Old 01-31-2009, 02:31 PM   #1
niSm095
niSm095 is just really niceniSm095 is just really niceniSm095 is just really niceniSm095 is just really niceniSm095 is just really niceniSm095 is just really niceniSm095 is just really niceniSm095 is just really nice
Oil pressure sensor removal question
In reference to this thread:
http://forums.nicoclub.com/zer...age=1
I was under the car (s13, blacktop sr) tring to hook up my oil pressure gauge and I can't find a reasonable angle to get at the sending unit to remove it. I have a 26mm wrench, as stated in that article, and it seems a tad too small. What is the easiest angle/way to get the sensor off? Anyone? Am I brain dead and missing something?
niSm095 is offline   Reply With Quote
Old 01-31-2009, 02:49 PM   #2
windshieldwiper
windshieldwiper is an unknown quantity at this point
27 mm long socket from the top worked fine for me. squeezed through the space between bracket and filter.
26mm or 1 inch socket is prolly closer in size. i just happened to have 27 mm. 4 inch extension.
i would guess you could use a small pair of pliers from top as well. just go straight in as if you were using a socket.
windshieldwiper is offline   Reply With Quote
Old 01-31-2009, 02:53 PM   #3
niSm095
alright...I've got a 27mm deep socket. I'll try to reach in there with that from above. I gave up pretty quick from above the car since I'm usually barely able to get the oil filter from above.
Old 01-31-2009, 02:54 PM   #4
windshieldwiper
you are golden. make sure it is a star socket. the six sided ones might be too fat to squeeze in. 26 mm long socket star socket is prolly ideal.
Old 01-31-2009, 03:01 PM   #5
projectRDM
projectRDM's Avatar
It's a 27mm anyway, but remove the intake brackets if you haven't already, gives a lot more access to that side of the block.
FORMERLY R240NA
Old 01-31-2009, 03:13 PM   #6
niSm095
Ah. the 27 I have is only 6 sided. Just tried it...no dice. not enough room to get next to the filter with it. I'm not sure which bracket you're referring to?
Old 01-31-2009, 03:16 PM   #7
windshieldwiper
i think your car is different from the ka24de. i'd try adjustable plier. should work if not rusted.
Old 01-31-2009, 04:30 PM   #8
projectRDM
projectRDM's Avatar
There's two large support brackets that support the intake plenum and bolt to the block. Remove and discard.
FORMERLY R240NA
Old 01-31-2009, 05:00 PM   #9
niSm095
Gotcha Thanks for the help. I only had one of these brackets, the "Y" shaped one. Got it off the car...made the process a breeze. Not having a garage sucks. I'll wire it up in the morning.
Old 01-31-2009, 05:00 PM   #10
40daws
40daws is an unknown quantity at this point
^ Thanks for the info on the intake brackets. I kept looking at them and trying to see the need . In the trash they go.
40daws is offline   Reply With Quote
Old 01-31-2009, 05:07 PM   #11
niSm095
From what I remember the oil pressure is supposed to be about 25 at idle and 50-60 something at WOT?
Old 01-31-2009, 05:41 PM   #12
windshieldwiper
for ka24de , at least 11 psi at idle and 60-70 at 3000 rpm
Old 01-31-2009, 05:57 PM   #13
niSm095
...um..okay. preciate it. but...read the first post again
Old 01-31-2009, 06:02 PM   #14
singlecamslam
singlecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymore
Alright dumb question, can anyone tell me the thread pitch and size of the stock sender? Is it 1/8? Thank you..
Nothing says racecar like a stock car with no interior.
singlecamslam is offline   Reply With Quote
Old 01-31-2009, 06:49 PM   #15
niSm095
1/8th bspt I believe...on an SR..if it's for another motor make your own thread or search harder.
Old 01-31-2009, 06:53 PM   #16
GSXRJJordan
GSXRJJordan's Avatar
1/8" BSPT is correct. Different than 1/8" NPT.
Old 01-31-2009, 07:50 PM   #17
singlecamslam
Cant you use 1/8th NPT thread but with a whole bunch of pipe dope so it wont leak?
Old 01-31-2009, 08:11 PM   #18
windshieldwiper
it will prolly work without the dope but you wreck the threads. the adapter is 13 bucks. only dopes use dope.
Old 01-31-2009, 08:30 PM   #19
AndyCs13
AndyCs13 is an unknown quantity at this point
summit sells the adapter.
what kind of gauge are you installing?
i just used pliers to get the stock sending unit out. it was pretty easy. i still have my intake brackets too.
AndyCs13 is offline   Reply With Quote
