Old 01-11-2009, 01:21 PM   #1
amdnivram
amdnivram's Avatar
amdnivram is an unknown quantity at this point
Send a message via AIM to amdnivram
crappy mileage on a ka?
well since i got my car, ive noticed really horrible gas mileage. I'm getting 10-11 mpg on my car, its a 89 240 hatch. It has a 93 ka24e, stock everything except for the intake. doesn't need an oil change or filters. where should i begin or is this normal?
amdnivram is offline   Reply With Quote
Old 01-11-2009, 01:24 PM   #2
murda-c
murda-c's Avatar
unless you're racing...not normal.
are your brakes dragging? lol
Old 01-11-2009, 01:33 PM   #3
amdnivram
amdnivram's Avatar
nope lol my brakes arent dragging. I trying to find the cause of this terrible gas mileage.
Old 01-11-2009, 01:34 PM   #4
JoHn E
JoHn E's Avatar
JoHn E is an unknown quantity at this point
is the chekc engine light on?
JoHn E is offline   Reply With Quote
Old 01-11-2009, 01:39 PM   #5
SilviaBricks
SilviaBricks's Avatar
SilviaBricks is a glorious beacon of lightSilviaBricks is a glorious beacon of lightSilviaBricks is a glorious beacon of lightSilviaBricks is a glorious beacon of lightSilviaBricks is a glorious beacon of lightSilviaBricks is a glorious beacon of lightSilviaBricks is a glorious beacon of lightSilviaBricks is a glorious beacon of lightSilviaBricks is a glorious beacon of lightSilviaBricks is a glorious beacon of lightSilviaBricks is a glorious beacon of light
Id pull the plugs, they are gonna be fouled from running rich. You probably have an injector or two stuck open flooding a cylinder, then check maf and o2.
you mean de right?
SilviaBricks is offline   Reply With Quote
Old 01-11-2009, 01:43 PM   #6
amdnivram
amdnivram's Avatar
no its a ka24e. as far as the cel, it isnt working, i think the bulb burned out. I'll give the injectors a look.
Old 01-11-2009, 01:59 PM   #7
amdnivram
amdnivram's Avatar
if i do have a stuck injector, how do i fix it?
Old 01-11-2009, 02:02 PM   #8
Sthrteen
Sthrteen is an unknown quantity at this point
interesting. im getting 23mpg and something is wrong with my motor could get better once I fix the issue im having
Sthrteen is offline   Reply With Quote
Old 01-11-2009, 02:02 PM   #9
NISMO_tuner
NISMO_tuner's Avatar
Trader Rating: (64)
NISMO_tuner is an unknown quantity at this point
Feedback Score: 64 reviews
Send a message via Yahoo to NISMO_tuner
if its a ka24e its a single cam off a 89-90
cant be 93
if the injector is stuck open, best bet is to swap em out
check your maf, o2 sensor, and find out if your running too rich
if your car reeks of gas when u run it then ur probably running too rich
Check my for sale thread for S13 parts
NISMO_tuner is offline   Reply With Quote
Old 01-11-2009, 02:06 PM   #10
amdnivram
amdnivram's Avatar
yeah, it does reek of gas when its running, how much will fixing it cost me? yeah i was thinking of something else lol i was going to get a dual cam 93 to swap that in, but i'd rather wait till sometime in the future for a sr.
Old 01-11-2009, 05:34 PM   #11
amdnivram
amdnivram's Avatar
anyone know what replacing the injectors usually runs?
Old 01-11-2009, 06:01 PM   #12
YoungRookie
YoungRookie's Avatar
YoungRookie will become famous soon enoughYoungRookie will become famous soon enoughYoungRookie will become famous soon enoughYoungRookie will become famous soon enough
Send a message via AIM to YoungRookie
I doubt that you are going to need to replace the injectors. My guess is that your bad gas mileage is the result of a bad o2 sensor. Call your local auto parts and get a new o2 sensor, replace that and see if that fixes it. If that doesnt fix it then move on to the next thing and at least you know your o2 sensor is good then.
92 Hatch, KA-T, T28, 12 PSI, FMIC, 3" TBE, EFI ECU, 440cc Inj, And more...
YoungRookie is offline   Reply With Quote
Old 01-11-2009, 06:04 PM   #13
s13_ricky
s13_ricky is an unknown quantity at this point
I get about 19-21 depending on how I drive in my 93 Hatch (DOHC)
s13_ricky is offline   Reply With Quote
Old 01-11-2009, 06:10 PM   #14
amdnivram
amdnivram's Avatar
should i replace the cel bulb? im really not sure whats wrong with the cel, or if it even works properly. i'll get an start on the running rich tomorrow i guess =/ lol
Old 01-11-2009, 06:24 PM   #15
YoungRookie
i would go ahead and replace the cel bulb. I mean it wouldnt hurt anything.
Old 01-11-2009, 06:34 PM   #16
WagDatto
WagDatto's Avatar
WagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfection
Send a message via AIM to WagDatto
If you're going to use this motor until you get an SR in the future, I'd go ahead and give it a general tune up regardless of what's wrong with it. Why not, right? All total, it wouldn't cost you too much if you do it all yourself. New O2 sensor (sounds like the culprit!), oil change, air filter change, check the MAF just in case, and get new spark plugs and wires.
If general maintenance doesn't fix it, you might be looking at new injectors.
http://garagezoku.blogspot.com
WagDatto is offline   Reply With Quote
Old 01-11-2009, 06:55 PM   #17
JRas
JRas's Avatar
JRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfection
Send a message via AIM to JRas
agreed
what do you mean you think it burned out? turn the ignition to the on position and it will light up all the bulbs... if the CEL is off than it's burned out.
If I had to guess, I'd say MAF or O2 sensor
JRas is offline   Reply With Quote
Old 01-11-2009, 06:59 PM   #18
amdnivram
amdnivram's Avatar
yeah it wont turn on when the its in the on position so its burned out. i'll do the tune up and see what happens.
Old 01-11-2009, 07:09 PM   #19
JRas
JRas's Avatar
go get the codes scanned, fix the light, than do the tune up..
Old 01-11-2009, 07:39 PM   #20
lflkajfj12123
i have a 91 dohc im getting about 13 mpg car is about to hit 190,000 miles
have a feeling its my fuel pump
car was maintained very well from previous owner he gave me an extra fuel pump but i dont know how old or what model it is so maybe he was hinting it needs a new one
maybe o2 sensor shit i dont know
Old 01-11-2009, 10:03 PM   #21
amdnivram
amdnivram's Avatar
yeah i'l get the light fixed, code scanned and then fix whats necessary .
Old 01-11-2009, 10:08 PM   #22
ChicagoS14
ChicagoS14's Avatar
ChicagoS14 is making a name for him/her selfChicagoS14 is making a name for him/her self
Send a message via AIM to ChicagoS14
Don't have to replace, you can rebuild. SOHC injectors are top feed so they shouldn't be that much, when I had my MSD 52lb top feed domestics style injectors rebuilt / cleaned by FIC ( Fuel Injector Clinic )
Fuel Injector Cleaning and Flow Testing - Fuelinjectorclinic
For my KA-T project since I bought them used with unknown mileage/condition on them it cost me like $76 total with shipping back to me. Thats roughly $19 per injector with tax and return shipping. Took one day plus the shipping time.
95 240SX 1JZGTE | SC300 2JZGE daily
www.240sxguide.com
ChicagoS14 is offline   Reply With Quote
Old 01-11-2009, 10:09 PM   #23
mikemadison_09
mikemadison_09's Avatar
mikemadison_09 is an unknown quantity at this point
o2 sensor. my car was getting prob 8 miles to the gallon. now i got the new o2 sensor its a world of difference. now i get like 20 mpg
mikemadison_09 is offline   Reply With Quote
Old 01-11-2009, 10:13 PM   #24
blackrms13
blackrms13's Avatar
just take out ur ECU and check for codes if u think the bulbs is burnt
91' 240sx Fastback LE
blackrms13 is offline   Reply With Quote
Old 01-11-2009, 10:23 PM   #25
daverussell
daverussell's Avatar
daverussell is a jewel in the roughdaverussell is a jewel in the roughdaverussell is a jewel in the roughdaverussell is a jewel in the roughdaverussell is a jewel in the roughdaverussell is a jewel in the roughdaverussell is a jewel in the rough
Send a message via AIM to daverussell
OK, I just had a similar problem with my SOHC coupe. Do a FULL tune up on your car. Air filter, fuel filter, plugs, wires, cap, rotor button oil filter and an oil change. Also, check the injector plugs. That is what the problem was with mine. The injector plugs were bad and my number 2 cylinder was not firing properly. I replaced them all with the smallest female spade connectors I could find and heat shrank them all. I also did the O2 sensor, coolant temp sensor and the fuel pressure regulator. I think all my bases are covered and I will let you know about the MPG later. BUt try those things. It may be as simple as that.
I never know what to put here.
daverussell is offline   Reply With Quote
Old 01-11-2009, 10:40 PM   #26
koops240
koops240 is an unknown quantity at this point
i have the same problem...but on a de
i used to get around 25-26 mpg.
now im getting 19-20
i have new o2 sensor, new plugs, new injectors, new cap and rotor, new wires..
would a new fuel pump affect excessive gas consumption? would an egr code affect gas consumption as well? how do i check if the injector is stuck open?
i didnt check the timing after i replaced the cap and rotor...do i need to do that as well because i don't seee the point in checking the timing if i didnt move/rotate the distributor.
koops240 is offline   Reply With Quote
Old 01-14-2009, 02:54 AM   #27
koops240
can any1 help?
Old 01-14-2009, 12:09 PM   #28
lightsource
lightsource's Avatar
Trader Rating: (41)
lightsource is an unknown quantity at this point
Feedback Score: 41 reviews
Send a message via AIM to lightsource
I have an SR, I upgraded my fuel filter & fuel pump at the same time, my mileage doubled.
You didn't list those two, so chances are they'll give you a good up in gas mileage.
lightsource is offline   Reply With Quote
Old 01-14-2009, 12:22 PM   #29
ricebike
ricebike is an unknown quantity at this point
i'm confused becuase the OP listed that he has an 89 shell, but a 93 DOHC transplanted engine, is that right? so was the wiring harness and DOHC ECU came w/ that and installed properly?
side note to koops, you just may be running on winter gas blend since your mpg isn't as drastic as the OP
in both cases, pull the trouble codes from your vehicle's pc and update us
ricebike is offline   Reply With Quote
Old 01-15-2009, 01:46 AM   #30
SR20DET KOUkI S14
SR20DET KOUkI S14 is an unknown quantity at this point
im also getting bad gas mileage, i have a 95 ka24de with new o2 sensor, new spark plugs and wires about 1000miles on them same with the injectors, but im running a 300zx fuel filter and a 255 walbro fuel pump. would that cause it to get less gas mileage.
my mods are s13 cams, pulleys, intake, exhuast.
i just want good gas mileage, also it smells like gas when i drive then i park it i smell it. how do i check if running rich
SR20DET KOUkI S14 is offline   Reply With Quote
