Old 01-31-2009, 02:44 PM   #1
AngryPanda
AngryPanda is an unknown quantity at this point
Fiberglass Bumper repair/fitment #2
This is a how to on making a cheap (ebay) bumper fit.
The work was done a a Matrix with a bumper purchased from ebay.
Before
The bumper had several issues.
1. The edges where the bumper meets the fender did not line up poperly
2. The bumper was made to wide for the car.
3. Area around the headlamp were uneven with huge gaps
4. the area around the grill was uneven with huge gaps
5. The finished surface of the part look like a ocean (waves)
Tape up the adjacent areas of the bumper to body to protect the paint, I used 4-5 layers of masking tape. If you are not used to doing this type of work it is advised to make the tape lines higher.
Apply some wax to the tape and all areas that will need to be filled. This will make the filler release easily from the car.
Put the bumper on close to factory fitment as possible. Secure it in place using bolts. You will be sanding on the bumper so make it sturdy as possible. At this point make necessary cuts, and breaks to make the bumper fit.
After the bumper is on the car sand all of the gelcoat down to the fiberglass in the areas that needs to be filled. Go about 3-4 inches past the immediate area of the filler. Use 40 grit or lower sandpaper
For gaps bigger then 1/8 of an inch use course fiberglass filler such as tiger hair of kitty hair.
For areas less then 1/8 use a high grade reinforced fine filler such as fibertech.
First squeeze the kitty hair in to the big gaps. Try to get it flush to the adjoining surface as possible. Let this dry about 2-3 mins and while the kitty hair is still soft rough shape with 40 grit sand paper.
After the kitty hair has dried use the reinforced filler to fill in the small gaps.
Let it dry untill tacky and sand to shape flush with the car.
After all outer surfaces are done remove the bumper.
It will be stuck to the car and will need some muscle to get it off.
after the bumper is off the car sand down the remaining filler to shape.
Repeat above process until you are happy with the fit.
If you have cracks from flexing the bumper or making major adjustments to it shape, look at my other post to see how to repair the broken areas.
http://zilvia.net/f/premium-members/...er-repair.html
Last step is to apply plastic filler over the entire area and sand to shape.
Using some sanding block work the entire bumper starting at 40grit up to 150 grit
Remount everything back on the car for final fitment before primering
Optional make some braces to support the ends of the bumper
and done
Some more pictures
We do "Awesome"
AngryPanda is offline   Reply With Quote
Old 02-01-2009, 08:37 AM   #2
CrimsonRockett
The Architect.
CrimsonRockett's Avatar
Trader Rating: (392)
Feedback Score: 392 reviews
Sweet.
This is perfect for everybody running aftermarket bumpers with crappy fitment.
Get them bishes to look good!
-Jspec-
Instagram/CrimsonRockett
Old 02-01-2009, 11:47 AM   #3
Brian
Brian's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
And this is exactly why the "cheap" ebay bumpers end up costing the stupid customer an arm and a leg in the end.
All the money they "saved" ends up going to the body shop for the hours spent on fixing the shit product.
http://bhworld.wordpress.com/
Old 02-01-2009, 11:52 AM   #4
CrimsonRockett
The Architect.
True.
I would have expected better fitment on Origin stuff though.(not that this bumper is origin)
It seems like they're almost spot on with 180sx stuff, but on my friends Z33, it fit like crap and was SUPER wavy.
Don't know what's up with that.
-Jspec-
Old 02-01-2009, 12:08 PM   #5
LongGrain
LongGrain's Avatar
ive never had a problem with origin, i have an origin bumper that was broken into 6 pieces. i ziptied/duct taped it back together and it STILL fits better than a lot of the cheaper stuff ive seen.
my origin fenders fit like OEM.
LongGrain is offline   Reply With Quote
