Old 01-06-2009, 07:12 PM   #1
CmR333
CmR333's Avatar
CmR333 is an unknown quantity at this point
s13 sr shifter parts(what do i need)
Ok i was modifying my shifter today and came across a weird dilemma. I was cutting the stock shofter while it was in the car to change the angle of it to fit the rx8 and the shifter popped out.. i have never removed the shifter before so im not to sure what all hold it together. what was in there is a small palstic ring that was on top and the shifter was sitting in the white cup with the two pegs in it. there was a snap ring on top of it all but it seems to small to snap into anything. i have 2 pics of the assembly i took out and the 3 parts that came out with it. im not to familar with the sr trans and i know there cant be to much to it. wanna help me out here guys?
CmR333 is offline   Reply With Quote
Old 01-06-2009, 07:52 PM   #2
projectRDM
projectRDM's Avatar
There's another larger snap ring. Yours seems to have gone away. You're also missing the wave washer that sits below the pivot.
FORMERLY R240NA
Old 01-06-2009, 09:19 PM   #3
CmR333
CmR333's Avatar
ok so let me see if i got this....from the bottom up it goes. wave washer,white cup bushing thing,shifter,top plastic ring. then big then little snap ring? If so can i get the ka guts from a ka trans? i was wanting a short shifter but im not wiling to hack it up to make it work on my car. is there a nice set of spherical bearings that i can get for the stock stick? thanks
Old 01-06-2009, 09:33 PM   #4
rb25_s13*CHUKI
rb25_s13*CHUKI's Avatar
Yes you can use the snap ring and wave washer from the ka.. you can use the ka shifter and plate as well.. And your shifter look funkay
Obliterate
rb25_s13*CHUKI is offline   Reply With Quote
Old 01-06-2009, 09:40 PM   #5
CmR333
CmR333's Avatar
i havent dressed the welds but i made them beefy because of the bend. its about 2" shorter and is set perfect for the way i like to drive. i just wish i could shorten the throw.thanks for the answers
Old 01-06-2009, 10:14 PM   #6
JRas
JRas's Avatar
JRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfection
Send a message via AIM to JRas
I just messed with mine yesterday.. removed it to pour in new fluid.
it's the c-clip that holds it in, you will need snap ring pliers to remove and put it back on available at sears or an autostore
JRas is offline   Reply With Quote
Old 01-06-2009, 10:19 PM   #7
handinpants
FreshColdBeer.com
handinpants's Avatar
Trader Rating: (48)
handinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud of
Feedback Score: 48 reviews
Send a message via AIM to handinpants
yeah its the c clip. i had mine come out when i was driving... but i fixed it, and later bought a b&m short shifter. you know i have a shifter thing for sale in my sale thread, for $15 with free shipping, if you want an extra one in case this one doesn't work for you
handinpants is offline   Reply With Quote
Old 01-07-2009, 07:24 AM   #8
projectRDM
projectRDM's Avatar
KA transmission is the exact same so you can use KA parts. You knew that.
FORMERLY R240NA
Old 01-07-2009, 10:15 AM   #9
CmR333
CmR333's Avatar
just had to make sure lol thanks for the info guys it helped alot.
