Old 01-04-2009, 06:53 PM   #1
opponheimer
opponheimer's Avatar
opponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond repute
rb25det turbo manifold... should i resort to stock rather than OBX?
I know most people would say Neither, go full race!
But i have an obx turbo manifold coming in, and an GT3582r turbo. Was curious if some of you would rather run the turbo on the stock manifold as opposed to the obx manifold. I am not sure whether it will crack, but many people seem to think those stainless manifolds are made to crack. The manifold also has a 40mm wastegate flange (which is rather small).
So run the stock one (and weld on a 50mm wastegate flange) or run the obx and gain top end at a risk of it cracking?
If i do run the obx manifold i plan on beefing it up a bit... was curious what types of things i should do; ie: slot the runners on the flange, reweld seams, add bracing, etc..
Thanks
opponheimer is offline   Reply With Quote
Old 01-04-2009, 07:04 PM   #2
sillyvia13
sillyvia13's Avatar
sillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfection
run it if it breaks weld it.
sillyvia13 is offline   Reply With Quote
Old 01-04-2009, 09:49 PM   #3
SuperiorS14
SuperiorS14's Avatar
SuperiorS14 is making his/her stupidity well-knownSuperiorS14 is making his/her stupidity well-knownSuperiorS14 is making his/her stupidity well-knownSuperiorS14 is making his/her stupidity well-knownSuperiorS14 is making his/her stupidity well-known
re-enforce it before using it. get some braces welded onto the exhaust flange to support the weight of the turbo.
thats what all the supra guys do with the ebay manifolds for 2j's
SuperiorS14 is offline   Reply With Quote
Old 01-05-2009, 02:31 AM   #4
Yellow4g63
Yellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of light
Send a message via AIM to Yellow4g63
Save some coin and get the 6boost manifold. I think it's like 800-900 AUD. Full merged collector or twin scroll. Or just mod the stock manifold for a external gate and bolt on a bigger turbo.
95 240sx RB20 415whp
91 Nx2000 VVL yo
Yellow4g63 is offline   Reply With Quote
Old 01-05-2009, 07:54 AM   #5
g6civcx
g6civcx's Avatar
Anything other than cast iron will eventually break. So run what you want and prepare to replace/repair later, or port out your stock cast iron however you want. Your choice.
Old 01-05-2009, 08:21 AM   #6
smelly240
smelly240's Avatar
LOL - cast iron is less likely to crack but it can
Because its cast doesn't mean it wont break. They cast ones crack when u beat on them with a heavy turbo. hell - stock manifolds crack on NA cars where theres less pressure/heat.
I am not saying its not better than a obx. obx is whack. But the stock one with a 35r? wtf - dont do that.
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope
Old 01-05-2009, 08:27 AM   #7
g6civcx
g6civcx's Avatar
I thought it was clear that anything can break. Cast iron is stronger than aftermarket material.
With improper use or inadequate bracing though, anything can break.
Old 01-05-2009, 01:06 PM   #8
ANVIL
ANVIL's Avatar
ANVIL can only hope to improve
do this. if u spend the money to get the obx, and then modify to to make it "better" ur probablly halfway to the 6boost one which is one of the if not the best manifold out there from what ive seen. they are also VERY knowledable and can also make custom to your setup to benefit you the most.
ANVIL is offline   Reply With Quote
Old 01-05-2009, 02:08 PM   #9
Yellow4g63
There merge collector is the best I have seen. Everyone else just puts them 3 in a row. His is circle which is hard to do for a Inline 6.
91 Nx2000 VVL yo
