Old 01-10-2009, 08:58 PM   #1
s14kings
s14kings is an unknown quantity at this point
Acceleration high pitch noise from motor
So I have this noise coming from my motor (i think since its from the engine bay) and I have no idea what it is. It occurs when I accelerate between about 2k - 3k rpm. It's a high pitched noise when I throttle but doesn't occur when it's in neutral. Noise occurs throughout all gears, but not as much when in first. I thought at first it was pinging from low octane but I've been pumping 91 for a while and no change. It's also not a vacuum leak. Any help? Thanks.
*edit* I have a ka24de
s14kings is offline   Reply With Quote
Old 01-10-2009, 11:56 PM   #2
scuba_steve91
scuba_steve91's Avatar
scuba_steve91 is an unknown quantity at this point
My ka24e does the same, kind of. When I drive from 2k-3k rpm, the engine starts getting unusually loud as it approachs 3k. Similiar to your problem, it occurs in all gears. Maybe it has something to do with our compression.
scuba_steve91 is offline   Reply With Quote
Old 01-20-2009, 10:57 PM   #3
s14kings
Could anyone help us out? I'm stumped on this one...
Old 01-20-2009, 11:13 PM   #4
artdrifter
artdrifter is an unknown quantity at this point
wish i could help but i have the same problem with my SR. i'm about to take it to Amerikajin to get it fixed
artdrifter is offline   Reply With Quote
Old 01-25-2009, 04:00 PM   #5
s14kings
Help? Friends and a mechanic couldn't tell me what it was either.
Old 01-26-2009, 12:20 AM   #6
alzahakar
alzahakar's Avatar
alzahakar has a little shameless behavior in the past
A slipping belt perhaps? 2500-3000ish is when the belt will start slipping on the water pump pulley when you have a bad fan clutch.
alzahakar is offline   Reply With Quote
Old 01-26-2009, 07:46 AM   #7
98s14inaz
98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection
PS pump makes a whine when it is going out. Also make sure you have atf in the ps pump. Other than that I got nothing,
-Retired
98s14inaz is offline   Reply With Quote
Old 01-26-2009, 07:55 AM   #8
Erjay1
Erjay1's Avatar
Erjay1 is making a name for him/her selfErjay1 is making a name for him/her self
Maybe someone installed a supercharger while you slept one night
I'd check the fluid level of you PS pump.
Erjay1 is offline   Reply With Quote
Old 01-26-2009, 08:41 AM   #9
aziankingz
aziankingz's Avatar
Trader Rating: (28)
aziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really nice
Feedback Score: 28 reviews
i have the same thing and i also have a ps problem.. could it be the powersteering belt/pump going? mine is a kind of whining plus ticking noise at about 2500-3k rpms.. do you guys have ticking as well?
aziankingz is offline   Reply With Quote
Old 01-26-2009, 03:19 PM   #10
supreme_1
supreme_1 is on the path to ruinsupreme_1 is on the path to ruinsupreme_1 is on the path to ruin
i have the exact same problem with my m30. vg30e.
i changed the power steering setup so it isnt that.
if worse comes to worse. take a belt off one at a time on your motor, if you dont hear the noise after you take certain belts off you then found your problem.
supreme_1 is offline   Reply With Quote
Old 01-26-2009, 03:34 PM   #11
slider2828
slider2828's Avatar
Look at adjustments of the belts. Check for slack also look at wear of the belts as well. Maybe also clean your pulley a little as well.
Check oil levels of tranny and engine, hopefully those are all ok...
Turn and Burn!
Old 01-26-2009, 04:05 PM   #12
aziankingz
aziankingz's Avatar
Trader Rating: (28)
could it be transmission related?
