Old 01-10-2009, 01:33 PM   #31
JRas
JRas's Avatar
JRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfection
Send a message via AIM to JRas
Originally Posted by reinvent View Post
Check your clutch fan. It should rotate about 6 inches when engine cold or about one third revoltion if car has been on.
maybe he forgot to plug it back in? worth a try
JRas is offline   Reply With Quote
Old 01-10-2009, 01:52 PM   #32
S14DB
AFC #1
S14DB's Avatar
How do you plug in a clutch fan?
Old 01-10-2009, 02:27 PM   #33
reinvent
reinvent is an unknown quantity at this point
I think he means the silicone has drained out. I wish these fans were not on all the time. The so called slow speed must tax the electrical system during idle.
The air temperature coming through the radiator is sensed by the bi-metal thermal spring on the front of the thermal fan clutch. It expands and contracts with the change in air temperature operating a valve inside of the clutch. When cold, the silicone drive fluid is pumped from the working area to the reservoir. When hot, the valve opens allowing fluid from the reservoir to be transferred to the working area thereby increasing the fan speed. The clutch disengages as the air temperature decreases, closing the valve and allowing the silicone fluid to be pumped back into the reservoir.
reinvent is offline   Reply With Quote
Old 01-10-2009, 03:06 PM   #34
reinvent
hkjhkjhk hhhhhhhhhhhhhhhhhhhhhhh
Old 01-10-2009, 04:25 PM   #35
theronin
theronin's Avatar
theronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfection
Send a message via AIM to theronin
rofl
/msglength
Originally Posted by HalveBlue View Post
That first picture is totally bad ass.
It just screams, "Hey, I'm a fucking Christmas Tree. What are you gonna do about it?"
theronin is offline   Reply With Quote
Old 01-10-2009, 05:45 PM   #36
JRas
JRas's Avatar
my bad, thinking of the other fan, don't know the technical name for it..
but I guess that wouldn't cause it to overheat either, right?
funny, I admit
Old 01-10-2009, 05:46 PM   #37
S14DB
AFC #1
S14DB's Avatar
AC fan.
Old 01-10-2009, 06:02 PM   #38
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
I run no clutch fan, I have an altima fan triggered @ 203f off of the OEM harness (cooling fan relay 1). My fan rarely comes on, and im running no egr. How are you guys having so much trouble?
I installed a new OEM thermostat with the jiggle valve installed this time because it was taking too long to get to warm up temp. Then again I have no A/C, so maybe im running more efficient.
Maybe you guys need to remove the lime/calcium deposits in your head/block
Bigsyke is offline   Reply With Quote
Old 01-24-2009, 09:34 PM   #39
240tuned91
240tuned91 is an unknown quantity at this point
its not fuking up filling the rad. i think hes trying to say he cant get it to burp or simple just cant get the thermostat open. im havig the same problem
240tuned91 is offline   Reply With Quote
Old 01-25-2009, 04:46 PM   #40
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
Test it. Boil it in water.
I just removed the jggle valve and am going to put it back in today. i can't deal with it running on the cold fuel map. Backfiring like Jesus.
SochBAT is offline   Reply With Quote
Old 01-25-2009, 05:28 PM   #41
TheRealNighthog
TheRealNighthog is an unknown quantity at this point
You should just get a new OEM thermostat. I have never used a nismo therm. and I track my car alot. Never had a problem with cooling either.
TheRealNighthog is offline   Reply With Quote
