Old 01-14-2009, 07:31 PM   #1
SnakeKack
SnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of light
Send a message via AIM to SnakeKack
350z wheels rubbing.
I got 17 inch Z wheels on the car. The fronts are rubbing against my coils. The tires and I think a bit of the lip. Do I need spacers and how much of a space should I use?
SnakeKack is offline   Reply With Quote
Old 01-14-2009, 07:38 PM   #2
SnakeKack
Sorry i forgot to mention I got 245/40/17 in the front
Old 01-14-2009, 08:15 PM   #3
khilgers
khilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond repute
seriously? Move them away to gain clearance, measure, buy spacers. If you space them more than 5MM I would probably get extended lugs.
khilgers is offline   Reply With Quote
Old 01-14-2009, 08:23 PM   #4
2toneluv
2toneluv's Avatar
2toneluv is an unknown quantity at this point
go to ichubusa.com get a 10mm bolt on spacer. make sure after you bolt the spacers down drive for a lil bit then take your wheels off and tighten them up again as the metal will cruch a lil keep an eye on torqueing yor wheels down too unless you wanna loose them on the freeway
2toneluv is offline   Reply With Quote
Old 01-14-2009, 08:27 PM   #5
Mathetai
Mathetai is a name known to allMathetai is a name known to allMathetai is a name known to allMathetai is a name known to allMathetai is a name known to allMathetai is a name known to allMathetai is a name known to allMathetai is a name known to allMathetai is a name known to allMathetai is a name known to allMathetai is a name known to all
Why are you running a 245 up front? Are the 17" 350z wheels like 17x7.5 or something like that? Try a 225 up front. I am running them on one of my verts with no issues.
Mathetai is offline   Reply With Quote
Old 01-14-2009, 08:34 PM   #6
sausage180
sausage180's Avatar
sausage180 has a spectacular aura aboutsausage180 has a spectacular aura aboutsausage180 has a spectacular aura aboutsausage180 has a spectacular aura aboutsausage180 has a spectacular aura aboutsausage180 has a spectacular aura about
Spacers are what you need! Whenever you buy new aftermarket coils, you'll always need spacers.
sausage180 is offline   Reply With Quote
Old 01-15-2009, 08:01 AM   #7
SnakeKack
Thanks guys. So 10 MM seems like that's what I need?. I'll have to order them.
I think 225 would work too but it still looks like it hits the lip just barely. I'm gonna put my old SEs on there until I get the spacers. Reason I'm running them is each one of these tires sell for about $215 a piece. They are all brand new and I got them for 50 bucks a piece so I said screw it. I seen other forum members fit 245s up front with wider wheels so I was hoping they'd fit. I really needed tires bad. All 4 were at like 0 tread life and just driving normal when a light turns green I would just sit there and spin lol.
Old 01-15-2009, 09:03 AM   #8
redline racer510
redline racer510's Avatar
redline racer510 is on the path to ruinredline racer510 is on the path to ruin
245 on a 350 z wheel is dumb for one i bet its all bubbled out looking like a balloon second your messing up your wheels and tires
redline racer510 is offline   Reply With Quote
Old 01-15-2009, 11:26 AM   #9
5t341tH
5t341tH's Avatar
5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute
Send a message via AIM to 5t341tH
its the offset that makes it rub...go get 5mm spacer, if not get 10. whatever works
lexus baby
5t341tH is offline   Reply With Quote
Old 01-15-2009, 02:32 PM   #10
smokin 14
smokin 14's Avatar
smokin 14 is an unknown quantity at this point
Send a message via Yahoo to smokin 14
I have g35 wheels with 215 40 18 no spacers not rubbing at all 225 are good to.
smokin 14 is offline   Reply With Quote
Old 01-16-2009, 07:55 PM   #11
SnakeKack
Nope not at all. And I put my old SEs on there for now. They rub too though but I'd rather ruin those old ass tires.
