Which poly end link bushings to buy?
So I want to replace my endlink bushings, not the endlinks. I replaced my just a year or two ago, and of course they are on their way out... I see ES has a ton of stuff, but I don't know the ID's or OD's. What are you guys running as far as end link bushings go?
-Bart |
#4 | |
16mm high, 24.5mm od', 10mm id. it also has a lip. these are replacement end link i bought. rear end links 8 mm inside diameter for stock. 25 mm for od. the cup that hold the bushing on end link is about 28.5 mm. the replacement will be totally different dimensions. measure your current endlink bolt to get inside diameter. http://forums.nicoclub.com/zerothrea...r-link-upgrade |
u can get stock bushings from the dealer for about 2 bucks a pop
courtesy used to sell the es bushings singles but i cant find it anymore with there new site. try giving them a call. |
Thanks for the help guys. I read the write up, and hopefully the ES bushings aren't too big, to the point that the sway and control arm aren't parallel anymore.. I'll give it a shot, thanks!
-Bart |
