark has a spectacular aura about
Removing rear speakers, now car won't start
Ok so the problem is simple yet complicated.
I was removing my rear speakers and the clarion amplifier from my 96 s14.
So I unscrewed/unbolted them. I wanted to get rid of all of the wires also...
So I just cut them off.
Tried to start car now it won't even crank.
I have power in everything, except when I turn to start car the relay just clicks and it doesn't even crank.
Is their a wire that I cut that I need to reconnect or something? Any help would be appreciated.
drftmark is offline   Reply With Quote
Old 01-02-2009, 12:04 PM   #2
drftmark
drftmark's Avatar
Here are some pics:
Wires that REMAIN IN THE CAR, going to tail lights/trunk light etc...
Wires that got cut out:
THEY ARE ALL THE SAME WIRES, just two different pictures.
Old 01-02-2009, 12:07 PM   #3
98koukile
98koukile's Avatar
98koukile will become famous soon enough98koukile will become famous soon enough98koukile will become famous soon enough98koukile will become famous soon enough
Did you snip the fuel pump wire? maybe not fully but it could be grounding on something... this is why I never cut wires haha
Just talking about cars, one at a time
Horsepower sells cars torque wins races -Shelby
98koukile is offline   Reply With Quote
Old 01-02-2009, 12:41 PM   #4
GSXRJJordan
GSXRJJordan's Avatar
No, he didn't cut the fuel pump WIRES (there's 4 of them). You have a starter problem (maybe dead battery?). Get some jumper cables and start that bish back up.
Old 01-02-2009, 12:57 PM   #5
drftmark
drftmark's Avatar
I tried hitting the starter quite a few times with a pipe and no luck, and I will try and jump it again.
I have had starter trouble before but I had it rebuilt not long ago.
Are there any important wires running along the driver side of the car that would do this? If so which color.
and btw I can hear the fuel pump come on and I have fuel pressure.
The problem is the starter is just not cranking.
Old 01-02-2009, 01:08 PM   #6
GSXRJJordan
That's exactly what I said. No, nothing that runs down the driver's side of the interior harness has anything to do with your problem, as you're
getting clicks so it's not your clutch interlock.
Old 01-02-2009, 01:18 PM   #7
drftmark
drftmark's Avatar
I guess I will jack up the car and hit the starter really good and try to start it.
If that doesn't work I guess I will take it out and see what the problem is.
Another thing is there is an alpine security/alarm system that is under the drivers seat.
A bunch of wires are connected to that, so then would it be possible that there is some sort of ignition wire going to it and I maybe have just loosened the connection and it is preventing it from starting?
btw I really appreciate the help
Old 01-02-2009, 01:27 PM   #8
GSXRJJordan
Dude, stop hitting your starter. If you recently had it rebuilt, that's not the problem. GIVE IT SOME JUICE - jumper cables to a running car, jesus.
Have someone else turn the key while you listen for clicks inside the engine bay - if you're getting a starter click, then it has nothing to do with your alarm or wiring - if not, then that might be where your problem is.
Old 01-02-2009, 05:42 PM   #9
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
take a wire, attach one end to the starter and the other end to a good ground.
Bigsyke is offline   Reply With Quote
Old 01-02-2009, 06:06 PM   #10
projectRDM
projectRDM's Avatar
Why in hell would you do that? The starter is not ground triggered. Grounding it will blow a shit ton of fuses.
To the OP, did you cut each wire separately, and tape them all up? You do know there's power leads to the amps, shorting them would blow fuses too, not enough to not start but enough to make a lot of other things not work.
FORMERLY R240NA
Old 01-02-2009, 06:31 PM   #11
redsx13
redsx13's Avatar
redsx13 is an unknown quantity at this point
ya dont do that. just bridge the solenoid
redsx13 is offline   Reply With Quote
Old 01-02-2009, 06:34 PM   #12
redsx13
redsx13's Avatar
i wonder if you may have grounded one of your power wires and fried your ecu. i have seen it done with maf wires....just a thought
Old 01-02-2009, 10:24 PM   #13
drftmark
drftmark's Avatar
I tried jumping it, no luck.
I removed all of the wires completley, and still nothing.
Jacked the front end of the car up, got under, looked at starter, and the freaking clip was somehow disconnected.
Plugged it back in and it cranked right up.
So problem solved, thanks for the help everyone.
Old 06-01-2010, 10:51 PM   #14
canseri
canseri's Avatar
canseri is an unknown quantity at this point
I have been having a similar issue with my car for some time now keys in turn key all relays click and....
Nothing No load nothing ill check the solenoid clip and see what happens.
canseri is offline   Reply With Quote
Old 06-02-2010, 12:02 AM   #15
03redTuscani
03redTuscani is an unknown quantity at this point
Send a message via AIM to 03redTuscani
Thanks for bumping a year old thread to tell us what you plan to do about your problem.
03redTuscani is offline   Reply With Quote
