Old 05-27-2003, 06:08 PM   #1
red_s14
red_s14's Avatar
red_s14 is an unknown quantity at this point
Question back brakes
I recently put on OEM brembo rotors and the back discs are not moving freely without the e-brake on. Do the back pistons on the calipers twist in? i tried c-clamping them in but they did not move too much. help'd be appreciated
red_s14 is offline   Reply With Quote
Old 05-27-2003, 06:45 PM   #2
mrmephistopheles
mrmephistopheles's Avatar
they rotate back in, clockwise, iirc. your local auto parts store probably sells a tool to accomplish this, however it CAN (although it's not a good idea to) be done with needlenose pliers.
Originally Posted by PHLIP
Old 05-27-2003, 07:45 PM   #3
Red
Red's Avatar
Red is an unknown quantity at this point
Get the tool and save your hands... I dont know if mine are just very hard to get in or if its this way with them all... I used needle nose and I cramper up my hand on the second one.. It also slips off alot and you could poke your seal... (Not good) I am guna get the tool next time I do mine.
http://www.cardomain.com/memberpage/509537
http://www.imagestation.com/album/?id=4287415487
http://www.zilvia.net/f/showthread.php?t=21036
Red is offline   Reply With Quote
Old 05-28-2003, 02:57 AM   #4
xrockoutx
xrockoutx has a spectacular aura aboutxrockoutx has a spectacular aura aboutxrockoutx has a spectacular aura aboutxrockoutx has a spectacular aura aboutxrockoutx has a spectacular aura aboutxrockoutx has a spectacular aura about
Send a message via AIM to xrockoutx
i paid $8 for the tool..so it's not too expensive. It looks like a little weird hollow cube. You might have a hell of a time finding one..i had to go to 4 different stores.
xrockoutx is offline   Reply With Quote
Old 05-29-2003, 12:32 AM   #5
twitchy
twitchy's Avatar
twitchy is an unknown quantity at this point
did it fine with needlenose pliers
be gentle and take your time.
Lubricate the slider pins when your in there, and use some never sieze (just a very thin film) on the back of the rotors where they press against the...hub (?)
this makes things easier next time to work on and more pleasurable to do your own brakes
good luck
Who the hell needs a sig anyhow
twitchy is offline   Reply With Quote
