Old 05-29-2003, 03:59 PM   #1
uiuc240
uiuc240's Avatar
s13 brakes are weird
I have Z32 brakes on my 240. They are making weird sounds these days when coming to a stop. It's like a crunching/clicking sound, and I can physically FEEL it coming through the pedal. The pads are fine, and they still stop well, but it just seems....off. I'm thinking about taking them apart and rebuilding them, but I'm not sure if it will help. Any thoughts? They were rebuilt when I installed them....
Eric
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
Old 05-29-2003, 04:11 PM   #2
FlyingChicken
FlyingChicken is an unknown quantity at this point
Send a message via AIM to FlyingChicken
do you have 26mm calipers? what kinda rotors you using? you using rotors designed for your calipers? brake pads all the same but rotors different for 26 and 30mm calipers.. they were both used on 300zxtt
FlyingChicken is offline   Reply With Quote
Old 05-29-2003, 08:10 PM   #3
Tricky1980
Tricky1980 is an unknown quantity at this point
Send a message via AIM to Tricky1980
i have stock s14 brakes but i have this exact same thing... its coming from front driver side and NOT one mechanic has seemed to diagnose the problem. i stop just fine but im not sure if its affecting performance or not because its just in town so far. but yea... if you get it figured out let me know
thx
JaY
Tricky1980 is offline   Reply With Quote
Old 05-29-2003, 09:14 PM   #4
kalieaire
kalieaire's Avatar
kalieaire is an unknown quantity at this point
Send a message via ICQ to kalieaire
replace your shims, you probably have them in incorrectly. it's a common occurence.
'93 240sx coupe
'93 taurus wagon
-kalieaire (maybe grinder too on special occasions)
kalieaire is offline   Reply With Quote
Old 05-29-2003, 10:31 PM   #5
uiuc240
uiuc240's Avatar
i'm not using shims....just the slimy goo. perhaps it just needs more slimy goo. good call. thanks kalieaire!
and they are 26mm brakes on 26mm rotors, chief . i've had them for almost 2 years now. this is a new development in the past month or so.
i'm going to try new grease soon!
Eric
2002 Mazda Protege5
Old 05-29-2003, 10:35 PM   #6
kandyflip445
kandyflip445's Avatar
You should still use the shims with the dielectric compound between the shim and the brake. Try not to put too much cause it would be bad for your rotor and pads.(Which I'm sure you already knew)
My 240 vBgarage
Old 05-30-2003, 01:30 AM   #7
kalieaire
kalieaire's Avatar
i always put the crap on after i have the brakes installed completely. i don't want the grease and stuff getting where it's not supposed to.
'93 240sx coupe
'93 taurus wagon
Old 05-30-2003, 11:43 AM   #8
Wei240
Wei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really nice
How funny, I have this problem too, I got the 180sx brake/rotor for my s13 and the brakes/rotors are fine. It only goes clicking/clunking when I depress the pedal really slowly and it only happens on the front-drivers side. Brakes works perfectly fine, flushed brake system twice to make sure, rotors resurfaced and I still couldn't figure it out nor did my mechanic, at first I thought it was that metal back dust plate cover thingy since it's too small for the rotors, but that's not it either. Recently after slamming on the brakes hard couple of times, it hasn't made the sound. Its more of an annoyance rather than anything else...
Wei240 is offline   Reply With Quote
Old 05-30-2003, 12:27 PM   #9
Sabertooth
Sabertooth is an unknown quantity at this point
do you guys have abs?
Sabertooth is offline   Reply With Quote
Old 05-30-2003, 04:04 PM   #10
adey
adey's Avatar
Heh heh heh.. ABS? ... I don't think many of us have ABS, and even if we did, that ABS junk has a distinct pedal feel... if it were a n00b who posted the original question/problem, sure, maybe ABS, but... no. Otherwise, good call though!
Instagram: @SX180HKG
adey is offline   Reply With Quote
