Old 01-24-2009, 11:55 AM   #1
Rittmeister
Rittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really nice
Power FC question
Just picked up a PFC from the good folks at RT Tuning; installed it yesterday.
Setup is: redtop DET, stock turbo/boost/fuel/air, except for big intercooler, big exhaust, and Walbro fuel pump.
The car ran great with the stock ECU. With the PFC it starts up, idles, and drives fine EXCEPT that it bogs on tip-in when starting from a stop. If I rev the engine out to 4-5k before shifting, no problem, but if the revs drop below 2k or so it also bogs on shifting.
Here's the weird part - the problem completely disappears when the car warms up past 50*C or so. I mean completely, not even a hint of the issue.
-Timing is dead on where it should be.
-Car doesn't leak vacuum or boost that I can tell - holds vac on the gauge perfectly. Admittedly I haven't built a pressure tester to check this but as it ran fine with the stock ECU I see no reason to believe there's a problem.
-Plugs, TPS, fuel pressure, other stuff is fine.
Basically, has anyone had a similar issue, and if so what was the solution? Is the PFC an adaptive ECU like the stock ECU?
Also, on a side note: the PFC doesn't have a provision for mounting the stock ECU bracket. How are you guys securing the ECU itself inside the kick panel?
E36 M3 - new project
1990 240SR - screamed down the road
Rittmeister is offline   Reply With Quote
Old 01-24-2009, 12:00 PM   #2
S14DB
AFC #1
S14DB's Avatar
Did you let it idle for 10mins then turn on the AC and rear window defroster for 10mins before driving it the first time?
Old 01-24-2009, 12:31 PM   #3
silentstyle1
silentstyle1 is just really nicesilentstyle1 is just really nicesilentstyle1 is just really nicesilentstyle1 is just really nicesilentstyle1 is just really nicesilentstyle1 is just really nicesilentstyle1 is just really nicesilentstyle1 is just really nicesilentstyle1 is just really nice
Send a message via AIM to silentstyle1
Ok I know nothing about the PFC but i figured i'd check this out anyway, cause i like learning new stuff.
But I kinda wanna know what that will do.... S14DB I know you know your stuff. Just want to clear up that I'm not trying to start anything or argue with you, just really curious as to how that would have an effect on his situation.
Originally Posted by s14fbs View Post
well im sitting in my car in the garage wathcing a movie on my mac thats sitting on the hood eating homemade french toast on 18s gettt some
Originally Posted by GSXRJJordan View Post
Nice to know I've got a 30k VA transformer all to myself with 100A 3-phase if I want to start building Cybertron or something in here.
Last edited by silentstyle1; 01-24-2009 at 01:14 PM.. Reason: My grammar was bad... and it made me mad
silentstyle1 is offline   Reply With Quote
Old 01-24-2009, 12:37 PM   #4
Rittmeister
Same question. No offense, but is this a joke?
Old 01-24-2009, 03:54 PM   #5
S14DB
AFC #1
S14DB's Avatar
When you first start up the car the PFC hunts for a smooth idle. If it doesn't have time to do it. It will be touchy going on and off idle.
Page 10:
http://www.apexi-usa.com/pdfInstallation/13.pdf
Also, check your coolant temp sensor.
Old 01-24-2009, 08:04 PM   #6
Rittmeister
OK, I'll try it tomorrow.
Edit: you think this will work on my Nissan, even though those directions on Apexi's website say they're for a Honda unit? I suppose it can't hurt...
Old 01-25-2009, 01:15 PM   #7
tmsilvia
tmsilvia's Avatar
tmsilvia is an unknown quantity at this point
s14DB is right, let it self learn idle for about 30mins, check ur water temp sensor. is ur ign timing 15 degree?
tmsilvia is offline   Reply With Quote
Old 01-25-2009, 01:53 PM   #8
S14DB
AFC #1
S14DB's Avatar
The CB's at Apexi only translated that one manual. The PowerFC's are the same except for the pinout and the base map.
Old 01-25-2009, 02:12 PM   #9
GabeS14
GabeS14's Avatar
GabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfection
may seam liike a dumb question, but what if you dont have defroster or AC? lol
just letting it sit for 10 mins should be good?
E92 M3 19" wheels for sale///JWT Cams and Springs +30whp for sale... cheap.
GabeS14 is offline   Reply With Quote
Old 01-25-2009, 02:17 PM   #10
S14DB
AFC #1
S14DB's Avatar
If you don't have any accessory's then 10mins should be fine. You can also turn on the headlights for 10mins to put a load on. ECU just wants to see how the engine reacts under accessory load. Defroster puts the most load.
Old 01-25-2009, 02:17 PM   #11
Sleepy240
Sleepy240's Avatar
Sleepy240 is an unknown quantity at this point
The PFC gets confused because of the fluctuation in idle when the AC/Defrosters etc are turned on. By letting it hunt the idle with these on/off it learns and corrects for these. If you don't have AC/Defroster then it wont matter since they will never be on
EDIT: S14DB beat me too it =(
Sleepy240 is offline   Reply With Quote
Old 01-25-2009, 02:20 PM   #12
GabeS14
GabeS14's Avatar
I actually put my Jim Wolfe Ecu back in for now, I have been putting off the day to change it back to the power fc and start playing around with the settings..
Old 01-25-2009, 04:32 PM   #13
Rittmeister
CTS is fine.
I tried the defrost/AC procedure, and... it didn't help. Steve Shadows seems to think I need a base map... I'm not sure what to do.
Old 01-25-2009, 10:55 PM   #14
Mirage
Mirage is making a name for him/her selfMirage is making a name for him/her self
Send a message via AIM to Mirage
Friend of mine velcro'ed his into the stock bracket, I didn't have a stock bracket in mine so its just stuff up in there.
If everything else is good with your motor, it might be the water temp correction. Go to settings, water temp, and check to see how much more fuel its putting in the 50* C area, try to drop it down some. I can't remember the specific increments, but I think its 30, 50, 80. It might just be putting in enough to make it stumble.
Boost leaks can be tricky bastids though, i'd still recommend testing for them even if it ran fine on the stock ecu. They can pop up in the strangest of places you wouldn't even think of, and while they might be small enough to not effect much, you get a couple of them and it will.
I'd also suggest getting the car tuned if you aren't planning on throwing a bunch of mods at it soon. Good tuner will clean up the entire map and make it much better running.
Mirage is offline   Reply With Quote
Old 01-26-2009, 01:18 AM   #15
steve shadows
steve shadows's Avatar
For PFC
Engine must be at 80 Deg C for timing mode.
No need to pull the TPS on PFC cars.
Double check TPS voltages too
Your base map settings may be mis-configured for your setup as well.
If you are interested I offer base map/support services for a one time fee of 85 paypal.
Either way I would keep this in mind for timing mode.
Is this Kent?
If everything hardware related is fine - then it is probably setting based, as we spoke about over email.
It's not that you NEED a base map per say, but the settings I re-configure and include in my setup directions with the new base map might clear this up right off the bat , irregardless of the actual map /cell by cell by cell settings
I will offer you as much support/help and maps I can remotely per my offering to board members.
Like Me on FaceBook !
