Old 05-29-2003, 01:16 AM   #1
justeno_heat
justeno_heat is an unknown quantity at this point
Send a message via AIM to justeno_heat
SR20 cranks but don't fire over
I just can't figure it out. I have everything hooked up from what I can see and I go to turn on the car and the starter cranks but it don't fire over. There is no fuel being pumped because there is no signal to the pump. And there is no spark in the engine. I'm not getting enough current or something because my ECU light comes on when I plug it in.
'91 Nissan 240sx
Redtop SR20DET
Stock T25 8 PSI
Bomex body kit
B&M short shifter
ADR 17" rims
2 10" JL Audio W3's with Kenwood head unit
Erebuni carbon fiber hood
Koyo aluminum radiatior
240 down for the Summer FROWNING
If NISMO stands for Nissan Motorsports, wouldn't Honda Motorsports be HOMO?
justeno_heat is offline   Reply With Quote
Old 05-29-2003, 01:20 AM   #2
aeontony
aeontony is an unknown quantity at this point
Ladies and gentleman we have another one.
Well obviously it's not going to fire if there's no fuel.
As for not having enough current to the spark plugs, the ECU light has nothing to do with it. The ECU light indicates malfunctioning sensors..
Did you do the harness yourself? I'm not too clear for S13s but for S14s the pump goes to a connector that you have to modify the harness for. I believe your problem lies in the harness..
S14.5 for sale. Must move on with life...=(
http://www.zilvia.net/f/showthread.php?t=56822
Au no wa wakare no hajime...
aeontony is offline   Reply With Quote
Old 05-29-2003, 08:08 AM   #3
nrcooled
nrcooled's Avatar
nrcooled is an unknown quantity at this point
Send a message via Yahoo to nrcooled
Most times when people come on the board saying "it won't fire" its the fuel lines or fuses. Check to make sure the your fuel lines aren't switched (supply and return) Then check your fuses and harness.
Good luck
NR
'91 hatch w/ SR Sold; '03 Evo Sold 401 HP; '03 MS Protege sold; '00 Evo 6.5 TME Sold 300HP
nrcooled is offline   Reply With Quote
Old 05-29-2003, 04:50 PM   #4
justeno_heat
I take the fuel line off and there is no fuel coming out. I said I checked for the signal at the pump and there is none.
'91 Nissan 240sx
Redtop SR20DET
Stock T25 8 PSI
Bomex body kit
B&M short shifter
ADR 17" rims
